Page 2 of 2 FirstFirst 12
Results 101 to 143 of 143
  1. #101
    Aug 2016
    Quote Originally Posted by Klainmeister View Post
    I do, it's actually slightly larger than the 2.4 (casing) and a little more round. Awesome for rear tire.
    Sweet thanks
  2. #102
    Quote Originally Posted by racebum View Post
    2017 version is being clearanced out. price is nutty good
    https://www.ebay.com/itm/2-QTY-Bontr...72.m2749.l2649
    really doubt these will last long @ 55pr
    for those of you who don't know random bike parts / crosslake sales is a wholesaler. they buy large lots from manufacturers.
    which makes you wonder why the hell trek sold all the 2017 tires off rather than through dealers on sale. these things move FAST
    se4 is also available here if you need a reinforced casing and i think {but am not sure} they may use a softer compound? anyone remember on the xr vs se?
    Is that 2017 version the same tire as the 2018, except for the graphics?
  3. #103
    Reputation: racebum's Avatar
    Mar 2013
    New Bontrager XR4 team issue 29 x 2.6-20180718_181828.jpgas far as i can tell, yes, same dual compound rubber and a 780-800g weight, i have 4 of them and the highest was 793g. lowest 778g. the ebay ad is wrong as they likely weighed an se tire and used the weight on both ads. 2017 is when the major change to xr4 took place and the tread redesign happened
    behaves like maxxis rubber. no idea who trek had make these but maxxis is high on my suspect list.
    rolling resistance is excellent. traction is similar to a speed grip nobby nic but requires a bit more lean angle. i really like the tire and they are not dried out. all 4 came very rubbery and fresh feeling. once ridden and allowed to fill in the measure 60mm on a 24mm id xmc1200 rim
    you get 10% off if you buy 4 so you can get a couple years worth of tire for $100. best tire deal i know of right now for a rowdy xc or good trail tire. above is an actual picture of the ebay tires
  4. #104
    I should be out riding
    Reputation: ACree's Avatar
    Sep 2004
    Quote Originally Posted by alexdi View Post
    Mine came in today. It's replacing a WTB Ranger 3.0 L/F and joining an XR4/29-2 2.35 in the back.
    Actual weight: 914g
    B2B: 160mm
    Tread, i39, 40 PSI, new: 67.2mm / 2.65"
    Casing, i39, 40 PSI, new: 67.5mm / 2.66"
    Height, unloaded, bare wheel: 29.9"
    Hey, what rims are you running in these pics? Any concerns with the XR4 being too square with wider width rims?
    If it's not powered solely by you, it's motorized.
    Worshiping at the Church of Singletrack since 1993.
  5. #105
    Nov 2017
    Actual weight: 914g
    B2B: 160mm
    The casing feels stiffer and thicker than the Ranger. On the wheel, it's about 0.25" shorter and 0.3" narrower. No problems mounting it by hand. Used a floor pump for the initial bead seat.
    EDIT: 6 hours later, it's 69.5mm casing and 68.7mm tread. Still 40 PSI.
    EDIT: Next day, at riding pressure (~16 PSI), it was 67.5mm.
    Measurements:
    Attachment 1202956
    Attachment 1202963
    Side view:
    Attachment 1202964
    Attachment 1202962
    The 29-2 2.35 actually has a 2.45" casing, that's the only reason the XR4 doesn't look even bigger. 180mm rotor on the front wheel.
    Compared to the Ranger:
    Attachment 1202957
    Attachment 1202960
    Attachment 1202959
    Lefty 1.0 clearance:
    Attachment 1202961
    If anyone's curious, this is Slime STR on the Ranger after about 4 months. Super tacky, but not actually flowing. I wonder if there's something I can add to make it liquid again, the sealant itself seems in fine shape. (EDIT: Slime says to just add water.)
    Attachment 1202958
    No riding impressions yet, it just rained over here. Maybe in a few days. First trial will probably be at 17-18 PSI.
    What are your thoughts on the tire?
