Page 9 of 9 FirstFirst ... 56789
Results 801 to 850 of 850
  1. #801
    Reputation: ya29er's Avatar
    Aug 2013
    The Koozer hub lasted only 2 months for me. Now the ratchet spins freely inside the hub shell.
    I've bought it from aliexpress and don't have any warranty cards. According to Koozer there will be no warranty in my case.
    As I understand the aluminium thread of hub body was minced by the steel thread of the ratchet.
    Whet it was working I really liked it. 72POE is the thing and really helps.
  2. #802
    West Chester, PA
    Quote Originally Posted by ya29er View Post
    So invest in a king, hadley or I9 then.
  3. #803
    Aug 2013
    Quote Originally Posted by 92gli View Post
    Buying a $500 hub from an US company is against my life philosophy.
    Koozer actually replied to me quite quickly and are going to send me a new hub. They say that they see this type of problem for the first time. And I believe them - I weigh about 120kg geared up and tend to brake all kind of components much more often then everybody else around.
  4. #804
    Nov 2014
    might make sense for you to use a hub with a larger ratchet ring (more contact area with the hub shell) or one without a threaded-in ratchet ring (xm470, dt swiss)
    or maybe just one with deeper threads if you can find it
    I like how he said "invest", by the way
    like it's gonna pay off
  5. #805
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    As a fellow clyde, the koozers are likly to keep going out on you. I kept deforming freehubs though the ratchet ring never gave out on me. I'm interested to see how the clydes do on the xm370 ring.
    Anyway, I have since moved to bike hub store / bitex hubs, and for a little extra coin theyre considerably more stout. Theyre not without thier problems, and I miss the extra POE the Koozers have (72 vs 54), but the BHS hubs are definitely stronger.
    But hey, if they can figure out how to make the koozers a bit more clyde friendly, I'd be back for sure.
  6. #806
    Aug 2013
    Quote Originally Posted by GuitsBoy View Post
    Bitex hubs are not perfect either.
    I've snapped an aluminium axle on Bitex hub. Replaced it with a steel one from Novatec.
    Then after another year the bearing shell on drive side became enlarged - i.e. the bearing itself is loose inside it's shell and can be removed with bare fingers. Fixed using a bearing fitting compound.
  7. #807
    Land of the 230+
    Sep 2013
    I'm not saying they are perfect. In fact I mentioned that they're not without their problems. I had skipping due to weak pawl springs in mine. but I still feel they are build a bit more stout than the koozers were, and so far they've handled the punishment much better. For what its worth.
  8. #808
    Oct 2015
    Glad to hear that they are standing behind the product and replacing it under warranty. I just laced up my XM490 (this was the first time I ever attempted to build my own wheel!) and for obvious reasons stories like yours get me nervous about the long term reliability of the hub. Just as a reference: did you use this website to reach out to them: About us | REBORN INDUSTRIAL DEVELOPMENT LIMITED ? Thanks!
  9. #809
    I have a brand new in black koozer hub. 32h qr 135
    I can let go for $45 shipped if anyone wants. I went with bitex and thought I cancelled this but appatently he didn't get the message.
  10. #810
    Aug 2013
    Quote Originally Posted by Szy_szka View Post
    Yes, I've contacted them using the email address listed there.
    So I've just received the hub. They sent the whole hub by DHL and didn't asked to send the broken back. So far this is my best warranty experience with hubs.
    Also the seller from Aliexpress offered to send a replacement but I would have to pay for the shipping.
    On the other hand when I minced down internals of Hope Evo 2 hub I had to send it back (+€7) first. The whole process took more then a month.
  11. #811
    Mine is now unlaced and going to my office as a liter paperweight. It's done and I'm really done, it's not even a viable backup anymore.
    It just doesn't roll well now. I'm not going to figure out why. It's not gritty, it has nice skf bearings. it just stopped rolling well. The pawls are beat, the shell is beat. I bet the axle bent.
  12. #812
    Reputation: 006_007's Avatar
    Quote Originally Posted by One Pivot View Post
    Quitter.
    Maybe turn it into a salt shaker?
  13. #813
    Jun 2017
    4 months so far with the Koozer XM 470 and everithing is working fine. Some muddy rides doesnt afected so far, bearings spinning freely and a clean ratchet is what i saw when opened the freehub.
    About the sound, i compared the 470 vs Hope Pro 4 and measured the sound with an app and the results are very surprising. Koozers are 12 db louder than hopes, this damm hubs are noisy! so fans of loud hubs will be pleased. I think if your goal is to have a trustworthy hub without paying a big amount of money the koozers 470 are pretty ok, it seems to be that koozer have adressed some reliablity issues and they solved very well, of curse you dont have the ultra quick engagement, but 28t are pretty ok for many riders, maybe only on ultra technical sections you´ll find not so quick.
