Need a rim recommendation for SS
Hi,
I have an older frame that I've converted (in process of) making a SS. The rear rim needs replacing so I'm looking for some recommendations for a strong rear rim that is a rim brake. To give an idea of what I normally ride...I run Stan's Flows on my other bike. I'm pretty rough on wheels (220lbs) but the flows have held up great.
Any recommendations greatly appreciated - obviously with the age of the bike I don't want to spend $300 for a rim so cost is a factor.
Assuming it's a 26" bike, Mavic X719 is very strong while still be fairly light. It's not cheap at $85 a rim but not terrible.
Of course on the cheap, the Sun Rhyno Lite is cheap and durable, but a little heavy for a single speed.
I would think the WTB Dual Duty are strong, I always had good luck with WTB. Whatever you go with, I would try to see rim cross section diagram before purchasing.
I was looking at the x719 as I've mostly ridden mavics in the past (before the Stan's)
What are you looking for/at in the cross section?
WTB i23 frequency 29r rim.
Thanks, that looks like a disc only rim...actually I looked at WTB's site and it looks like all their rims are disc.
Seconding the X719 - excellent rim that can build into a very solid wheel.
I'll probably go with the 719.
Is the Mavic x719 easy to build? I've recently taken up that art and have been told some rims are harder to build than others - which I assume means being able to true.
Mavic rims have always been some of the easiest rims to build IME. Lace up true, round, and even tension.
- You may not post replies
- You may not edit your posts
Forum Rules