    I'm thinking about getting these to replace a 2.5wt DFH up front. I would be looking at a 29x2.6 or 3.0. My rear is a Maxxis Aggressor 2.5wt and may or may not change it out to.
    Sent from my SM-G930U using Tapatalk
  6. #106
    Jun 2016
    Thank You! Got an order in today.
  7. #107
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    Quote Originally Posted by Haymarket View Post
    Yes. Confirmed with Trek on the SE4's (same tread pattern as XR4...just more burly casing). Just graphics update for 2018.
    I use the SE4's rear only on both my Hightower and Spot Mayhem. Slightly less weight than an Aggressor EXO 2.3, way better volume, and I feel like they roll slightly better than the Aggressor. So far the casing has stood up to the rough environment here in CO (Mainly Front Range & Crested Butte riding). I killed a handful of rear Aggressors over the past year and so far the SE4's have been solid (running them on Derby 30mm IW rims)
    As I have said in other threads I would have never thought about running Bontrager tires a year and a half ago, but their newer gen tires are solid. I started with the Chupas (29x3's) a little more than a year ago on my plus wheelset for my fatbike and was really impressed with those tires. Since then have swapped the front on that wheelset to a XR4 29x3 with the Chupa still in the rear and then ran a 29x2.4 XR4 front earlier in season on my Mayhem and all the tires have been rock solid.
    Good review on nsmb.com back in May on the XR4/SE4 tires ---> https://nsmb.com/articles/bontrager-...m-issue-tires/
  8. #108
    Nov 2017
    Quote Originally Posted by RiderofPA View Post
    Booo ... They don't have the 2.6 or 3
  9. #109
    Quote Originally Posted by gundrted View Post
    Bontrager tires are the best!! I always go back to them when my curiosity makes me try something different. They allowed me to have more fun and more time just riding my bike without worrying about a tire thatís going to fail on the trail.
  10. #110
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by jpfurn View Post
    For those of you not happy with the XR4 2.6 outback have you tried or considered a Rekon 2.6. I'm thinking I may try DHR 2.5 up front and Rekon 2.6 out back. If there is clearance issues I may try the Agressor.
    Sort of need to know what you didn't like about the XR4 to be able to suggest a replacement.
  11. #111
    Sep 2014
    Between the rain and work and etc...finally got enough ride time on the 2.6's to get them dialed in. Settled on 17f/19r and weigh 180 rtr. Could go a bit lower but rather not risk rim damage. So far, love em. Rollover is much better than 27x3; traction is nearly as good(different brand tires on 27x3, so not a direct comparison) they roll fast once moving but do take a little more effort to get going. They weigh a little over 100g more than the 27x3's. Cush is close and rolling resistance about the same.
    I picked up a used cassette and put some old rotors on the 27x3 wheels and can swap them out in a minute now. Gonna take the 27x3 out next time since it's been a loooong time since I've rode them and have upgraded my fork since then. I may have a set of wheels for sale soon....I dunno, depends on how the next ride goes!
    I have a set of 29x2.4 XR4's to try out too. Lighter than 2.6's, but I'm sure cush and traction will be a bit less. They're not as tall either, so rollover might be not as good.
    The 2.6's are holding up well, the rear has pinged off lots of roots and rocks w/o any damage and tread wear is minimal despite messing around doing wheelies and endos on the street.
  12. #112
    Sep 2014
    Well hell....now I'm confused. Just finished a loop on the 27x3's and at first thought I was killing it! Oddly, it seemed they climbed easier, but I guess that's due to their lighter weight and slightly different gearing being smaller. They definitely carve corners better than the 29ers, but when I hit the chunkier sections, momentum was lower, rollover obviously less, and I had a few pedal scuffs which I've had none with the 29ers. Also spun out one time on a short steep climb due to coming into it slower. It was getting dark half way through the ride and this was only the 2nd time I've ridden with lights, so that may have affected things a bit. I think I'll have to give them another shot to be fair and then the 29x2.4's go on for testing. They should be close to the same weight as the 27x3's and just a bit shorter the the 29x2.6's. Cush and traction unknown.
