Results 1 to 31 of 31
    Maxxis Crossmark snipping/tweaking
    Hello,
    Anybody tried the Crossmark modification mentionned here:
    https://www.competitivecyclist.com/r...-8-UST.34.html
    I really like the Crossmark for dry hardpack conditions in the summer, but they lack some cornering grip and can get pretty sketchy in wet conditions, with leaves, mud, etc. From the description in the article, it sounds like a great modification to make the tire slightly less "condition specific", but I've never heard it reported or recommended elsewhere.
    If that matters, I have the 2.25 F/R on a XC hardtail. I also have a set of wheels with Conti Trail Kings 2.2 on a full susp trail bike and I don't expect the cut Crossmark to become excellent performers in the wet. I am just looking at giving the CM a bit more cornering bite.
    So...anybody did the mod? Any drawbacks and/or reasons not to do it?
    Reputation: ewarnerusa's Avatar
    Interesting that removing knobs makes the tire grip better in the corners...
    I could picture it, though. My new bike came with 29x2.1 Crossmarks that I immediately swapped for my preferred trail tire (Specialized Purgatory Control 2.3). I had tried Crossmarks years ago and didn't remember being a big fan. I thought I would maybe mount them up for a 38-mile gravel road race I do every year. I'd like to hear if anyone confirms this tuning because I would be interested in improved cornering traction on loose gravel.
    I haven't tried it, but it can't hurt. The Crossmark was probably the worst tire I ever bought. I'll definitely try that mod some day.
    Tried it and it worked really well.
    I chose 29" Crossmarks for the 2010 Transalp Challenge for their light rolling and wanted them to corner a bit better on loose stuff. Cutting out the little round knobs made it feel like a new tire, which Competitive Cyclist also says.
    Another mod is to cut out one or two of the rectanglular knobs in the middle row, between the 'swiss cross' knobs. This increases straight line grip (braking, climbing) a lot, as well as grip on slippery rocks and roots.
    I totally agree with CC on this: The Crossmark seems to be made for modification to make it suit your needs. If you are not happy with them, either sell them as new, or definitly try one of these mods.
    Thanks! Would you advise cutting the round knob both on the front and rear? ...or front only?
    I only did the front, because the front tire has the most effect on cornering grip and feel. At least in my mind .
    Good luck. You will notice there are a lot of those round knobs! A sharp not too large set of pliers is the right tool for the job.
    Do you guys mount your Crossmarks in reverse to more simulate a more knobby tire?
    Quote Originally Posted by NOCSUCOW View Post
    I did that, but the whole thing is symmetrical apart from the transition knobs that have a ramp on one side and an edge on the other, so the difference is small. Turning a Crossmark around does not make it a more knobby tire. It just tunes it a bit towards a bit more climbing grip vs. a bit more braking grip .
    I run them in opposite direction front vs rear.
    Front for braking, rear for climbing traction.
    I went ahead and tuned since this tire is sitting in my parts bin anyway. The remaining side knobs now appear like they would have a better chance to bite and not have their penetration hindered by the little round knobs.
    I like how it looks but I won't be mounting them up soon to try them out. But here are some pics at least.
    ^ got a pic of whatever scissors/tool you used to get those off? I started cutting some of mine off last night but my scissors were really tight fitting and cramping my fingers. I tried a wire cutting tool but it wouldn't get as deep as my scissors.
    I hear ya! I first tried with a set of wire cutters and quicly realized it wasn't the right tool for the job. I had great luck with a pair of sheers with narrow blades. I could use just the tip of the shears to get at the round knob from the side and the blades were narrow enough to fit beween the round knob and the surrounding rectangular knobs. They were actually very cheap sheers that came from the hardware store. They looked something like this.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Can you guys get the Maxxis Rendez? The 2.1 matches the Crossmark for volume and is a great front tyre in loose conditions IMO. Save all that knob snipping.
    Less isn't MOAR
    If it matters to anyone, I weighed what I cut off of one of my 26x2.1 Exo Protection tire and it was 18grams
    Quote Originally Posted by Sideknob View Post
    Maxxis Rendez? Never heard of it... I just googles it and I don't think its available around here.
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    For more hardpack grip... sipe those intermediate knobs!
    P
    I cut the round knobs on my front CM earlier today. No ride on it yet, but from the look of the tire, I'd agree those knobs were almost made to be removed. It now looks even more aggressive than I thought it would be. Can't wait to try it. If I like it, I'll probably tweak the rear tire too.
