Results 1 to 35 of 35
    Mavic hub adapter 15mm to 9mm - question
    Hi all,
    I'm completely refitting my old 1997 Specialized Rockhopper. I purchased the Mavic Crossride wheel set, and I am attempting to use the Mavic QR 15mm to 9mm adapter.
    I've scoured the internet, but I can't find a picture of the finished product. I put a dab of grease on the o-ring, but I seem to only be able to get the adapter in to a certain point. I'm not sure if the adapter is seated far enough into the hub. Can anyone advise?
    Attached Thumbnails Attached Thumbnails Mavic hub adapter 15mm to 9mm - question-photo-1-3.jpg
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Have you tried sticking the wheel in your fork ?
    I don't post to generate business for myself or make like I'm better than sliced bread
    Maes3o
    I have the same situation, were you able to resolve the it?
    resolved
    DeeEight had a great suggestion - After confirming that the fork wouldn't fit in the position the adapter was in, I put the wheel on my deck with one adapter resting on the deck (and the other visible to me. obviously taking care not to let the wheel itself come into contact with the deck, I tapped a few times with a mallet against the adapter... and then one solid tap/whack, and both adapters seated perfectly. Now, I can't imagine that I will ever be able to remove the adapters.
    the short answer to your question is that if your adapters are seated as they were in the pictures I posted, they are not fully installed.
    Thanks much to DeeEight.
    Hope this helps.
    Maes3o
    Thanks, ill check that out!!!!
    Feb 2012
    Does anyone know where to find these adapters online? Price point
    Has what looks like it would work but says not for cross ride wheels. Which
    Is what I need it for.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by Fred2726 View Post
    The Mavic plugs as Pricepoint will convert any 15mm wheel to 9mm q/r. Because the axle ID is standard, they'll fit any 15mm wheel from any manufacturer.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Mar 2011
    mavic wont work cuz it has a 2mm cap to it. look at the first picture. i had this issue 2 yrs ago. i tried the mavic caps and they dont fit cuz of that 2mm edge to the cap. your 15mm hub is already 100mm and QR forks are only 100mm wide so its obsolete. u can force them in but good luck. u might hurt yourself. check out what i made! =) had it done at a LBS they were awesome but first prototype was kinda $$$ bling bling. o well it worked for me! Good Luck!<br><br>
    ImageShack® - Online Photo and Video Hosting < <<<**** heres a PHOTO of what i did.
    Quote Originally Posted by Loverboyvaj View Post
    are you saying the Mavic 15mm hubs are 96mm wide and that the OP's "resolved" means doesn't work?
    Mar 2012
    New question here.
    Quote Originally Posted by meltingfeather View Post
    i'm also wondering if this worked or not..? and rczbikeshop.com also offers what looks like the same products but its specific for and works for crossrides!
    Mar 2012
    Good job!
    just fyi, the adapter from price point for the 15mm to 9mm does work! i had put in a call to mavic to confirm it beforehand and price point says mavic should be correct if they say it works. i was riding dat setup today! the adapter is a tight fit, just add wd-40 and you can pop it in with your pinky. hope this helps some peeps!
    MarkyMark
    Reputation: MarkMass's Avatar
    It took a bit of effort (used the QR skewer with tape over the end, rested it on inside of the cap, tapped it with a mallet), but I was able to remove my Mavic 20mm TA adapters. I added some lube/grease so it'd be easier to remove next time.
    Quote Originally Posted by paddler123 View Post
    + bump
    Are you sure this kit will work with Crossrides?
    Mavic QR Plug- Fits 15mm Front Axle at Price Point
    “You can always count on Americans to do the right thing - after they've tried everything else.”
    Reputation: TwoHeadsBrewing's Avatar
    Quote Originally Posted by PatrickK View Post
    + bump
    [STRIKETHRU]My Crossride wheelset came with the 9mm QR adapters already installed. Had to tap them out to run my 15QR fork.[/STRIKETHRU]
    NVM, I'm an idiot. I have the Crosstrail wheelset...
    "Got everything you need?"
    I am looking at Crossridesand the front is 15mm so I would have to convert. I got a little be concerned when I read on pricepoint website it does not work with Crossrides. I do not want to break my teeth.
    Can you post a link to the wheelset you're looking at?
    + bump
    If they are 15mm TA, it will convert them to 9mm q/r.
    I wonder if Mavic has outsmarted themselves with proprietary fit parts.
    I'd call Mavic on that one.
