Results 1 to 3 of 3
    Mavic XM 719 Disc Rim width
    What is the exact width of a Mavic XM 719 Disc Rim? I;m planning to build a new wheelset with these rims but one online store says it is 24.5 mm, another says 23.8mm and the Mavic site does not have the width stated. Mavic XM 719 Disc Rim owners, please help. Thank you!
    Reputation: sixate's Avatar
    The inner section of the rim is 19mm. All Mavic rims ending in 19 are 19mm wide. 717's are 17mm wide. If you need something wider than that you should step up to a 521 (21mm wide) or 823 (23mm wide) and so on.
    If you want to know the outer dimension I just put a digital mic on mine and they're 24mm, but that really doesn't matter because the tire mounts on the inside of the rim. I'm 6'8" and weigh 240lbs, and mine have held up no problem.
    whoah! many thanks for the reply!
