    Jan 2013
    Newb trying to build first wheelset. Difference between 15qr and 15maxle?
    I searched the forums but the similarity in search terms made it impossible to get any relevant results.
    I want to build my first wheelset. And I am a little unfamiliar with some things and hoping u guys might help. Is there a difference between 15qr and 15maxle? When buying hubs do all the 15mm formats use the same hubs. If it makes a difference I have a superfly 100.
    Jan 2013
    anyone? I'd like to order the hubs but i don't want to make a costly mistake. Thanks for any help.
    Reputation: 4slomo's Avatar
    My understanding is that any 15mm TA has an outside diameter of 15mm, and any difference in TAs is in the threaded end.
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    Theres only 15mm hubs. Theres no difference. All 15mm forks fit all 15mm hubs. Its a standardized hub size.
    If you have a 15mm fork, any 15mm front hub will work as they're all the same dimensions.
  1. New wheelset for a newb
    By TwntyOneTwlv in forum Beginner's Corner
    Last Post: 01-17-2013, 10:07 AM
  2. Newb needs help with DT Swiss wheelset
    By Porschefan in forum Wheels and Tires
    Last Post: 03-08-2012, 12:00 AM
  3. Help a newb out with wheelset
    By BJD83 in forum Wheels and Tires
    Last Post: 03-01-2012, 11:06 AM
  4. Replies: 0
    Last Post: 12-08-2011, 11:06 AM
  5. 15qr wheelset and 15qr fork
    By pangster in forum Where are the Best Deals?
    Last Post: 08-27-2011, 01:55 PM
