• 12-12-2012
    JimEG
    Least rolling resistance hubs? Help.
    Looking for a sealed and durable hub for a strong wheel build on an enduro bike with as little drag as possible. I was running Hope hubs, but the drag is, well a drag. My LBS said White Industries hubs have very little drag.
    Any suggestions?
  • 12-12-2012
    smithrider
    DT Swiss and the new Easton's are the lowest drag MTB hubs I have tried. DT Swiss would be the reliable choice out of the two. That said, I have only ridden King, I9, DT Swiss and Easton on my MTB's for some time so not a broad sample set.
    That said, the lowest rolling resistance hub I have tried by far is the Campognolo on my road bike. Campy makes mountain bike wheels now as well under the Fulcrum brand.
  • 12-12-2012
    steadite
    I haven't sampled everything out there, but can confirm WI spin really nicely.
  • 12-12-2012
    hitechredneck
    I found the sun ringle flea hubs to roll for days.
  • 12-13-2012
    Bike Whisperer
    American Classic hubs have the least drag of any cartridge bearing hubs I've used, especially in the freehub body. But while it is a 24 poe hub like the Hope and White Industries, the engagement is slower because the pawls take longer to engage. They are also quiet compared to most hubs.
    However for the ultimate roll, nothing beats a quality Shimano cup and cone hub with a light grease (Slickoleum)...roll forever!!!
  • 12-13-2012
    derby
    Originally Posted by Bike Whisperer View Post
    American Classic hubs .... But while it is a 24 poe hub like the Hope and White Industries, the engagement is slower because the pawls take longer to engage. They are also quiet compared to most hubs.
    The Hope P2 rear hub has slow engaging angled-cut pawls and teeth too... and engage about as slow as an old XT 18 tooth hub while riding. Hopes are pretty high in friction also. But they look cool and are as loud as a Harley with straight pipes!
  • 12-13-2012
    JimEG
    I considered the Shimano route. But being in the NW, sealing against the muck is really important. The impression I was given by my LBS is that they wouldn't last long around here. It's been many years since I ran a non-cartridge bearing sealed hub here.
    Any more thoughts on that? Shimano was my original first choice, but I was deterred from going that route for the above reasons.
    And for the record, the Dura Ace hubs on my Surly are by far the smoothest rolling hubs I've ridden.
  • 12-13-2012
    Bike Whisperer
    I've run Shimano hubs in the PNW for years...though in the wet I prefer to use a heavier Marine grade grease. Even with the thicker grease a hub like the XT M756 or the STX M665 cup and cone hub still rolls forever and they hold up fine. You just have to stay on top of servicing them (usually 2x a year for me). That said I quite enjoy my WTB (American Classic clone) hubs for their drag free performance, quiet coasting, and nice stainless steel bearings.
    My 10+ year old Ultegra hubs are also the smoothest hubs I've ever owned. Still original bearings packed with Slickoleum. I service them about once a year.
  • 12-13-2012
    Zen Cyclery
    This!!
    Hard to beat the bearing feel on the Whites. They have consistent longevity, and they are easy to service when that time finally does come.
  • 12-13-2012
    Matty F
    White Industries or American Classic are about the fastest rolling hubs I've seen, and I've had nearly all the high end hubs in my bike stand at one time or another. The American Classic's would probably be marginally faster rolling due to their pawls-retract-when-coasting freehub design, but this makes for sluggish engagement, on top of their already fairly low 24 contact points. They also have more durability issues that the tried and true White's, and I've also gotten more reports of flexy axles on the Classics.
    I wouldn't, however, consider getting a hub based on rolling resistance, unless you are already on a race-bred XC machine with super high rolling tires and such. Rolling resistance due to hub bearings is a much smaller portion of total resistance than people make it out to be. Somewhere under 1%. There is a good bit on it in Bicycle Science - 3rd Edition. You would be much better off studying your tire choices well and working on dialing your inflation pressure than getting flexy hubs with soggy engagement. Dropping 2psi from each tire would give you a better rolling advantage than going from "good rolling" hub to a "great rolling" hub.
  • 12-14-2012
    thechez
    I will agree with those on the American Classic hubs. I have a set on my road bike and have easily 7000 miles on them. I had one of their front hubs on my old wheels on my mtb and though the bearings eventually went up here in the Pacific Northwet, they were easily replaced. Now I have some Sun Ringle Black Flag Pros. They're sealed and they roll very very well. I don't feel they're the most sealed in the world but again they're easy to service as well.
  • 12-14-2012
    womble
    By "sealed" do you specifically mean "cartridge bearing"?
    If not, then XTRs are the best-spinning hubs I've ever come across.
  • 12-14-2012
    FireSpitter
    My current White Ind hubs are my 4th set. That should speak volumes of how high I rate these hubs.
