Results 1 to 5 of 5
    Are my Tioga Factory XC 1.95's really that bad?
    Newbie MTBr here. I replaced my first tube today, after getting a puncture off some thorn brush about 1/4" long. Replaced the rear tube, and went off for a ride, avoiding the area where I thought I picked up the thorns.
    Coming back, both my tubes are punctured (same type of thorn), and it seems like the tires really shouldn't be this bad. Of course I am new to all this and don't really know what to expect.
    Have any advice for me? Do I put some sealant in the tires? Do I change the tires? (Currently on Alex Y2000 rims) Get a thorn resistant tube? Does that add too much weight?
    Thanks for any help you can provide!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by jumpmonger23
    1/4" thorns are going to puncture almost any tire. If you must ride in thorn areas use sealant (like Slime) in your tubes.
    When you get a flat you need to check your tires for thorns and remove them before replacing the tubes. Your flats in the 2nd ride may have been caused by thorns from your first ride.
    mtbtires.com
    Young, Shawn Young
    Reputation: Redmon's Avatar
    Thorn resistent tubes or heavy duty tubes are pretty damn heavy. Try some slime tubes instead.(they are easier to carry as a spare as well). I have the Factory DH 2.3 on the front of one of my bikes and have been very impressed with the durability/rideability.
    "Im just going to explore a little bit..."
    Dont make me be the bad guy...
    Do I need a pass to ride this trail?
    Thanks for the help guys. What's the general opinion on things such as Spin Skins?
    kneecap
    Spin skins suck big time! I tried a pair couple of seasons back, couldn't get them aligned in the tire, which in turn made the tire wobble, & the tire casing became really stiff when inflated. You could really tell they were in there. Spend your $ elsewhere. When dealing w/ thorns, I've had very good luck with the "Stans" setup.
  1. Local DH'r kicks ass in the XC at Sea Otter
    By Slayer77 in forum Downhill - Freeride
    Last Post: 04-26-2004, 12:56 PM
  2. Sea Otter XC update--Mark Weir
    By Slayer77 in forum Passion
    Last Post: 04-26-2004, 12:54 PM
  3. Agressive XC bike help
    By DJGsnax in forum Bike and Frame discussion
    Last Post: 03-03-2004, 10:04 PM
  4. Replies: 4
    Last Post: 02-02-2004, 02:01 PM
