Results 1 to 10 of 10
    Two wheels are best
    Reputation: DM-SC's Avatar
    Nevegal 2.1 vs NBX 2.1 vs ?
    The places I ride around central SC have varying surfaces including hardpack, sand, loose small rocks, clay, and plain ol' dirt/mud. If you know Tsali, then you know about what I mostly ride.
    I'm currently riding Velociraptors and though I like the traction (Ok, so the rear can skid a bit at times), I'm looking for something better. I switched from some smaller tires (Fire XC 1.8, Comp S) this year and really like the larger tires.
    I'm thinking Nevegal or NBX in 2.1's but am having a hard time picking one or the other. Does anyone have a recommendation? Is there another option?
    Never be afraid to try something new.
    Remember amateurs built the Ark.
    Professionals built the Titanic.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by DM-SC
    I think you would like either one though be aware that the Neve 2.10 is slightly larger than the NBX 2.3.
    mtbtires.com
    Two wheels are best
    Quote Originally Posted by shiggy©®™
    Based on your comment and the tire spec info on your web site, I'm guessing that the MBX isn't really a "High Volume" tire?
    Dec 1998
    I would consider the NBX 2.3 a "high volume" XC/trail tire.
    mtbtires.com
    Just passing through....
    Reputation: DaFireMedic's Avatar
    Look at the Kenda Karma DTC's. High volume and relatively low weight.
    If you want to play with electricity, more power to ya......
    Two wheels are best
    How would a Schwalbe Albert 2.25 compare to the Nevegal 2.1?
    Dec 1998
    In what regard?
    mtbtires.com
    Two wheels are best
    In what regard?
    Size, traction, rolling resistance. Basically, I'm wondering if the Albert would be as able to handle my riding conditions as the Nevegal or NBX?
    Dec 1998
    Size: About the same as the Schwalbe Big Jim 2.25
    Traction: Better drive than the Neve, about the same as the NBX. Braking all about the same. Cornering; the Albert slides a bit sooner than the others though very controllable and it does not slide on the front wheel. Very good on roots, rocks, soft and hardpack (as are the others).
    RR: Better than the Neve. About the same as the NBX.
    (Based on the Little Albert 2.0 and Fat Albert 2.35)
    You should look at the Pana racer Cinder 2.25, too. Awesome tire
    mtbtires.com
    Two wheels are best
    Thanks for the info.
    I really wish I could afford to buy a set of each and test them out. Tires are as bad as saddles...it can cost a lot to experiment!
  1. Insight on NBX 2.2 lite vs RR 2.1 or 2.25
    By TomFL in forum Weight Weenies
    Last Post: 06-09-2004, 11:45 PM
  2. Nokian NBX 2.1 vs. the Lite versions?
    By RC JonB in forum Weight Weenies
    Last Post: 05-30-2004, 11:10 PM
  3. Dual Post - Weight of Kenda BG 2.1 and Nvgl 2.1 tires
    By boboso in forum Wheels and Tires
    Last Post: 05-28-2004, 12:37 PM
  4. Nokian NBX 2.1 measurements: Does anyone know...?
    By AZ-X in forum Weight Weenies
    Last Post: 05-25-2004, 04:28 AM
  5. Albert / NBX 2.1 Combo
    By MTBDad in forum Wheels and Tires
    Last Post: 04-01-2004, 08:52 PM