    Edit: The 27x3's are waaay easier to wheelie for some reason.
  13. #113
    Aug 2016
    Slightly off topic, but anyone looked or tried the new 29x2.6 SE2 tires.
    I was really wanting a 2.4 SE3 to be made for the rear. But maybe the wider 2.6 SE2 might be ok. At least in the dry.
  14. #114
    Sep 2014
    Got another ride on the 27x3's and had more pedal scuffs than last time and got hung up on some roots on a few climbs. 29ers are definitely better for me and the trails I ride.
    Gonna do the 29x2.6's again and then try the 2.4's to see which work better.
  15. #115
    Jul 2017
    Hey man, have you noticed any buzzing in the front tire with the mud flap? The clearance there is tight! I'm about to buy some XR4 for my FEX9 but not sure if I should go 2.4 or 2.6
  16. #116
    Oct 2017
    I can tell you that on my 2017 Fuel EX 9.8, I do get some buzzing from mud on my XR 4ís on the front fender, at least a little bit. Itís not usually an issue, but it has happened.
  17. #117
    Sep 2014
    I took it off, don't ride in mud anyway. Plus it was really tight.
  18. #118
    Jul 2017
    Quote Originally Posted by not2shabby View Post
    so you what are you riding now?
  19. #119
    Sep 2014
    I rode the 27x3's last few rides but put the 29x2.6 back on. Rollover for the win. I will probably try some 2.4's out next.
  20. #120
    Quote Originally Posted by MSH View Post
    I would echo this for rough Idaho backcountry - lots of slate, chipped granite and general loose detritus. The 29x2.4 SE4 TE rolls nicely, with decent climbing/braking and quite good cornering.
    And it is really tough for this weight - I smash things regularly on the SB55, but don't like 1100 draggy grams in the rear. Similar ride to a Nobby Nic, though I murdered 3 of those by slicing tread and sidewalls... so much for light & fast from Schwalbe. I may try an XR4 out back (under 800 grams), but would feel like I'm rolling the dice...
    I would not use the 29x2.4 4 series up front - that is reserved for a 2.5 DHF or 2.4 DHRII and ass-saving in fast corners. Would love to see a 29x2.4 or 2.5 XR5 under 1000 grams
  21. #121
    Reputation: OwenM's Avatar
    Oct 2012
    I know pics can be deceiving, but the 2.4" actually looks more rounded than the 2.6" in the ones posted here. To me, the side knobs also look more prominent on the 2.6"(which I'd prefer on the front), but it's hard to tell whether that's reality or just perspective due to the angle of the pics.
    Any comments on that?
    May be totally off base, but here's what I'm talking about:
    I have used the 2.4" on i29, and am probably going to mount it back up this week. Even with it, I've thought a wider rim would be a better match for the sake of sidewall support, though(if I settle on this for the front and buy a carbon wheelset, it's probably getting i34).
    I've been screwing around with different tires for awhile now, and am thinking the XR4 may be my most livable compromise for general use. Would kinda like to try a 2.6" on i29 up front, just to see, but want to make things better, not worse!
  22. #122
    Mar 2013
    It's definitely not a square tire and isn't designed to function as one. I mean you could put it on a wide enough wheel to make it square but then you increase the rolling resistance and at that point you may as well go minion /aggressor. For a rounded Tire I feel the traction is pretty good and more importantly predictable. The tire lets you know what it's doing and it rolls really well. Nobby Nic speedgrip is definitely in the same class but then you have that gaudy looking blue line down the tire. There are some rounded tires I have ridden that are downright terrible but this is certainly not one of them. At least not until it wears down. once those knobs start to heat cycle and wear down the tire gets downright sketchy. I know the latest trend is to go wider and wider but if you guys actually time yourself through various courses you might find that wider and bigger is not always faster.
  23. #123
    WNC Native
    Reputation: nitrousjunky's Avatar
    SO are you saying the SE3 29x2.3 has a larger casing/more volume than the SE4 29x2.4 tire?
