    Looking for Adventure
    Reputation: Ricksom's Avatar
    Mounting Direction of Kenda Nevegal in Rear
    Tires say direction should be the same for the front and rear. However, I wonder if this is ideal for the rear. Wouldn't the climbing traction be better with the tire reversed, the sharp side of the centre blocks biting into the ground rather than the sloped side of the centre blocks?
    Perhaps the sloped side biting in would be better for shedding mud...
    What's your experience? I have the new Tomac series 2.1 Stick E.
    Reputation: shiggy's Avatar
    Dec 1998
    When reversed the braking suffers. I prefer better braking.
    mtbtires.com
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    You've both got the reasoning backwards I think??? but Shig is still correct when he says to run it the same way as the front.
    The sharp edges of the knobs DO contact the dirt first if you mount it forward. So reversing it would increase braking but decrease forward traction.
    JMH
    JMH
    Quote Originally Posted by shiggy
    Dec 1998
    Quote Originally Posted by JMH
    JMH
    JMH
    Sorry, no. You have it wrong.
    Rotation is to the right/down
    The leading edge of the center blocks are ramped. Square edge is in the braking direction.
    mtbtires.com