    Thanks all!
    I decided to work on sealing them up for tubeless usage. So far the conversion is going well, one seems air tight but the other got a bit soft overnight. Some weeping occurring around the beads. I gotta say, this tire is looking more attractive and I'll throw them on for XC racing next season.
    Reputation: GTscoob's Avatar
    Quote Originally Posted by ewarnerusa View Post
    This mod allows the remaining side knobs to support more weight and really bite in.
    I might have to try this although I've always been pretty happy with the Crossmark for GA conditions.
    Feb 2005
    I have done this before and really liked the handling results especially on softer terrains.
    Reputation: funnyjr's Avatar
    Damn little nubs flying all over my garage.
    Also helps to fold tire like so to expose the nub in order to achieve clean cut.
    Wear gloves, there are more nubs than you think - I got a damn blister. Thought about cutting the skin flap off blister w/ same snips I used to cut nubs - but decided to be safe and not risk an infection or worse yet grow nubs on my fingers. Isn't that how spider man came to be? **** I think I drank to much beer.
    Sent from my Galaxy Nexus using Tapatalk 2
    try anything on a bike
    Reputation: blue_biker's Avatar
    doing this this weekend. should have bike finished by mid next week, so i will give you a good ride report on my tuned CMs.
    May 2005
    Just modded my 650b CM by removing the round side knobs....I used a new pair of narrow bladed pruning cutters I purchased from my local hardware chain store.
    My CM is mounted tubeless on the rear and has certainly improved what is the worst tyre in the Maxxis line up.....only running it because I'm sick of piss weak walled schwalbes blowing off the rims Grrrrrrr
    Anyway, the mod definitely improves the corner grip of the tyre......I didn't push it to hard, just trying to gauge it's behavior....update to follow
    May 2005
    Made some more mods to the Crossmark by cutting slits into the + of the centre block to get some more driving edges.
    Feb 2013
    I think the only Crossmark mod I'd want to make is to get them off my bike! I've been using them for about a month and I'm not a fan. They're heavy and don't grip well. However, they do hold air like no other, but that's nothing a pump couldn't fix with another tire. I'm going with Specialized's Purgatory and Ground Control for F/R.
    May 2005
    Quote Originally Posted by n64kps View Post
    I think the only Crossmark mod I'd want to make is to get them off my bike! I've been using them for about a month and I'm not a fan. They're heavy and don't grip well. However, they do hold air like no other, but that's nothing a pump couldn't fix with another .
    Understand what you're saying....
    I'm running 650b where there are limited tyre choices at the moment.
    Was fed up with Schwalbes RaRa blowing off the rims (set up tubeless) so decided to go with a brand I know....despite the CM sucking traction wise.
    Guess the fact is you can make it a better tyre by modding it....but that wouldn't be hard!
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    My past two or three tire setups have been the Specialized Purgatory and Ground Control (F/R), and I really like this tire combo (I'm on 29" wheels).
    I modded a Crossmark a few months ago using a single edge razor blade to cut the round knobs pretty close to flush, but didn't have a chance to give it a go until recently. I tried to get it aired up tubeless, but it would seat, so I put a tube in for now. Been out for a few rides with it as a rear tire, and so far, I like it just fine. I tried it as a front last time (before modding it) and did not care for it at all. I usually don't run 2.1" front tires, but I will likely mod the other one I have and give it another shot as a front tire.
    I got some riding in on my snipped Crossmarks. Mounted tubeless. No complaints on the driving traction. Cornering seemed good, too. Still suck in the mud, though.
    Re: Maxxis Crossmark snipping/tweaking
    Awesome frozen hero dirt tonight. They hooked up great and rolled fast.
    Sent from my XT907 using Tapatalk 2
    Attached Thumbnails Attached Thumbnails Maxxis Crossmark snipping/tweaking-uploadfromtaptalk1363753193294.jpg
    Reputation: bholwell's Avatar
    Oct 2007
    If you'd like a little better mud performance, you can remove the little knobs on the centerline of the tire between the square knobs. I did it with a X-acto knife years ago- it took forever.
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Quote Originally Posted by bholwell View Post
    I could visualize a benefit in doing that. But I don't think any mods will make this tire a good mudder! It is what it is, a fast roller meant for more hard packed conditions.
