Results 1 to 12 of 12
    Rider On The Storm
    Reputation: crimsontime's Avatar
    Noise that only occurs at high speed, derailleur or freewheel?
    Hey guys,
    I'm trying to diagnose a noise that only starts to occur when I'm going high speed and not peddling at all. It's like a thrumming sound and it induces some minor vibration and it seems to come from the rear derailleur or freewheel. If I start peddling even slowly that mitigates the noise. Any ideas on what this is? I'm on a budget and want to do a DIY repair, but even if I took it to a shop this is hard to reproduce since it does not occur at all at low speed. What I'm worried is that this could cause the bike to lock up or something at speed if it gets worse.
    Also, I'm not sure if I'm in the right forum to post this, as I haven't posted much in the last decade.
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    Hi CT
    Can you provide more info regarding the bike? Brand and model, what components make up the drivetrain, types of brakes etc, it will help narrow down peoples views and suggestions to solve your problem.
    What a perfect waste of time
    Sneaker man
    Reputation: mik_git's Avatar
    is it a mavic wheel?
    All the gear and no idea.
    Nutrailer
    Aug 2016
    As you've posted in DT as well it may be worth deleting your post here to avoid chasing answers in both
    Rider On The Storm
    It's a Cannondale Prophet 800, 2006 model, all stock components (Deore LX/ XT from way back then) and yes it has a Mavic rear wheel. The rear wheel isn't stock, I think I bought it used after the old one was damaged, but this had to have been at least 8 years ago. Memory is foggy. Just started riding a lot again recently.
    Sneaker man
    Not saying it IS, but could be the mavic scream, I had this the other week on my road wheels, all of a sudden, at speed I get this...grinding, vibrating sort of howl. Turns out a well know issue, lack of lub in he freewheel, which leads to the bushing binding on the hub. Pulled it apart, put a little lube smeared about, problem when away. If it is left too long the bushing wears, so you have to replace it.
    Could be that, could be something else...
    Reputation: J.B. Weld's Avatar
    Probably something in the freehub mechanism is making the noise.
    I brake for stinkbugs
    Rider On The Storm
    Thanks guys I will pull it apart tonight and add some lube... see if that fixes it. I'm adverse to spending too much money on this old steed, although it still is riding well otherwise.
    Freehub.
    \_(ツ)_/ SuperModerator
    Reputation: Klurejr's Avatar
    Sounds like a hub issue. Moved both threads to Wheels n Tires and merged them.
    Ride Bikes, Drink Craft Beer, Repeat.
    Know these before you post:
    MTBR Posting Guidelines
    e-bike sub-forum rules
    Rider On The Storm
    Quote Originally Posted by mik_git View Post
    That sounds like it exactly. We'll see. Thanks!
    Reputation: Lone Rager's Avatar
    Dec 2013
    Many Mavic freehubs use a big plastic bushing for the freehub bearing at the hub. Lubing it can help but they will wear to a point where the freehub becomes wobbly and should be replaced (~$50). For lube, I've used Slick Honey or Phil's Tenacious oil. IDK specifically what Mavic recommends.
    Do the math.
  1. Shimano "Complete Freewheel Body" vs "Freewheel Body Unit"
    By Scott Novak in forum Wheels and Tires
    Last Post: 01-06-2015, 01:03 AM
  2. Curious natural phenomenon occurs around here every spring
    By ric426 in forum General Discussion
    Last Post: 04-20-2014, 10:27 AM
  3. Replies: 1
    Last Post: 10-30-2013, 01:53 PM
  4. If A Skid Occurs on the Trail
    By Enduramil in forum Eastern Canada
    Last Post: 09-26-2011, 08:15 PM
  5. Noise, noise, noise!!!
    By Loos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2008, 01:59 PM
Members who have read this thread: 30
