Results 1 to 11 of 11
    Mar 2013
    Is my tire pressure too low? Quick question
    After sections of pavement, I can see that the dust is cleared off on the shoulder knobs of my rear tire, but only the center knobs of my front tire.
    I'm running about 3-4psi more in the rear as it is. Seems like it would throw things off to create even more of a gap?
    This happens with every tire combo I've tried and it just occurred to me that it might be wrong.
    Slower But Faster
    Reputation: BrentD's Avatar
    Remember though that off road the centre knobs will dig in (unless it's rock or super hardpack dirt) allowing the side knobs to also bite. Your pressure difference front to rear sounds about right.
    Mar 2013
    Quote Originally Posted by BrentD View Post
    But is the fact that I'm riding around on my shoulder lugs (as evidenced by the dust wearing off on them), at least in the rear, bad?
    Sweater
    Reputation: Buzzaro's Avatar
    Quote Originally Posted by Alias530 View Post
    I would think you'd get better braking and climbing traction that way. If you're not getting rim strikes and it's not squirmy feeling I'd say that's a good pressure. What's your weight and what pressures are you running? I'm about 230 and I run 30f/35r and that seems to work pretty well for me. It's probably a little higher than what I could get away with but the reliability and solid feel makes it right for me.
    All out of S**** and down to my last F***
    Mar 2013
    Quote Originally Posted by Buzzaro View Post
    235-240lbs and 25f/28r on a 24mm internal width rim, 29x2.3 tires
    Nov 2012
    just saw this a few days ago, gave me 27f, 35r at 190lbs... 2.25f/2.10r going to try it tomorrow, was just running 30/30.
    Art's Cyclery Blog Give ?Em a Squeeze: How to Find the Perfect Tire Pressure for Your Bike
    at your weight I'd guess more pressure...
    My bike MCA kinda climbs like a billy-goat. WOO WOO!
    Mar 2013
    Add 3 psi per 10lbs you are over the starting range? I usually don't get below 230lbs so even adding 3psi per 10lbs from the upper end of that range gives meat LEAST 40psi in the front, even after subtracting 3psi for my front and subtracting 5psi for tubeless. That sounds way too damn high.
    Sweater
    Personally I think you're a little low. 40 however, i also think is too high. There's another calculator I remember using that put me at 35 or so. Maybe it was competitive cyclist? I ride the same areas you do (auburn and vicinity) and am a similar weight. At the pressures you're running, the tires felt squirmy and would occasionally burp. At 30 & 35 they feel good and I don't burp or ding very often. If you're not experiencing those things at lower pressures, then run what you've been running. Even experiment with it on a few rides, try higher pressures or lower pressures. Keep in mind though, you run the risk of more damage at lower pressure.
    Mar 2013
    I'm happy with my performance, just wondering if I'm dragging more of an anchor than I need to up the hills if my shoulder lugs are in full contact the whole time.
    How big of hits/drops/jumps do you take in the area? I don't think I ever get more than like a foot off the ground, still adjusting to flat pedals (I recently switched) and feel like I'm gonna fly off the pedals lol
    Sweater
    I don't hit any big gaps but I'll do 2-3' drops and I generally ride fairly aggressively. Not keeping up with the local expert/pro riders or anything, but their sweat won't be dry at the bottom of confluence either.
    But you know, give different pressure a try and see what you like or dislike about it.
    Nov 2012
    experiment with different pressures, if you think it's low, add a few psi and see how it goes.
  1. Question on tire pressure for my GF
    By Sleevem1 in forum Women's Lounge
    Last Post: 05-18-2014, 06:32 AM
  2. tire pressure question
    By fuzygrub in forum Clydesdales/Tall Riders
    Last Post: 08-29-2013, 04:17 PM
  3. Pressure /tire type question
    By drjay9051 in forum Wheels and Tires
    Last Post: 12-14-2012, 09:09 AM
  4. Quick Question About Tire Pressure
    By DieTheVillain in forum Clydesdales/Tall Riders
    Last Post: 01-06-2012, 11:58 PM
  5. Tubeless tire pressure question
    By RBowles in forum Beginner's Corner
    Last Post: 01-19-2011, 02:10 PM