    Here you can see a video made by my self.
    https://www.youtube.com/watch?v=M_okN8SxtcU
  14. #814
    Reputation: Schulze's Avatar
    Feb 2007
    I've done a few rides on the dt ring drive knockoff version and it works fine. I have a lot of bikes and wheelsets so I can't put tons of time on it, but it looks like a solid design.
  15. #815
    Is dang happy!
    Reputation: Mr. Doom's Avatar
    I need a louder hub than my old Hope for chasing bears off the trails, seriously.
    XM470 looks like it will work, has a skull on it to match the Yelli. Building up a set of 35mm id Kore Realm 35mm id hoops. (Modern bike has them for $40 a pop with the 7% code and free shipping btw).
    12db louder than a Hope is impressive. That should be twice as loud! Thanks for the info Bacalardo
    The wheel is a extension of the foot
  16. #816
    Reputation: W.J.Christy's Avatar
    Jun 2017
    Soo in my desire to build a secondary wheel set, I came across this thread while looking for hubs. I made it halfway through and decided to purchase a set. Well, I have now read the whole thread and am starting to wonder if I made the right choice. On the plus side, I have an and extra set of reliable hubs that I can lace up still.
    I am 210 ride mostly XC with only 1-3 foot drops and jumps (which I rarely do) and I am not a pedal masher most of the time.
    Should I cut my losses now and lace up the other hubs or should I experiment with the koozers and see what happens? thoughts?
  17. #817
    Reputation: gotdurt's Avatar
    Quote Originally Posted by W.J.Christy View Post
    If you are comfortable with lacing wheels, I wouldn't hesitate to put them to use; for me, it's only about an hour of my time, and if I can get a year out of them, I'm happy. I have a set that have been on 3 different bikes now since early 2015, and are still in good shape... luckily I caught a bad freehub bearing pre-failure that was causing some flex, and I had to replace the thin plastic ring in the freehub, but they are otherwise fine. FWIW, I pound my bikes pretty good. Id go ahead and use them, maybe start off with some good bearings for insurance, especially in the freehub.
    'T'is only a flesh wound...
    Some videos
  18. #818
    Aug 2013
    If you usually don't brake components then you'll be fine.
    Unfortunelly I do brake everything quite oftent. Just yesterday I managed to crack freehub bearing and feehub itself after about 1.5 months of usage.
    It was the replacement hub that they sent to me.
    And I had exactly the same experience with Hope Evo 2 hub which was supposetly rated even for downhill. With Koozer it's a bit easy to deal with - they send replcements without asking you to send them the broken part.
    A couple of weeks before I cracked XT crankarm in half while climbing.
    Attached Thumbnails Attached Thumbnails Koozer hubs, 72 POE @ under -20171005_082619.jpg
  19. #819
    Land of the 230+
    Sep 2013
    Those pics land somewhere between LOL and Holy Sh!t.
    I thought I was hard on my bikes. I see I have much to learn from you, master.
  20. #820
    Jun 2017
    Lord have mercy, what exactly are you doing with that bike? Yeah, I don't break stuff often, looking at how most people who have broken these hubs ride, I am pretty easy on my bike.
  21. #821
    Jan 2009
    That's exactly what I was thinking looking at the crank pic, lol.
  22. #822
    mjw
    mjw is offline
    Feb 2007
    I have a buddy who bought a set of the Poozers to try. The ratched ring broke free and started spinning inside the hub. Lasted a couple months at most.
    Total waste of Money.
    • 2015 Kona Explosif Ti
    • 2015 Kona Process 111
    • 2016 Banshee Rune
    • 2017 Canfield Riot
  23. #823
    Jun 2017
    Quote Originally Posted by mjw View Post
    What kind of riding did he do? How heavy was he if you don't mind me asking?
  24. #824
    mjw
    mjw is offline
    Feb 2007
    He is 160-165 lbs
    Powerful for his weight I would say, but not a giant by any means.
    Most of the riding on them was flat prairie xc, and they broke on a trip to Deluth.
    The drive rings are not keyed - totall engineering mistake. They must be just bonded in. Considering a mtb'er generates the same torque as a small car, I'd say Poozer hubs are basically designed to fail. At lease the pawl and ratched style hubs.
    When you are 20km away from the trail head and your drive ring/ratched ring seperately....you have a long push back to the car!
    • 2016 Banshee Rune
  25. #825
    Jun 2017
    Ouch, Oh well...... I can lace a wheel pretty easily and these are supposed to be the back up set. Plus i have a spare hub ready to go that will use the same spoke length. So I think i will give these a shot and see where it goes with the expectation of failure. I will just be sure to not use them when I absolutely need a reliable wheel set.
    Most of where I ride is well populated and never to far from the car....... The joys of living in Houston.
  26. #826
    Aug 2013
    He is 160-165 lbs
    Not true. The ratchet ring has a thread and is threaded into the hub body. Most hubs are made the same way.
