Results 1 to 8 of 8
    Oct 2010
    Nextie Premium, Crocodile, Regular & Asymetric
    Trying to gather differences and what to buy for my Ibis HD3 at 27.5
    Premium rims will be closer to what a Derby or Ibis rim might be....that's an assumption. Only options are 39id or 29id. I plan to run 2.6 most likely so seems like that 35id sweet spot is missing. $240 a rim [NXT27XA45] PREMIUM 32mm Width Carbon Fiber 27.5+ 650B Plus Mountain Bike Clincher Rim [Tubeless Compatible]
    The Crocodile looks like it has reinforced nipple beds. based on price, I am going assume these reinforced nipple beds are the only difference between the Crocs and the Regular rims. 36id which is pretty close the Ibis 742 rims. Seems like the right rims. For those that have Crocs, did you order the offset spoke holes? $195 [Crocodile] [NEW DESIGNED] 42mm Width Carbon Semi-Fat MTB 27.5+ Rim Hookless Tubeless Compatible [NXT27CD42]
    Regular Nextie are 33id for $170 [NXT27AM40] [All Mountain / Enduro] 40mm Width Carbon Fiber 650B/27.5" MTB Clincher Rim Tubeless Compatible
    Asymetric at 32id $155 [Asymmetric] [NXT27WC38] [All Mountain] 38mm Width Carbon Fiber 27.5" / 650B MTB Rim Clincher Hookless Tubeless Compatible
    Thanks for any info you can provide
    I just got a set of the nextie AM35's built up by them on hope pro 4's, VERY impressed.
    If you don't have to have assym. look at their 40, with an internal of 33, should be perfect.
    Shoot Lo Maxwell a email, he gave me 20% off on the hoops.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I've been running the croc 42mm with 3" tires on my fatty all last summer, super happy with them. Light, strong, setup tubeless easy.
    Following. Interested in the Croc+ for a Maxxis DHF 2.8 tire. Maxxis says minimum ID should be 39mm
    Reputation: The Boz's Avatar
    It seems like the crocodile design provides for stiffness and spoke strength without having to resort to a deep rim depth all around, so it shaves weight while maintaining strength. But mostly I just like the way those Crocodile rims look, they are cool. If I needed a pair of i36 wheels Id be looking at these (just ordered a pair of i34 wheels from carbon speed)...
    Oct 2015
    Quote Originally Posted by laksboy View Post
    I'd take that with a grain of salt. I've been running 2.8 on 30mm internal for over a year and I'd say 35mm to 40mm is the sweet spot.
    Curmudgeon
    Reputation: shif's Avatar
    On my pre-Boost HD3 w/ Fox 36 I'm running Nextie Asymmetric Wildcat rims having 32mm inner width. Tires are Maxxis WT DHF 2.5 / DHR2 2.4 combo. The rear tires fit in the frame nicely. I'm considering the DHF 2.6 up front when a replacement tire is needed.
    Love the Nextie rims, light and stiff. No problems mounting the tires. The rims have taken countless rock strikes with zero structural damage and just very minor cosmetic blemishes.
    https://www.nextie.net/mountain-asym...-cat-NXT27WC38
    I chose the Enduro reinforcement option.
    Order them in a custom wheel build here:
    https://www.elevationwheelcompany.com/
    -SHIF
    Reputation: David R's Avatar
    I've got a set of these in the post now, looking forward to getting them!! Certainly seem like good bang-for-buck.
  1. Nextie rim for 29 plus: Jungle Fox or Crocodile?
    By KVV in forum Wheels and Tires
    Last Post: 02-21-2018, 08:03 AM
  2. Does anyone use the Nextie Crocodile 27.5+ in 42mm on their + bike
    By ArchieTolliver in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-17-2017, 07:36 PM
  3. Nextie Asymmetric Premium UD Carbon rims, 27.5+
    By MattMay in forum Classifieds
    Last Post: 05-09-2017, 04:19 PM
  4. Spam: Nextie & DT Swiss 29 Plus wheelset for sale
    By bikeny in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 02-17-2016, 11:31 AM
  5. Tire advice for the crocodile trophy (queensland australia)
    By Nothing's impossible in forum Fat bikes
    Last Post: 10-08-2015, 05:52 AM
Members who have read this thread: 82
