Results 1 to 5 of 5
    Reputation: Burt4x4's Avatar
    Feb 2013
    Are My Spokes Too Long
    Howdy ~ It just doesn't "feel" right so here I go, I'll keep it short as I can...
    Laceing 32h 3X 29"
    Disk Side = 290
    Drive Side = 292
    Turn ALL nipps thight just to the end of the spoke threads
    Turn ALLL nipps tight 3 turns still loose so ALL nipps 3 more turns
    Ok getting a bit of tension but still loose so ALL nips 2 turns tight
    So 8 turns in now
    Alright now I got some tension, lets spin it, OH but WAIT..look at my DISH
    About 1/2 the rim distance towards the Drive Side
    Looking at the spoke ends they are ALL at about the bottom of the slot on top of every nipp.
    OK turn Disk side 2 x tight better but need more towards Disk Side
    Turn Disk side tight 1 x and turn Drive side loose 1x
    OK good dish now with a slight wave so I work the majic and make the wheel spin true, BUTT >>
    Looking at the spoke ends my Disk side it WAY at the TOP of the nipps and the Drive side is BELOW the bottom of the nip's slot arrrgggg
    ^^that is too much difference right?
    Feel like I wnat to buy 16 288s and get rid of thoes 290s?
    When you first start to achive tension shouldn't dish be ALOT closer than what I have to start with?
    I did this twice,t he first time I saw the spoke ends at the very top of the nipps I loosed it all up back to the start at the bottom of the threads...
    Second tension attempt gave me same results
    Is my Disk side spoke too long?
    Thanks For reading and replying
    Burt
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    Feb 2013
    Screwit, I'm gonna order the 288s and see if my dish is more better at the start. All the reading tells me I'm on the right path and if I can start with the disk side over or shorter at the start I feel my dish will be much much closer with minimal "streching" one way or the other..
    Happy Friday :-p
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    if the long ones need to be shorter and the short ones need to be longer it sounds like you swapped the spoke lengths left-to-right.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by Burt4x4 View Post
    If the spokes are correctly sized then the dish should be pretty close when the nipples are evenly threaded on either side. I agree with Meltingfeather, maybe you have them reversed? It's OK if the spokes are all the way to the top of the nipple when tensioned, even slightly beyond is sometimes alright.
    Feb 2013
    OK thanks
    I double checked and I did it right, my first thought..oh crap I gottum backwards..nope.
    I think what is was the Disk side came up with the number 289.1 and I did 290 and should have when't down to 288, then my dish would have been way closer..from what I have been reading anyway.
    Hub is Front disk
    left flange 58 right 45
    left flage to center 22.25
    right flnage to center 34.25
    32h 3X
    ERD 599
    I just tore it appart again...3rd times a charm :-)
  1. Replies: 1
    Last Post: 06-12-2014, 04:02 PM
  2. Replies: 9
    Last Post: 04-10-2013, 08:35 AM
  3. Replies: 6
    Last Post: 10-04-2012, 12:54 PM
  4. Titanium spokes vs stainess steel spokes
    By ayjay69 in forum Weight Weenies
    Last Post: 02-11-2012, 08:26 PM
  5. Need help/advice on long long long rides
    By OSOK in forum Passion
    Last Post: 08-14-2011, 10:41 AM