    It is quite difficult to find contact info on their website unless I am blind.
    (888) 466-2842
    Thanks. I just gave them a call and provided me with a part number that does not exist in Google. I am calling them again since I found this kit at bikebling.
    Mavic 9mm QR Adapter from BikeBling.com
    (888) 466-2842
    (888) 466-2842
    Thank you. This is what I need.
    MAVIC AXLE REDUCERS 15-9 MM KIT 99694101 - Mc Convey Cycles
    How do I get it in the States?
    Quote Originally Posted by TwoHeadsBrewing View Post
    Hos is that Crosstrail wheelset workinf for you? What is your weight? My Fulcrum Red Metal 3 went of true a little bit after 1100 miles and I am not happy about it.
    This guys says it works.
    Mavic Crossride or something else? | Mountain Bike Forums
    I really like the Crosstrail wheelset, no complaints for a ~$300 UST wheelset that works with centerlock, 6-bolt, 9mm, or 15mm. It's not a super light, but they aren't boat anchors either, and have stood up to quite a bit of abuse.
    And seriously? 1100 miles and you're bummed? I expect a couple hundred miles with a brand new wheelset before it needs to be trued up. 1100 miles is looooooooong!
    Where do you get those wheels for $300? Did you have to servie the rear hub? It seems to be quite easy. I do not like super light wheels. 2000g wheels with skewers are fine with me.
    HuckNRoll had them on sale in November of last year and I snatched them up. So far I've put maybe 500 miles on them and the rear hub still runs smooth. I just noticed them being 1mm or so out of true, which is amazing since I've bounced them around on rocky trails quite a bit. I have a friend with an older version of the Crosstrails and he said it's really easy to service the hub if it starts making the trademark Mavic groan.
    Shame I missed it. I a big fan of Fulcrum wheels but I was a bit disappointed when I found out the weight limit is 82kg. I weigh 72kg plus 9.5kg bike and a backpack. I have not been abusing my wheels at all. Mostly long rides on a rough asphalt trail which I think is worse than soft forest soil.
    I would like to add that my Fulcrum 5 wheels stay straight. I think it has to do a lot with j-bend spokes which are stronger.
    Update:
    I have got my kit from pricepoint. It worked like a charm with a drop of Teflon Lube. I had to push it in a little bit harder on the left side. I am also impressed with a manual, packaging and adapters etc. that came with Mavic wheelset. It is much better than my more expensive Fulcrum or Hope Hoops wheels. I am getting another set since for $140 it is a steal.
    Reputation: HTR4EVR's Avatar
    Update:
    How did you get it into the US?
    A mountain, a lake, a trail, all waiting there...
    pat
    pat is offline
    Sep 2004
    Does the Mavic adapter fits for use on Easton EA 90 XC wheels? Thanks!
    Quote Originally Posted by pat View Post
    I just ordered this from eBay..
    Mountain Bike 15mm Thru Axle to Standard 5mm Quick Release Wheel Adapter | eBay
    Yes. It fits any 15mm TA wheel.
    I got the adapter from eBay and worked great...
    Sep 2012
    New question here.
    I just got the Mavic adapters for my XT hubs. At first they seemed rock solid but as my ride went on the front wheel seemed to get a bit loose/sloppy. I put the adapter in w/o removing the one end cap; it still fit right into my fork. Could this be causing my wheel to feel sloppy? Should I take the end cap off regardless?
    Also, is there anyone on here that can explain how the 9mm part that extrudes from the cap can take all the weight and stresses of mountain biking?? I can't get it out of the back of my head that they are going to snap clean off every time I hit a little drop.
    Cheers!
    Dec 2012
    TA means Thru Axle? So, I can use this adapter on Fulcrum Red Power XL wheels?
  1. adapter 15mm to quick release
    By seaweed in forum Shimano
    Last Post: 10-14-2016, 11:45 PM
  2. 15mm fork adapter skewers lock?
    By sknsnw9 in forum Cars and Bike Racks
    Last Post: 05-16-2013, 12:07 AM
  3. Hope 15mm to 20mm adapter question
    By jason333 in forum Wheels and Tires
    Last Post: 11-25-2010, 09:16 AM
  4. 15mm to 9mm adapter?
    By Dr Saw in forum Wheels and Tires
    Last Post: 10-06-2010, 01:38 PM
  5. ProRack - 15mm adapter? Any suggestions?
    By KYjelly in forum Cars and Bike Racks
    Last Post: 07-31-2010, 03:54 PM
