Results 1 to 11 of 11
    Maxxis Monorail 2.1 UST
    Any one used the new Maxxis Mono's and if so your opinion please, the Lbs just got them but they are pricey. Nothing under reviews yet so any info will help alot.Cheers
    Reputation: pagey's Avatar
    I absolutely love them.
    I went from Ignitor on the front & crossmark on the rear to Monorails all round.
    The monorails roll extremly well on my local trails which are a mix of hardpack and loose over hard. They are very deceptive and hook up suprisingly well in corners.
    You won't be sorry - Get into them
    cheers
    Pagey
    sstill in to monorails?
    Still like the monorail´s pagey? how´s the wear on them?
    Still loving them. I only swap them out for my Medusas when its muddy.
    I've done about 450kms and there is still life in them yet.
    cheers
    Pagey
    Cool Pagey
    Quote Originally Posted by pagey
    if you don't mind me asking, what psi do you run? how much do you weigh?, just to have a baseline, i ordered a set that should arrive this week... how's the grip in loose soil?
    I weigh 163lbs and run 30psi front and rear.
    They grip suprisingly well in loose over hard. Be aware they drift and just when you think OH S&$T! they grab on.
    cheers
    Pagey
    Cool 30psi it is..
    What do you mean by drift, i thought you said they were like being on rails!!! ha, LOL
    Do they drift toooo much, or just a slight pull?
    They drift in very loose sandy soil. It is predictable and it is only recently, so that may be an indicator of wear. When new they did rail in the same terrain.
    cheers
    Pagey
    Reputation: BRKNSPOKE's Avatar
    How do they do on wet roots, and rocks? You know eastcoast type singletrack?
    The way we ride today shapes mountain bike trail access tomorrow. -IMBA
    Monorail's rock!!
    Well, i installed a monorail up front, replacing a SB8, man, this tire has grip in the corners, rolls fast!!
    I was most impressed in the corners! loose over hard, and soft soil were not an issue, predicatble, very happy with it's performance!! this is a 2.1 UST version, with stan's..
    Thank's for the recommendation Pagey, 30psi was perfect!
    Knew you'd love em!
    cheers
    Pagey
