Results 1 to 7 of 7
    Reputation: George Gr's Avatar
    Mavic Crossline 12mm to 10mm adapters
    I bought a set of Mavic Crossline wheels and I wanted to put a 10mm quick release at the rear wheel. So I also got a set of these 12mm to 10mm reducers
    The think is that they won't fit inside the rear hub...
    I removed the standard 12mm to 9mm QR adapters that where on the hub when it came from the shop and tried to fit the 12 to 10 with no luck. I measured the outer diameter of the adapter and it is 12,9mm
    I called our local Mavic representative to check another set and measure it but he told me that it is 12,9mm also. It is impossible to fit in a hub that it is 12mm diameter....
    Am I doing something wrong? Does anyone ever done the same with Mavic wheels?
    I have just got mine and they have the same problem
    The ID of the hub is 12 mm to fit a 12 mm axle as you would expect
    But the adapters are 13 mm OD. How do these work
    They just don't!
    No word from Mavic about this. My local distr. couldn't find a solution...
    I just got a 12mm to 10mm QR axle and solved my problem!
    "Do not go where the path may lead. Go instead where there is no path and leave a trail" Ralph Waldo Emerson
    Just what I thought
    I'll machine up my own adapters
    I expect a refund from the shop for these little rip offs
    Thanks for the reply
    These are the best things to do ;-)
    What stepped axle did you get
    I see sun ringle do a nice one
    I like d the adapter be ukase I can use the dt Swiss 10mm QR
    Bring on the lathe
    I got this one.
