Results 1 to 6 of 6
    New question here. Mavic D521 + Surly Endomorph + Surly 1x1 fork
    Ok, let me describe my situation first:
    I have already an ok wheel and ok Hope disc brake. The rim is Mavic D521. The fork is too narrow. I'd like to try Surly Endomorph, which is a 3.7" tire. Obviously I need a better fork.
    I have two questions:
    1. Would Surly 1x1 fork be wide enough for the Endomorph, if I put the tire on a Mavic D521 rim?
    2. Is the D521 rim too narrow for the Endomorph? Does that combination work?
    Category Winner
    Reputation: teamdicky's Avatar
    Quote Originally Posted by Nikolas
    Don't think the Endomorph would fit in the fork. It was made with the Pugsley frame/fork specifically in mind.
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
    Reputation: shiggy's Avatar
    Dec 1998
    Extremely unlikely to fit in the fork as a Gazzi 3.0 barely fits.
    Not recommended to use on a rim as narrow as the 521. Surly recommends at least a 45mm wide rim which is ~50% wider than your rim. The Large Marge rim is ~2.5 times wider than the 521.
    mtbtires.com
    New question here.
    Quote Originally Posted by shiggy
    Wish I had seen that recommendation by Surly somewhere before asking. Where did you find it?
    Dec 1998
    I do not remember. It may have been the surlyblog. In any case the Endomorph is too big for the 1x1 fork.
    mtbtires.com
    Unless...
    ...you shave some side knobs or do like a co-worker of mine did, and use a blowtorch to bend the fork out a little bit. Problem solved, and his 1x1 now has Alex DX32's with Endomorph tires on it.