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  24. #124
    Reputation: Curveball's Avatar
    Aug 2015
    Quote Originally Posted by mikesee View Post
    DHF is sketchy on anything wet. No siping means it skates sideways as fast as forwards.
    The XR-4 is no mud tire by any stretch -- it's just more predictable in the wet than the DHF.
    Having my DHF suddenly let go on me one too many times, I'm considering the SE4. I ride in the PacNW and so wet performance is important.
    Riding Washington State singletrack since 1986
  25. #125
    Mar 2013
    How new the tire is makes a big difference in wet conditions. The xr4 uses 61/50 rubber which is the same as a maxxis dc. Maxx terra is softer and better in the wet but really. Flexibility diminishes with age pretty quickly. The best Oregon Washington wet weather combo I have actually found is Magic Mary and hans in the back. The dhf works you just want to be replacing them every two years at the very most. Yearly would be better. Also if you run them on a wide rim like a lot of people it Squares Off the tread which reduces the off-camber grip. Break aways become more of an on/off unless you run really low pressure which has its own set of drawbacks
  26. #126
    Nov 2015
    If riding in the wet a lot, get a Shorty. XR4/SE4 is not exactly known for wet performance
  27. #127
    WNC Native
    Quote Originally Posted by Curveball View Post
    If you haven't seen the NSMB review on the Bonty tires, it might be worth reading - https://nsmb.com/articles/bontrager-...m-issue-tires/
  28. #128
    Aug 2015
    Quote Originally Posted by nitrousjunky View Post
    Thanks for the link. That's my terrain.
    From their review, it sounds like the XR/SE4 isn't ideally suited as a front for my area.
    I had a Butcher on my last bike that worked pretty well, but would seep sealant at an alarming rate. I'd still consider that one for a front tire in grid casing and 2.6. Maybe then an XR4 on the back.
    I'd need wider rims than my current 25 mm, but all this is getting to be quite expensive. There would have to be a significant advantage to using 2.6 tires to justify the cost. Maybe it's worth it.
  29. #129
    Aug 2015
    Actually, my front tire washouts have occurred in very dry trail conditions. It does get quite dry here in late summer.
    I've heard a lot of great reviews on the Magic Mary for this area.
  30. #130
    Mar 2013
    Magic Mary is wonderful when it gets wet up here. If you're riding dry or especially the East part of the state where it gets really dry. Soft rubber is about the only thing you can do. The dhf in Max Terra is my general go to if I'm riding the eastern part of Oregon or Washington. That ball bearing dirt that builds up on the side of the trails sucks. You just need a soft compound. Magic Mary may or may not work depending on your riding style in those conditions because the knobs are so tall they get flexible and squirmy
  31. #131
    WNC Native
    Yeah it sounds like he prefers the SE5 that he's testing better on the front.
    FYI- I have a buddy who ran the Butcher 2.6 Grid tire. He loved the tire and didn't have any sealant weeping issues. However after plenty of tubeless miles it had only made it to 2.5" on an i36 rim. That said it grew quite a bit in overall diameter and ended up around 29.6-29.75".
  32. #132
    Other than buying from Trek online store or Trek dealer, any other means to get Bonti tires (on sale?). Looking at the 2.6 size, so I'm guessing they are hard to come by other than from Trek themselves.
  33. #133
    Nov 2017
    @mikesee on this forum sells just about everything including Bontrager. I've bought from him in the past. Great service and very fast shipping.
  34. #134
    Reputation: Overkill's Avatar
    Quote Originally Posted by smoothmoose View Post
    I'm having a hard time finding these on sale too. The 2.4 sizes seem to be available at good prices but not the 2.6s. Anyone know what mikesee sells them for? or is this something that needs to be taken off-line?
