Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 201 to 300 of 836
Thread: NOX Composites?
  1. #201
    Jun 2013
    No, we have no relationship with Kappius. "Imitation is the sincerest form of flattery" :-)
    The Kappius 29er rim and Nox XCR-29 are actually pretty similar in dimensions. They just use a non-standard way of measuring internal width. If you measure the XCR-29 rim the way they do it is 26mm wide internal and 31mm external. The difference in weight is because we have more material in the bead for rock impact durability and the XCR-29 is ~5mm deeper for more lateral stiffness.
    Nox Composites
    Carbon Fiber Mountain Rims and Wheels
  2. #202
    Jul 2013
    Thank you for the clarification I was just wondering since lots of the features seem pretty similar...
  3. #203
    Jun 2005
    I'm looking for a carbon rim with asymmetrical design for my gravelgrinder/cyclocross/road bike and the NOX XCR-29 rim is the only one I've found and I like the looks and reviews of it so far.
    I run 30 mm Grand Bois Extra Léger when I'm on the road and Challenge Grifo XS 32 mm för cyclocross and gravel. Today I use the Velocity A23 OC rims with 23 mm outer width (tubeless ready).
    There is a trend in road cycling of going for wider rims in order to reduce the "light bulb profile" of the tire which gives better handling in curves. I also find the comfort increasing when getting a wider footprint and being able to run lower pressure.
    Will the XCR-29 rim be too wide for my 30 mm tires? I've seen 23 mm wide road rims paired with 23 mm road tires. Can I assume that a 30 mm wide rim can be paired with a 30 mm tire then? And is there an upper tire pressure limit on the XCR-29 rim?
    /K
    Wheel brewer
    "For I am a Bear of very little Brain, and long words bother me"
  4. #204
    Jun 2013
    It will depend on the individual tire whether it will actually seat or not, but in general running a 30mm tire on a 30mm (external) rim will not give you good handling results. The engineer who designed that 30mm tire probably never intended it to be ran on a 30mm rim. I'd recommend you go with a 40mm+ tire (for example Clement X'Plor 700x40 or similar) for gravel applications. Max pressure is listed as 60psi but if your tire is listed higher than that you can safely go up to the tire's limit.
    The same benefits are found off road, actually it's more pronounced since tire rubber hysteresis losses are a much bigger factor off road (much more tire deflection with trail chatter than on a smooth road).
    Nox Composites
  5. #205
    Jun 2005
    Ah, thanks.
    Do you have any plans for a narrower cyclocross rim? Say, 25-26 mm outer width.
    /K
    Quote Originally Posted by NoxComposites View Post
    Wheel brewer
  6. #206
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    NOX Composites?
    Huh?
    The comfort benefit of lower pressure is more pronounced off-road because of hysteresis?
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  7. #207
    DLd
    DLd is offline
    Feb 2005
    Are you guys gonna be releasing a hookless rim design soon? Less weight, higher strength, easier manufacturing... there doesn't seem to be a downside. It would be nice to see a rim lighter than a Crest. That would make the upgrade to carbon a bit easier to swallow. Stiffness is nice, but at 160lbs I'm not crushing the Crests. Or it seems that any lack of stiffness isn't holding me back... I'd expect you could make a carbon rim both lighter and stiffer then the Crests. They seem to be the benchmark for performance/dollar in xc/marathon. I expect carbon rims to cost more, no problem there, but I'd also like to see them be lighter. I'm thinking maybe hookless rims would help get you there. I'm sure you guys have talked about it. Are there downsides that aren't being mentioned?
    Fall is here. Woo-hoo!
  8. #208
    Chris Bling
    Reputation: dustyduke22's Avatar
    Quote Originally Posted by DLd View Post
    One big one I can see is the increased amount of acceleration and speed you will gain with light, stiff carbon wheels. Are you really ready for those types of gains?
