Results 1 to 12 of 12
    Reputation: eric_syd's Avatar
    Maxxlite 310 tubeless: experiences ?
    I just bought a pair of Maxxis Maxxlite 310 for my 12 year old daughter. I would like to go ghetto tubeless to lower weight and go low pressure. Does anybody have experience with these tyres tubeless? With such a low weight (310g), can the sidewalls hold well given that my daughter is less than 50kg (110lbs) ?
    Reputation: bholwell's Avatar
    Oct 2007
    Geoff Kabush runs the 310 and the lighter 285 tubeless using sealant, and he weighs a bit more than your daughter.
    I have to ask, though, why Maxxlite 310's for your 12 year old daughter? Many pros have trouble cornering on a tire with such minimalistic tread. Have you looked at the Larsen TT's?
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Reputation: kevbikemad's Avatar
    i think can remember reading that 310 and 330 both have very weak beads and some have had them blow off the rims. not something i would want anyone's daughter to go through.
    i did use a 330 converted for a couple of races but the performance was not great.
    your daughter is light, she can probably run very low pressure with tubes, most gals don't rid that rough either.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Very light, very fast and works well tubeless. They make zero noise on pavement and roll just like a road slick. Is your daughter an excellent rider? Bike handling skills are absolutely required, with this super-fast tire. All this speed and such comes at a steep price...utter lack of cornering ability and no off-camber grip whatsoever. Why don't you try riding on them FIRST before subjecting your poor girl on these racer-only tires?
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Thanks for all this info
    It is most helpful to know that they will most probably not blow off the rim without agressive riding.
    Now Why ? Because they are....
    Quote Originally Posted by Zachariah
    So with these tyres it will be easier for her to keep up with me in the climbs so we can ride together which is cool ?
    No but she knows it and she does not take risks and we ride on easy trails for now.
    Because I am a clyde and they would not last very long.....Anyway I have bought them cheap off eBay and I'll give it a try while we still ride on easy trails (my daughter begins MTB) and I'll change for more aggressive tyres when she progresses.
    I would have to say you need to put FAR more thought into this.
    She's really not going to want to ride much once YOUR choice of tire has dumped her onto the ground (let's hope nothing got broken). At that age she will never keep up with you and you need simply to have ride days just to spend some time with her, not where she feels the need to go as fast as you do. Better to have a daughter who is stable and has years worth of interest in the sport than to put her at risk like you are.
    Although your intentions are good- the reason you got your daughter a tire made for advanced/pro riders will quickly show, once she under-estimates the capabilities of this tire. I know I took many a fall, before learning the Maxxis 310 is a straight-ahead-only tire. She will definitely like the lack of rolling resistance, but this tire also performs poorly in mud, deep sand and is very sketchy on rocky surfaces. She would most likely fare much better with 2.0 Maxxis Larsen TTs as bholwell suggested. The 310 Maxxlite has a painful "learning curve" in my honest opinion.
    oups..
    I missed some Karma L3R for 1/2 the price..... too bad.
    Quote Originally Posted by eric_syd
    That's okay, use it as a rear tire only and maybe some other low rolling resistance tire on the front, like Maxxis High Roller or Kenda Small Block 8. A kid washing-out on a trail is NOT a fun or learning experience and is a 100% preventable occurrence.
    Will do that.
    Aug 2014
    maxxis maxxlite 310 is it much better than maxxis detonator 26x1.5?
    maxxlite 26x1.9 is at 310grams each tire, for the maxxis detonator 26x1.5 550grams each tire
    I do xc road, flats and climbs, and some light trails off road.. maxxlite for the win?
    Reputation: raganwald's Avatar
    Quote Originally Posted by Forcemajeure View Post
    Not necessarily. People take it as a given that lighter is better, and especially for rotating mass: Reducing mass around the rim of the wheel doesn't just reduce the weight of the bike, it makes the bike quicker to accelerate, and more so than reducing the same amount of weight elsewhere on the bike.
    But all that being said... When are the times you are most likely to need to accelerate? Coming out of corners, for one. You slow down, take the corner, then accelerate on the way out (from a physics perspective, cornering itself is acceleration even if you maintain the same speed).
    However... If the tire doesn't corner well, you need to slow down a lot more to take the corner than if the tire has good grip for your trail conditions. It may be too much to switch to a Fatbike, but within reason, the tire that corners better is faster and requires less energy to ride than the tire that accelerates better.
    So... I'd say that if you aren't doing a lot of tight switchbacks and cornering, you won't get as much of a benefit from the lighter weight. And if you are doing a lot of cornering, you will lose on the lack of traction.
    Conclusion:
    Mount the 310s for certain specialized "marathon" race applications, but for everyday use pick a tire with a better balance of grip, durability, and weight.
