Results 1 to 5 of 5
    Reputation: KMan's Avatar
    Loose cassette hub on a set of Mavic Ksyrium SL's, how to fix?
    I was cleaning my road bike last night and trying to find where I was betting a bit of noise from my drive train. I noticed the cassette on the hub of my 04 Mavic Ksyrium SL's was a bit loose. Turns out the cassette hub itself is a bit loose. I messed around with it a bit last night and could not figure out how to tighten the cassette hub.
    Anyone know how to do this?
    I can remove to non-drive side parts, but the parts on the drive side (where the allen key is inserted) I could not remove?
    Thanks for any help,
    KMan
    a legend in his own mind
    Reputation: mtnpedaler.com's Avatar
    Quote Originally Posted by KMan
    KMan
    Here ya go. It's a CrossMax but you get the idea. You should have got one of these tire tools with each wheel.
    "I think this is the worst thing you've ever done Homer."
    "Oh Marge you say that so much it has no meaning."
    Larry, does that tighten a "loose" drive side cassette hub?
    I didn't get the tool, but I used a make shift tool to tighten that.
    I thought that just tighten the bearings. Does it affect the cassette hub shell as well?
    KMan
    Quote Originally Posted by mtnpedaler.com
    KMan
    A pin spanner tool will work. Yes it what holds everything together.
    Professional Slacker
    -Rich
  1. Cassette loose on the hub
    By Ratt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-04-2004, 02:57 PM
  2. XTR hub or Mavic Crossmax Hub?
    By windsplitter in forum Wheels and Tires
    Last Post: 04-27-2004, 06:35 PM