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  9. #209
    Don't focus on just the weight. The XCR rims are MUCH stiffer, as you mentioned, and also wider. And because they're stiffer and stronger than a Crest you can use lighter spokes (which saves weight) and still end up with a very stiff wheelset. It's easy to say the Crests are stiff enough, but once you ride some stiff carbon wheels, it's hard to go back. I've got a set of American Classic hubs laced to Crest rims with DT Swiss Comp spokes, and I've got a set of Hope hubs laced to Nox XCR rims with DT Swiss Revolution spokes. The AC/Crest combo is a handful of grams lighter thanks to the very light hubs, but the Hope/Nox combo is WAY more fun to ride thanks to the stiffness - the bike feels a lot more planted and stable in the corners than it does with the Crest rims. Riding is believing.
    All that said, I'd love to see a lighter rim offered too.
  10. #210
    DLd
    DLd is offline
    Feb 2005
    Quote Originally Posted by dustyduke22 View Post
    So Crests and Nox XCR-29 rims are both 380grams. You're saying I'll see increased acceleration and speed simply because the Nox are carbon? Interesting hypothesis.
    Anyway, I was asking about downsides to hookless, not carbon. I don't doubt that the nox are stiffer, btw.
  11. #211
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by dgaddis1 View Post
    This^^^ I've been on Nox for awhile now and these things kill it compared to the Arch/i9 set I was on before. Acceleration and cornering are just awesome, point and go with no deflection at 190 pounds. I have a set of hookless Light Bikes on my fatty and too soon to tell if there will be any disadvantages but they sure mount up tight.
  12. #212
    DLd
    DLd is offline
    Feb 2005
    Agree with all about the benefits of carbon rims. I have them on my 26'er. At about 1250gms for the set they're amazing.
    I was more interested in hearing about what nox has up their sleeve and if an advance like hookless is something they're considering to up their game, or if they think hookless is hype and has some heretofore unknown downsides.
  13. #213
    aka bOb
    They are already doing hookless in their AM rims.
  14. #214
    Jun 2013
    We don't think hookless is hype. There are real advantages to bead strength and we've measured them in the lab. The ONLY downside is a limit in maximum pressure. But we're hearing more and more people tell us they'd easily trade a 45psi limit for lighter/stronger mountain rims. So given that feedback, that is the direction we're taking for our future mountain rims.
    Our AM/Enduro rims ARE hookless and have been for a while now. Our AM-275 rim has a 3.5mm bead, which is one of if not the burliest on the market. The AM-29 has a 3mm bead.
    We are in final testing stages of a racing, pure XC 29er rim now. This rim is hookless and will push the limits of strength/stiffness at very low weights by using more T800 fiber and a hookless bead with our overwrap construction (no seams near the bead edge). Look for that rim to start shipping in about 1.5 months.
    This thread needs more pics! Here are some pics of the Pivot Enduro Team who helped develop the hookless rims on the World Cup Enduro Circuit (these are from South America) and from some local terrain.
    Nox Composites
  15. #215
    Mar 2014
    What about the XCR-275? Any news? Postponed for later? Thanks!!!
  16. #216
    Jun 2013
    We are working that rim too, but the race 29er rim will be ready first.
    Nox Composites
  17. #217
    DLd
    DLd is offline
    Feb 2005
    Awesome! Perfect timing. Looks like I should be able to get a set in time for the Grand Junction Off-Road!
    Nice pics btw.
  18. #218
    I've got a really cool set on deck, I'll post pics once they're built up. AM29 rims, King hubs, mix of black and white spokes.
  19. #219
    more skier than biker
    Nov 2006
    I've only had my Nox XCR-29's a short time, but I've become a huge fan. Stiffness = check. Good weight = check. Durability = so far, so good, no complaints.
    Recently won the California State XC Championship in Open Single Speed on a set! (hard to see the Nox logos due to dirt). Love em....looking forward to see what you guys come out with next.