  35. #135
    Mar 2018
    Quote Originally Posted by OwenM View Post
    Hi, i've also a trek fuel ex 8 with 29i rims... and previously have Xr4 2.4.... the side knobs were really pointing out requiring crazy lean angles to full engage them... watching the pictures(2.4 vs 2.6) assuming both were on 29i rims... i also noticed that the profile of the 2.6 seems better, with side knobs more vertical and engaging them with less lean angle... anybody can confirm??? thanks!!
  36. #136
    Mar 2018
    Horses for courses and all that. DHF is awesome in dry conditions, but pretty sketchy on wet roots/rocks. DHF was my go-to for a ~decade, but there are so many better tires now. I'd take the XR-4 2.6" every day of the week over a DHF 2.5" nowadays.
    miksee... really interesting... are you comparing the Xr4 2.6 vs a DHF 2.5 wt ??
    Are you prefering the xr4 only for the better wet roots/rocks control, or do you consider a XR4 2.6 a better overall front trail tire? Maybe because Xr4 has some intermediate knobs and has not the open channel(vague zone) that the DHF has? In some normal trails you can't always lean the bike that much as in a bike park, and so maybe an Xr4 2.6 could be a better choice?
  37. #137
    Nov 2017
    Quote Originally Posted by zambo78 View Post
    I've ridden the DHF 2.5wt for a long time and never liked it because of the 'dead spot'. If you are not riding full lilt or like a DB on moderate trails, there are much better options out there.
    I went from a DHF 29x2.5wt to an XR2 29x3 and love it. I will be trying the XR4 when my 2 wears down.
  38. #138
    Aug 2003
    Yes.
  39. #139
    Mar 2018
    Hi, thanks for your advice... maybe the XR2 3.0 could be great in front but i'm on 29i rims and i prefer to stay in the 2.4/2.6 range...
    As you and mikesee confirmed, when riding in some "normal" trails with medium skills, it's not possibile take corners at the highest speed or at the correct speed every time... so a 2.6 tyre with a sort of intermediate knobs like the xr4, can be a good choice that maybe has less maximum grip at edge like a DHF, but better grip in the "intermediate zone".
    Many many people with all kind of skills or terrain simply put a dhf only because it's know to be one of the top front tires.. but sometimes there is a lot more to consider...
  40. #140
    Reputation: Klainmeister's Avatar
    Yes. The XR3 2.3 and XR2 2.35 are both larger than the XR4 2.4 when on an i24, i27, and i30 rim (me and the wife have a lot of bikes...haha).
  41. #141
    Jun 2016
    Finally blew out my rear Onza so I am threw my front Onza on the rear and the 2017 XR4 on the front. That was the easiest new tire install I have ever had. A little bit of soapy water and a floor pump, 30 seconds later I have a 40 PSI inflated tire stretching!
  42. #142
    Mar 2018
    Regarding what already sayd by OwenM, this is what we see from the pictures...
    Different angle at where the side knobs works... 2.6 and 2.4 on the same 30mm rim...
    This is strange because keeping the same rim, and use a wider tire, should do the opposite to the side knobs... these 2.6 instead seems to have really another carcass design and/or a different knobs placement or different cutted/shaped side knobs
  43. #143
    Reputation: sethd513's Avatar
    Jun 2016
    The 2.6 se/xr5 is much larger then the 2.3 se/xr5 and also the 2.4 se/xr4
  1. Bontrager Tires - XR4 Expert vs XR4 Team Issue
    By V8Interceptor in forum Trek
    Last Post: 02-18-2015, 04:12 AM
  2. Bontrager xr4's team issue....
    By stangbang in forum Wheels and Tires
    Last Post: 11-13-2014, 09:58 PM
  3. Hans Dampf or Bontrager xr4 team issue?
    By angelo in forum Wheels and Tires
    Last Post: 10-29-2014, 01:41 PM
  4. Bontrager XR4 Comp vs. XR4 Team Issue vs. ???
    By bluntrager in forum Wheels and Tires
    Last Post: 10-01-2013, 06:02 AM
  5. Replies: 8
    Last Post: 08-11-2013, 03:42 PM
Members who have read this thread: 501
