    New front tire suggestions?
    I'm going to replace my front tire soon. I've been on a Hans Dampf & would like to stick to a 2.3-2.35 with some sidewall reinforcement but a little less volume would be ok. Along with stiffer side knobs. Any suggestions?
    I'm thinking about the Michelin Wild Grip'r 2.35 but not sure if it's larger than the HD? I run the WG'r 2.25 in the rear & it shows virtually no wear after 6 months but it was easily punctured when I was running it tubeless. The 2.35 vers. is reinforced.
    I use Atomlab Pimplite rims & my local trails are mainly hardpack that turns very loose with rocky sections. I like tougher tires than my trails really need.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    trail king 2.4
    BarBanger
    I also ride trails of mixed riding conditions. My front tire of choice is the Nevegal 2.35. I also like the Bronson and the Nobby Nic.
    I forgot about this thread. I just ordered the Minion DHF 2.5 to replace the HD as it is suppose to be smaller than the HD so figured I would give it a try. I ordered a 2.25 Ardent for the rear to replace my Wild Grip'r as I'm tired of messing with tubes . Both Maxxis tires are the EXO versions.
    I'd like to try Conti's but kind of paranoid that their 2.4 would be larger than I need.
  1. Replies: 24
    Last Post: 05-19-2013, 05:10 PM
  2. Tire Suggestions (Moved to Tire/Wheel Forum)
    By chad1376 in forum Singlespeed
    Last Post: 09-17-2012, 08:37 AM
  3. Burly rear tire suggestions - light DH tire?
    By TwoHeadsBrewing in forum Wheels and Tires
    Last Post: 07-20-2012, 01:33 PM
  4. good tire size setup? new tire suggestions
    By ryin in forum Wheels and Tires
    Last Post: 03-09-2012, 04:25 PM
  5. Need tire suggestions for Snowshoe trip, any suggestions?
    By TheTwanksta in forum Downhill - Freeride
    Last Post: 09-29-2011, 11:48 AM
