Results 1 to 12 of 12
    Apr 2014
    Need input on spokes for new wheel build
    Going to have a new wheelset built for my bronson. Planning on getting hope pro 4 hubs with dt xm481 rims. Where I donít need help is spoke count 28 vs 32, and double butted vs strait gauge spokes. I am 165 lbs with gear and generally ride a mix of trails, very little bikepark and not much airtime. I do enjoy ripping down the hill and hard cornering.
    Reputation: Nubster's Avatar
    Never had a single problem rolling on DT Swiss double butted competition spokes with brass nips.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Norco Torrent HT 7.1
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    No good reason to use straight gauge spokes, but on aluminum rims more spokes might be beneficial in keeping the wheel from feeling too flexy.
    West Chester, PA
    Sapim race or dt comp
    eri
    eri is offline
    Reputation: eri's Avatar
    Sep 2012
    Good thread here:
    How much do rim and hub stiffness matter?
    In my opinion: Weight gain going to 32 is totally worth it, get spokes butted as narrow as you can build (revolutions are too twisty). Brass nipples are traditionally the most durable, thinking corrosion in the wet - I've been riding for decades and rim always gives out before my alloy nipples.
    My last wheel was lightbicycle, Sapim race and their long alloy nipples, wheel has been great. Use a tensiometer!
    the truth is always a gift because it offers the recipient of that information the chance to change the outcome - Grace Choi
    Dec 2014
    You'd be crazy not to go with 32 spokes in my opinion. Sapim Race, DT Competition, and Wheelsmith DB14 are all great options for double butted spokes which I would use. Those rims come with DT's aluminum squorx spokes and washers so you might as well use them but make sure that they are built with anti-seize and all the usual caveats about aluminum nipples apply.
    mtbpete
    Reputation: changingleaf's Avatar
    Sapim Race 2.0/1.8/2.0 spokes or DT Swiss competition spokes are a great choice. 28 hole rims will save you about 50g in spokes. With the xm481 rims the durability will be fine at your weight, but 32 hole rims will always give you more room for error.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by fdes View Post
    Which tires you'll run, and at what pressures, will help you to narrow this down yet further.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Double butted for sure... as other have said, no reason not to go with them. Can always step up a little and go with DT Swiss Comp RACE spokes (yes different than Comp), if I remember correctly they are 2.0/1.6/2.0 instead of 2.0/1.8/2.0. Been riding them for a while now (at 190+ riding weight) and have had zero problems.
    Apr 2014
    Thanks all, looks like 32 spokes, DT comp or comp race spokes is what I need.
    Apr 2014
    Quote Originally Posted by mikesee View Post
    Planning on running DHF front, Aggressor rear. Usually run 21 psi front, 23 psi rear.
    Wheelsmith spokes beat DT on price and weight right now. Quality and durability are the same.
  1. How do i know the lenght of the spokes i need to build a wheel?
    By Merida OneFiveO880 in forum All Mountain
    Last Post: 05-03-2014, 11:18 AM
  2. Replies: 10
    Last Post: 06-01-2013, 06:09 AM
  3. Replies: 9
    Last Post: 05-17-2013, 12:00 AM
  4. Replies: 0
    Last Post: 11-24-2012, 08:13 PM
  5. Replies: 2
    Last Post: 03-11-2011, 10:45 PM
Members who have read this thread: 45