    Kappius Components Ambassador - Ping me a note for a discount code
  20. #220
    Dec 2005
    any beans to spill on the 29er race rim ? dims ? offset ? will it have the anti burp bumps ? target weight ? price ?
  21. #221
    AM29 rims, Chris King hubs with the new XD driver, mix of black and white Sapim CX-Ray spokes with red alloy nipples. Built for enduro racing!
  22. #222
    Nov 2007
    Real vs declared weight. WTF?
    A bit disappointed:
  23. #223
    NOX Composites?
    I just ordered a set of am-29/i9 wheels for my intense spider 29 comp. I have enve am's on my carbine 27.5. I'm looking forward to the comparison. I'll post pics and feedback in a couple of weeks.
  24. #224
    Jun 2013
    Quote Originally Posted by jadis3 View Post
    A bit disappointed:
    Hi, please contact us, we'd been happy to swap this rim out for you. As I'm sure you're aware, manufacturing variances leads to different weights for each rim. Assuming your scale is accurate, this is out of spec and we'd replace it for you. Spec on the XCR-29 is 380 +/- 10g.
    Nox Composites
  25. #225
    Nov 2007
    Thank you for the opportunity, great service.
  26. #226
    Apr 2013
    Nox Rims with some chris kings. I think i may try some... ...green ones
    "Because it's RED"
    I disagree. I believe that Green is much faster- the trick is finding it!
    Green= Fast.
  27. #227
    NOX Composites?
    AM-29's laced to i9 hubs.
    My bike shop was very impressed with the rims and really liked the guys at Nox.
    I'll get a few rides in and report back how the compare to my enve am's.
  28. #228
    Reputation: madskatingcow's Avatar
    So, when is the hookless 29'er XC rim coming out? Send a mail to Nox about 2 months ago, never got a reply
  29. #229
    NOX Composites?
    Was able to get a short ride in this morning. First impressions are these wheels rock. Super stiff, quick acceleration, and track amazing. I'm running nobby nic 2.35's on my Enve AM 27.5 wheels and the nobby nic 2.25's on the Nox AM-29 are wider.
  30. #230
    Jun 2013
    Our latest demo bike build:
    Nox Composites
  31. #231
    Quote Originally Posted by gcohen View Post
    Looking forward to the report. These are on the list. I have a set of Derbys on CK on my SS, and I want to try out the Nox rims on some i9s next.
  32. #232
    I've ridden them a half a dozen times now. They are great. I'm running approx. 20psi tubeless on rocky rooty north east trails. I'm 210lbs and I have not had an issue. These wheels look and act the part!! Very satisfied and zero regrets choosing them over another set of Enve's
  33. #233
    Same here. I've had my AM29's about a month and they have been amazing. 20 PSI seems to be the sweet spot on Nobby Nic 2.25 in the rear and about 18 up front on a 2.35. Had my LBS order them from Nox and the build quality was excellent. The guys at Nox were great to deal with as well. Without a doubt, I'll be buying another set for my next rig.
  34. #234
    This thread needs more pics!!!
  35. #235
    NOX Composites?
    Quote Originally Posted by crlavoie View Post
    I really like what NOX is doing as well. Haven't seen any in person but they're at the top of the list to replace some Nancy Wides that I'm not super stoked on.
  36. #236
    Just recevied my xc 29 with ac hubs and 142 rear axle last week. First ride was a 60 miler in Marin and here are first impressions:
    Super Stiff
    superior braking.
    Upgraded from a pair of Stans Crests
    excited to race these this weekend at the lake tahoe 100k
  37. #237
    Jul 2013
    Quote Originally Posted by newportl View Post
    Loving my AM29s on I9 hubs, best bike upgrade I've ever made. I run them at 16-17 PSI for my 150 lbs on 2.3 tires. Fantastic corning traction and steering precision. My bike feels much more composed on jump landings. Specialized tires mounted up easily tubeless, hold air well, and have stayed true. Riding on them for 2 months.
