    NBX 2.1 Rear, ??? in front?
    Looking for suggestions - I am currently running blue grooves 2.35/ 2.1 Fr/ R. This is a great set up, but I am looking for something a little faster.. I have the NBX 2.1, which I think should work well as a rear with a slightly larger front tire. I greatly prefer sticky rubber tires, esp for the front, which eliminates some good tires like the weirwolf.
    My current thought is to use the Blue groove 2.1 in front, or the nbx 2.3. I also may use the Kinetic 2.3 because I have it already..
    Your thoughts and suggestions, please.
    I am running the NBX 2.1 F/R. Its a good rear tire but not enough volume in front for me. Ordered a Schwalbe Big Jim 2.25, if it ever gets here I'll let you know how it rides.
    Quote Originally Posted by icenoir
    Kinetic 2.35 shouldn't compare to either the Blue Groove or NBX for rolling speed. From the above I assume you own a BG 2.1, BG 2.35, Kinetics 2.35, NBX 2.1 right?
    I'd mount the NBX 2.1 on the rear (it might wear a bit better than the sticky BG), keeping the BG 2.35 on the front and give that a try, then mount the BG 2.1 on the front and go again, see how the grip and speed feel/compare. Because the BG 2.1 is a bit bigger volume than the NBX 2.1 (and the BG corners/tracks pretty well) they might match well F/R. I'm actually thinking of trying that same combo, but I don't own any of those tires/sizes yet (so I have to fork out the dough to try them out). I'd be interested to hear your feedback...
    FWIW I'm using a Wierwolf 2.5 race front and it rolls pretty fast (for a big tire), and hooks up well in loose stuff, not a bad option.
    thats what my thoughts were
    That was my plan, although I may put the BG 2.1 if front right away.. You are correct that I own the tires you listed.
    Quote Originally Posted by fsrxc
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. 29er front, 26er rear?
    By sean350 in forum 29er Bikes
    Last Post: 09-06-2004, 01:10 AM
  3. Nokian NBX 2.1 measurements: Does anyone know...?
    By AZ-X in forum Weight Weenies
    Last Post: 05-25-2004, 04:28 AM
  4. Weight balancing front to rear?
    By keen in forum Weight Weenies
    Last Post: 04-25-2004, 09:00 PM
  5. Racing Ralph on front for racing, 2.1 or 2.25?
    By vtwin996 in forum Wheels and Tires
    Last Post: 03-24-2004, 10:32 AM
