Results 1 to 3 of 3
    Reputation: L3ONNOEL's Avatar
    May 2012
    Mag 30 dh rim problem
    I recently got a bike with mag 30 rims, and when I pump the tires up 60 psi, something comes loose and slides around the rim, but when I take some air out it stops. I have no idea what it is. Ive taken the tire off heaps of times, and the sound stops, but starts again when I get to around 60 psi. The sound is clearly in the rim. Does anyone know what the noise could be? The only thing I can think of is something is lodged in the rim, and when the tube pushes the rim walls out the thing wedged in slides around
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Why are you putting 60 psi into a DH tire?
    You are hearing the sleeve on the inside of the rim where the 2 sides come together.
    Shouldn't be anything to worry about.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    May 2012
    I ride to school so I put maxxis hook worm tyres on it, so that's why I pump it up