  38. #238
    Reputation: trumpus's Avatar
    Quote Originally Posted by brightride View Post
    What I need to hear - this is my planned build (all black).
  39. #239
    Aug 2005
    Stoke to be riding my set soon on a 2014 Trek Remedy - I just received a full build of 27.5 on CK XX1 hubs.
    Following this thread, their price point, and race results really moved me to purchase over other brands/options. NOX appears to be scaling with demand pretty well.
    Timing was very prompt once parts arrived (~1 wk + 4 days shipping from TN to CA). CK XX1 hubs had to be ordered, which took 2wks to arrive. Their packing list showed hubs ordered a few hours post my online order. Not everything can be amazon prime'd and drone-dropped on my doorstep.
    I received an email confirming 1) my initial order 2) parts arrived & into production 3) shipping.
    Boxed wheelset was a little lightly packaged. Fed-Ex did a number on the box, but the wheels look like they arrived without damage.
    Will report back once I get tires mounted and some miles on my local trails.
  40. #240
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    I am at 10 months on my 29er Nox laced up by Dave at Speeddreams.
    Best wheels I have ever owned. I like them better than the Rovals and the Enve AM 29ers.
    Great hoops thus far.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
  41. #241
    Jul 2014
    Quote Originally Posted by Green Giant View Post
    Great to hear! Dave is completing my 27.5 wheels today. I'm going with Chris King hubs, should be a great setup on my Tracer T275...
  42. #242
    Jun 2014
    Uh oh
    Still haven't got the package yet, hopefully everything is alright.
    Been waiting almost a month now
  43. #243
    Fat Skis/Fat Tires
    Reputation: rangerbait's Avatar
    NOX Composites?
    Quote Originally Posted by mattwright999 View Post
    Uh oh
    You Canadians with your beady eyes and your flappy heads...
    Jk, hope everything is ok with your shipment...their packaging seems suited only to best shipping case scenario unfortunately.
  44. #244
    Jul 2014
    Uh oh
    Bummer, I hope everything is okay...
  45. #245
    DLd
    DLd is offline
    Feb 2005
    Any word on those new hookless XC 29'er rims?
  46. #246
    Green Giant, I'm curious, what makes the Nox better than the Enve AMs you tried? I'm on a set of those right now and hands down, best wheels I've ever had under me. I've been eyeing Nox for a second, lighter weight wheel set for summertime conditions.
  47. #247
    Well for starters Kalamath the nipples are external making tweeks really easy.
    Should you need to make one.....
    That's all I got.
    Watching this thread closely.....
  48. #248
    I love my Nox am 29er rims, but I have to say their shipping, packaging leave a lot to be desired. I have worked for ups for years and there is no way I would ship something I wanted to make it there in good shape like they do. I had one of my boxes completely destroyed. Wheel had some marks but no breaks so I kept them. I probably should have sent the one back but I was ready to ride. Waited forever to get my Hope trials single speed hub. Nox, step up your packaging - we will gladly pay for it.
  49. #249
    Jun 2014
    Just picked up my package today. Unfortunately it looks like my end caps on the hubs were damaged
    I was surprised to see that there was no support at all for the rim in the box. The rim arrived only in a plastic bag and placed into the box.
    Both my rims were shipped separately and this is my first rim to arrive the other one should be here late next week. I have a feeling Im going to end up with the same damaged box and end caps on my front rim
    Im going to send NOX an email today and hopefully they can send me new end caps.
    The good news is my Maxxis HR2 tires went on without any effort and they aired up using a floor pump with no sealant. No air leaks! (will add sealant later)
    I may bring the rim down to the LBS and have them look at it quick just to make sure everything is good
    Sorry for the crappy phone pics, its hard to see the damage. The end caps are dinged up and scratched.
