Results 1 to 3 of 3
    Reputation: amillmtb's Avatar
    Jun 2005
    Lefty Hub Measurements
    Has anyone built a wheel with a lefty hub? What are your measurements on the lefty hub? Do these sound right? I am lacing it to a ZTR Olympic 347, does 257mm non-drive and 261 drive sound right?
    My measurements are:
    Left Flange:
    dL: 58.00mm
    WL: 18.55mm
    Right Flange:
    dL: 45.00mm
    WR: 31.56mm
    Thanks for your help in advance!
    Jul 2003
    Sounds about right.....
    for exact results I get 257.7 left and 260.8 right. I'd be more inclined to go 258 left and 261 right rounded. And this is assuming a 3x pattern of course.
    Anyway, sounds about right to me.
    Good Dirt
    Jun 2005
    Thanks for the help, I did the spoke lengths that you suggested and got the wheel built. It went pretty smoothly for my first wheel build. This wheelset took just under 2 lbs off the overall weight, from the xm117's and deore rh. Went from 29.79lbs to 27.82lbs Thanks Squash!
