Results 1 to 17 of 17
    less leading than trailing spokes (32h rear disc hub / 24h rim)
    Can anybody tell me if, considering only one hub flange, the number of trailing spokes must be the same as leading spokes?
    I was considering mounting a 24h rim with a 32h hub using 2 trailing / 1 leading on the drive side and 1 trailing / 2 leading on the brake side.
    The overall count is even and this would allow me to leave every fourth hole free and distribute the holes on the flange.
    Reputation: shiggy's Avatar
    Dec 1998
    Try it if you must, but just get the proper parts if you want a solid wheel build.
    mtbtires.com
    Hmmm...sounds like POWerwheels!
    Dec 1998
    I am tempted to take an old wheel and cut out 8 spokes, but I do not have one I am willing to sacrifice.
    I have build a few (20") wheels with 8 spokes on one side and 16 on the other.
    mtbtires.com
    I already stumbled upon POWerwheels but I was not able to understand whether it is a joke. Given the rest of Sheldon Brown writings I think that something true hides there, but unfortunately it is not possible to ask him anymore.
    mtbpete
    Reputation: changingleaf's Avatar
    Geometrically it looks like the tensions will balance out since you're doing the reverse on the other side of the wheel. It also looks like it will induce some twist in the hub.
    Dec 1998
    Quote Originally Posted by marcoxc View Post
    It is a total joke.
    mtbtires.com
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Scroll down to the photo at the bottom of the inventor and read downward - it makes it pretty obvious that it's one of his annual April Fools' day articles.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Doesn't Industry9 have a 2/1 24 spoke set of wheels. Although, their's was designed to run that way.
    Lead by my Lefty............... right down the trail, no brakes.
    Dec 1998
    Quote Originally Posted by ziscwg View Post
    Yes. Campy/Fulcrum were the first to bring it to market, many years ago AFAIK.
    mtbtires.com
    FYI: I have built it and time will tell about durability. It has been a bit tricky to find a spoke pattern compatible with the spokes I had. First of all I assembled it as a "regular" wheelset with only 16 spokes, using half of 32 holes in hub, leaving out 8 holes in rim, resulting in a balanced wheel that could be trued although with fewer spokes. Then I added 4 trailing spokes on each side with a different (longer) spoke length.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Somehow I missed this thread previously. Let us know how it works out.
    Rather than unbalancing the number of leading vs. trailing spokes, which means your tension varies significantly, I would have unbalanced the number of spokes per flange, as mentioned by others.
    Good luck!
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    "Dish is illogical." Spoke of Vulcan.
    Cute... picture-with-zero-explanation.
    What was the tension balance?
    @meltingfeather and @zerodish: my wheel has disc brakes and I assumed that unbalancing the number of spokes per flange (as in the photo) would result in more chances of breaking something. In the past with this same wheel I have broken spokes on both sides so I cannot say which flange (drive or disc) could run with fewer spokes.
    I just finished a ride climbing for 1000mt and everything is fine so far.
    If anybody is interested I can post a pic of the wheel.
    BTW, rebuilding the wheel I used 2.0 spokes instead of the previous 1.8 and now the ride is harsh. I did not expect such a difference.
    I would think that the large tension variation caused by unbalancing the leading vs. trailing spokes would cause more durability issues.
    The DS gets fewer spokes, and as others in this thread have mentioned, there are at least a few companies who use this design to achieve more uniform spoke tension left-to-right. Modern hub shells are more than rigid enough to handle the braking forces through the NDS flange.
    Hopefully everything works well for you.
    I'd like to see a picture.
    I think there is some other factor causing the perceived harshness in the ride. The difference in elasticity of those two spokes is almost nil... as in on the order of 0.001mm difference in deflection.
    Seems like I am not allowed to post pictures...
  1. Replies: 21
    Last Post: 07-01-2013, 11:16 PM
  2. Replies: 5
    Last Post: 05-11-2013, 05:16 PM
  3. Disc wheel build-DB or straight guage spokes?
    By logbiter in forum Wheels and Tires
    Last Post: 10-23-2012, 01:06 PM
  4. 20 spokes enough for a cyclocross disc wheel?
    By blantonator in forum Wheels and Tires
    Last Post: 09-20-2011, 09:43 AM
  5. Leading a race
    By pljam67 in forum XC Racing and Training
    Last Post: 05-20-2011, 06:06 AM