    I will take some better pics once the other rims arrives. Cant wait to get out and ride these!
    w/ I9 Hub with XD driver
  50. #250
    Quote Originally Posted by Kalamath View Post
    The Nox set up tubeless easier than the Enve for sure. I actually managed to knock my rear AM Enve out of true (though Dave at speeddreams didn't build the Enve's).
    Found that the internal nipples were a pain on the enves for 2 reasons. 1. Had to take the tape off to true them up. 2. The aluminum nipples (which have now been changed, corrosion issues).
    The Enve's rode great and were stiff just like the Nox.
    Either way, I'd have Dave build up the wheels. The bladed spokes I believe are stock by both Enve and Nox and don't add anything other than weight and a pain in the arse factor. I also think that offset spokes make sense.
    The Enves are absolutely a nice wheel, I just like the Nox better, and from a price standpoint there is really no comparison on bang for the buck.
  51. #251
    I should be out riding
    Reputation: ACree's Avatar
    Sep 2004
    I've been running Nox XC-29 rims since late April, approximately 400 mostly trail miles since then. Absolutely the easiest rims to mount up tubeless I've ever used (comparing to Stan's Arch's, WTB i19s, and Shimano XTR UST), and the only rims that could be inflated tubeless with a floor pump. Very positive snap as the bead seated. Mine were built on Hope hubs, with Comp spokes by the Nox guys. I did find a few loose spokes on the rear last week, which is quicker than I've experienced with other builders like Stans or QBP building, but didn't take long to true back up.
    These are my first carbon wheels and I've been very happy with the ride. I do think the difference over aluminum is frequently exaggerated in reviews though. From what I've seen, I would buy Nox again.
  52. #252
    Aug 2005
    NOX Composites?
    Just a couple light trail rides so far but loving really the inner width and handling characteristics. Here's a couple photos. I know the trail looks like a dirt sidewalk
    <a href="http://imgur.com/tfQP1rc"><img src="http://i.imgur.com/tfQP1rc.jpg" title="Hosted by imgur.com"/></a>
    <a href="http://imgur.com/SIdz2rB"><img src="http://i.imgur.com/SIdz2rB.jpg" title="Hosted by imgur.com"/></a>
  53. #253
    Jul 2014
    Just got my NOX wheels today, built by Dave (Speeddream)...
    Front - 783 grams
    Rear- 941 grams
  54. #254
    Reputation: metrotuned's Avatar
    @Tyrone, congratulations. Tell us more about your gearing setup on that winning bike.
    Producer, Actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
  55. #255
    Shipped this set out this week - burly build for a client weighing in around 250lbs. AM275 rims, Chris King hubs with the stainless steel freehub body upgrade. Instead of the usual lightweight spokes I used the Wheelsmith DB14's instead, a bit heavier gauge than Revolutions or CX-Rays or Aerolites for an extra dose of stiffness. Brass nipples. 1,837g if my memory is good. Bombproof and built to take a beating!
  56. #256
    Jun 2013
    I just want to say that this is NOT how we ship wheels. I believe what happened in this case was the box was ripped open during shipping and the wheel supports fell out and were not replaced by the carrier (that box has clearly been through the ringer!). When wheels leave our shop they are fully supported in the box by cardboard inserts both vertically and laterally and also placed in a plastic bag for scratch protection. Shipping damage has been extremely rare.
    Nox Composites
  57. #257
    You might better get back in there and tell your shipping guy to start doing a better job. Mine had nothing in the box except a wheel in a plastic bag.
  58. #258
    Jun 2013
    Well, we don't really have a shipping guy (I wish!). I suppose it's possible someone zoned out and shipped your wheels without the protective inserts, in which case we screwed up - and please contact us if there is any damage whatsoever to your wheels and we'll take care of you.
    I can tell you that is not the way they are supposed to be shipped. I snapped some photos this morning of our wheel shipping box. This is a pretty standard wheel box design across the industry and does a good job at keeping the hub axles and freehub body centered and away from the sides of the box. We've had VERY few issues including shipping wheels all over the world.
