Results 1 to 5 of 5
    New Tire or New Riding Style, Technique
    Recently just got a new 29er. It is superlight, carbon and 6 lbs lighter than my last bike. I've noticed that due to the change in weight, I've not only been bounced around more by the trail but I'm also losing rear traction towards the tops of steep climbs, especially when I have to stand on the pedals, more. I'm running Schwalbe Racing Ralph 2.25's.
    Do I need a grippier rear tire, less tire pressure (running at about 35psi), better technique, none of the above or some combination of the above? I'd like to get it solved as I took a decent spill last night because I stalled out suddenly due to losing traction at the very steepest part of a climb.
    Thoughts?
    Jan 2013
    Quote Originally Posted by psuambassador View Post
    Thoughts?
    Reducing the tire pressure a bit might help. Try it, you got nothing to loose..
    Reputation: shiggy's Avatar
    Dec 1998
    Thoughts?
    35psi is high. I run the RaRa 2.25 at 22-25psi with tubes.
    mtbtires.com
    I'm thinking it's not the change in weight, but more the differences in the geometry and/or suspension of the bikes that's causing the problems. My guess is less pressure and a change in riding technique will help you stay planted on the trails.
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    I've been riding a TBc since April: Ro Ro's front and rear, tubeless @ 28 & 30 psi. Bike is sub 26lbs. There is definitely an "adjustment curve" moving to wagon wheels: cornering, flowing thru tight singletrack, throwing the bike around, and climbing. I'm still in adjustment mode. Riding my 5" travel 650b @ 29 lbs. is definitely different in all respects, with travel, bike weight, and wheel size all contributing to that in some degree or another. If it wasn't raining here so much this summer, I'd have enough saddle time to figure 4" travel 29er out more completely. Just keep riding is my game plan.
    Old enough to know better. And old enough not to care. Best age to be.
  1. Wha is this riding style?
    By jamface54 in forum General Discussion
    Last Post: 04-08-2013, 10:15 PM
  2. What is this style/technique/trick called?
    By sixstringsteve in forum General Discussion
    Last Post: 10-13-2012, 04:52 PM
  3. What's your technique for riding Off Camber?
    By wbmason55 in forum Off Camber (off topic)
    Last Post: 10-09-2012, 11:22 PM
  4. 29er Riding Technique / Skill Set????
    By bowler1 in forum 29er Bikes
    Last Post: 04-20-2012, 06:42 AM
  5. Ottawa: Riding technique class?
    By D4ng3r in forum Eastern Canada
    Last Post: 05-20-2011, 08:57 AM
