Mavic hub problem
Printable View
  • 11-26-2012
    GTfreefall
    Mavic hub problem
    Hello, have a Mavic hub that wont release. Just keeps spinning. Any ideas? Youtube video below:
    https://www.youtube.com/watch?v=mpx8...e_gdata_player
  • 11-26-2012
    One Pivot
    Im pretty sure you have to put a hex key in the other side to hold it in place.
  • 11-26-2012
    GTfreefall
    The other side is the lefty stem going into the hub. No access points, and no hex key.
  • 11-30-2012
    410sprint
    In the video it looks like you did not remove the brake caliper first. Bad news.... You probably stripped the self extracting bolt. When you started to back it out, the caliper prevented the wheel from moving.
  • 11-30-2012
    meltingfeather
    the caliper is clearly off the rotor... and that wouldn't strip the bolt.
    OP- shop time, i think. i'm not super well versed on Lefty, so I'm not sure what your options are.
  • 12-01-2012
    410sprint
    My old eyes must have missed the caliper being off. :blush:
    From personal experience helping a friend extract an axle bolt with a rounded out head on a lefty, I can tell you that the axle bolt has self-extracting threads and if you crank too hard the rotor will press against the caliper (if not removed) hard enough to round out the bolt head and bend a rotor. When you loosen the axle bolt it pushes against the bearing dust cap and pulls the hub off. Just like self-extracting crank bolts work. The OP’s axle bolt head seems to be fine, so the either the bolt or the axle threads are stripped.
    It might not be a good idea for the OP to ride the bike until this is fixed… as melting feather said- shop time.
  • 12-01-2012
    LMN
    That looks like a fork issue not a hub issue. The insert that the bolt screws into is turning.
    As melting feather said, take it to a shop.