    (note protective plastic bag is not included in these pics)
    Nox Composites
  59. #259
    NOX Composites?
    Just an FYI, my wheels came nicely packed, in great shape and have been running great ever since. Very happy customer.
  60. #260
    Dec 2005
    how are the xc light rims coming ?
  61. #261
    My experience with NOX Composites:
    1. Great wheel
    2. Great Price
    3. Fast, stiff, and light
    4. Excellent customer service
    5. Already saving up for the AM29 set
    And they look damn good on my wife's Yeti SB75.
  62. #262
    Aug 2014
    Is there any eta on the Nox 27.5 xc rim?
  63. #263
    Jun 2013
    Just a few weeks away now. Sorry for the delays, it's taken some time to get these lightweight rims right!
    Nox Composites
  64. #264
    chasing simplicity
    Reputation: MattMay's Avatar
    Dec 2013
    Awesome news! I'll be among first to order/pre-order…
  65. #265
    Aug 2014
    Your timing is perfect, can't wait to order Nox 27.5 rims xc w/ck hubs for my new ride.
  66. #266
    chasing simplicity
    Dec 2013
    ...it's taken some time to get these lightweight rims right!
    btw, just how light are they…can you reveal ballpark rim weight? If not, can we assume about the same weight difference as between the 29 xc an am rims?
  67. #267
    Jun 2013
    Our target weights for production rims are 340g for race 29er and 320g for race 650b.
    Nox Composites
  68. #268
    Jun 2005
    Do you have an estimate on rim width on the "race 29er"? I'd like to use it for a cyclo cross/gravel grinder wheelset.
    Wheel brewer
  69. #269
    chasing simplicity
    Dec 2013
    NOX Composites?
    Awesome, thank you!
    I know what it's like to be dead. "To Die & Live In LA."
  70. #270
    Aug 2014
    Nice only 320 grams for the 650b rims. I would like to know inner and outside width of my future rims.
  71. #271
    Any more info on the new rims with better spoke hole angles? Please give update, Thanks.
    650b and 29er lighter rims for XC
  72. #272
    Nov 2007
    Have to say that I have had a big improvement by riding Nox wheels vs good alu wheels.
    Worth the price.
    Thanks to "a small business owned and operated by cyclists".
  73. #273
  74. #274
    Re: NOX Composites?
    Cool!
    Nox, when will the 29s be available?
  75. #275
    chasing simplicity
    Dec 2013
    The Skylines sound great, but slight ouch...$1800 built out the door...$400 more than my Nox AM-275s.
  76. #276
    Re: NOX Composites?
    Quote Originally Posted by MattMay View Post
    I think they have a script problem on their website. It shows $479 for a single rim, but then when you add it to the cart the price for one rim jumps to $958.
  77. #277
    chasing simplicity
    Dec 2013
    Definitely an error. Doesn't happen when you use drop down to order a build.
  78. #278
    Yeah, hopefully that's an error. The $20 increase in per/hoop price certainly doesn't account for the $400 uplift for a wheelset.
  79. #279
    chasing simplicity
    Dec 2013
    I think I got the early adopter special last year...they were running a limited offer before year end on the AM275 now that I recall. Still, my invoice was like $1400 with shipping. Enough of a diff to make me pause before I hit "order" button now! I got spoiled.
  80. #280
    DLd
    DLd is offline
    Feb 2005
    Nice, hopefully this means the Skyline 29's will be showing up soon.
  81. #281
    Full year on the NOX rims (~1200 miles) and not a single issue....
    Many dings, scratches, crashes, and ohh sh!!!!!!t moments but still true and sound.
    Love em
  82. #282
    chasing simplicity
    Dec 2013
    Fairwheel Bikes is showing the AM275s at $382.50/rim ($67.50 off) if you're in the market for great 35mm carbon rims!
    https://fairwheelbikes.com/nox-asymm...im-p-6094.html
  83. #283
    Coming in few weeks !!
    I like the new Teocalli, should be a great do it all 29er rim. 26mm inside and 31mm outside. NOX also offers Lilly Percision nipples in any color, the best nipples you can get. I'm still desiding of the new graphics, I don't know if I like them!!
  84. #284
    Jun 2005
    So, hookless Skyline means that cyclocross and gravelgrinding is out of the question? Can one run pressures up to 6 bar (30 mm road tires) on these hookless rims?
    /K
    Wheel brewer
  85. #285
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Had a set of XCR 29s/Hope Pro2, for a year. Found them not quite as good as narrower, hooked Easton EC90 XC, which I still love(solely my opinion). YMMV....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  86. #286
    Not a fan a Easton or Hope, try to get parts for Easton hubs. Good luck!! The bearings in newer Hope hubs suck, local bike shop will not sell them any more. Just my 2 cents!!
  87. #287
    Oct 2013
    NOX Composites?
    These Teocalis will be perfect on my Anthem SX! This is my next purchase for sure.
  88. #288
    Reputation: davemk's Avatar
    Jan 2009
    Quote Originally Posted by dgw7000 View Post
    So is the Farlow a revision or just re-naming of the AM275? I am looking at picking up some Nox wheels for my Nomad3, and don't want to buy old tech.
  89. #289
    chasing simplicity
    Dec 2013
    NOX Composites?
    Quote Originally Posted by davemk View Post
    Just ordered the Skylines. I don't even see Farlow, where is that? Just the three different 27.5s: 35mm AM275, 32mm Teocali, 29mm Skyline.
  90. #290
    Jan 2009
    The image above has the Farlow listed instead of the AM275 but the specs look almost identical. Hence my question, is it a new rim or just a new name?
  91. #291
    The Farlow is new as NOX will confirm, just call them and ask. When I did they always answer all my questions, good people!!
  92. #292
    No the Farlow is the AM rim renamed, already talk to them.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
  93. #293
    The rim is not the same, it has a better design.
  94. #294
    Nothing was mentioned on the phone about a redesign, just changing the name to line up with other names.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
  95. #295
    chasing simplicity
    Dec 2013
    What's weird is they don't have that image on their site...must be an ad somewhere, or catalog? Curious,. I Googled Nox Composites Farlow, got a page Noxcomposites.com/farlow29 and got "access denied."
  96. #296
    I was on the phone with them this week. She said they are in the middle of updating the site.
    The new pre-order rims have Project 321 hubs as an option, the AMs don't, things like that.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
  97. #297
    Jan 2009
    I just got off the phone with Kaysee at Nox Composites. She specifically said that the Farlow is the AM275 rim, it is just a new name.
  98. #298
    Quote Originally Posted by TwoTone View Post
    So how is this a new rim and better design?
    Love the internet, people posting things they know nothing about.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
  99. #299
    NOX Composites?
    He meant better designed decal.
  100. #300
    The spoke holes are done at better angle, after I talk to Brad again will pass on what he say's. Just to make sure it wasn't a dream. He also told all the new models are using the new drilling's and some other improvements which make the rims stronger. All the info I have came from Brad, I also said I'm on the fence about the decal !!
    Sounds like I'm not the one passing wrong info, call and walk to the designer of the wheels not who ever answer's the phone.
  1. Replies: 14
    Last Post: 12-15-2011, 04:55 PM
  2. Replies: 0
    Last Post: 09-06-2011, 09:15 AM
  3. Replies: 0
    Last Post: 09-06-2011, 09:13 AM
  4. Ahead Composites Wheels
    By Stevob in forum 29er Bikes
    Last Post: 08-23-2011, 08:56 AM
  5. A joint venture between Turner and Edge Composites
    By juan_speeder in forum Turner
    Last Post: 12-10-2009, 07:47 PM
Members who have read this thread: 214