    In my case the thread on the ratchet ring was fine, but the thead on the hub was gone.
    The problem is not the design, by design they are all more or less the same. The problem is in the quality of manufacturing.
    A $7 narrow-wide chainring from aliexpress lasts only 2 months for me, but $30 from a proper brand such as Absolute black lasts alsmost a year. By design they are all the same. The difference is the aluminum alloy. The cheap one probably is made from softer 60x series alloy to justify milling costs.
    There's an old trick to use cable ties to tie casstte and spokes and make it a fixie.
  27. #827
    Land of the 230+
    Sep 2013
    Thank you for this. I'll be sure to hold on to this gem for future use.
  28. #828
    mjw
    mjw is offline
    Feb 2007
    Thanks for the clarification. Still... designed to fail! At least this version of the pooz.
    You will find also some companies to key their drive rings. Novatec does in their better hubs, like the Factor series for example.
    A few zipties on cassette and spokes is a neat idea. Still not going to be much fun through.
    • 2016 Banshee Rune
  29. #829
    Nov 2014
    factor hubs cost $200 or more per set
    haven't seen keyed ratchet rings in this price range (<=$100)
  30. #830
    mjw
    mjw is offline
    Feb 2007
    • 2016 Banshee Rune
  31. #831
    mjw
    mjw is offline
    Feb 2007
    Quote Originally Posted by bruto View Post
    I was using as an example.
    I bought a set of new factors a while ago btw, for $120 usd to my door.
    In the last 6 months I've seen a good number of similar deals on nicer hubs.
    Crc has DT 350's for example, 36t,15x100 front 12x142 rear for around the $120 usd mark.
    If you aren't in a rush, better deals will pop up. You just have to watch for them.
    • 2016 Banshee Rune
  32. #832
    Nov 2014
    had, you mean
    the rear 350s were probably gone in an hour
    yeah I bought a set myself once for less than that, but it was a one off deal as well, so not really something I can advise to someone as an alternative to hubs that are actually in stock somewhere
    btw, the RWS-style Koozers have keyed rings I think
    there were pictures on this thread a while ago
    only 3 tabs, but probably enough for most people
    not everyone is 220lbs and hucking 3ft drops in the bottom gear (and landing uphill)
  33. #833
    mjw
    mjw is offline
    Feb 2007
    had, you mean
    I think just a few keyed tabs is all you need.
    The 350's were up for a couple week - I was super surprised. After the first 3-4 days they upped the price on the rear hub by $20. I assume when things sell to quickly they must have something to cue a price increase.
    They were actually $99 for the rear and maybe $49 for front, Canadian. $20 off if you spend $149 because both were clearance marked! I suppose that makes them closer to $100 USD.
    I keep an eye out now every few days. I managed to pick up a DT 240s rear for super cheap recently - $140 usd. They were up for a couple weeks also.
    • 2016 Banshee Rune
  34. #834
    Nov 2014
    You know the difference between rear 240s and 350 is basically the bearings (stainless vs regular) and a bit more weight shaving on the axle between the bearing stops, right?
    Manual lists different part numbers for the end caps and spacer as well but I fail to see how they're different
    oh yeah, and does anyone know if the framed part is threaded into the hub body or glued to it? I mean, neither is acceptable on a hub of this price, is it?
  35. #835
    mjw
    mjw is offline
    Feb 2007
    Indeed I do know, yes. I'd never pay the MSRP difference to get a set of 240's. But, when they are on super sale and the difference is small, why the heck not? the bearings in the 240's are some of the best in the business. Smoother longer lasting bearings and marginally lighter...not a bad thing.
    The axle configuration in the two is slightly different. The 240's can be converted in some cases. 15x100 can be converted to 20x110 for instance, and end caps play a part in that. The 350 is a dedicated standard which cannot be converted.
    Back to the Poozers. The big draw seems to be 72POE for cheap, but I'd rather less engagement and more reliability. If I were building a budget wheel, or backup set, I'd grab some XT hubs, disassemble, fill with a quality grease, and reassemble properly. I know cup/cone put some people off, but properly packed and assembled, they roll super smooth and are actually pretty tough - more so that most non-contact cartridge bearings found in the vast majority of modern hubs. Total cost, about $80-90 bucks for a set.
    • 2016 Banshee Rune
  36. #836
    Nov 2014
    and 3 xt hubs will get you 72 POE, or more
    now to figure out a way to put them in one wheel
  37. #837
    Land of the 230+
    Sep 2013
    The koozer freehub lasted much longer than any shimano deore/slx/xt I've ever had. I couldn't disagree with you more about XT being a good budget hub.
  38. #838
    mjw
    mjw is offline
    Feb 2007
    Current XT hubs are 36T. That's actually not horrible.
    Again, for me, at that price point I'd prefer reliability over fast pick-up.
    And for reference, I like high POE hubs and have ridden/own some of the best - but I would just rather not feel my hub is a ticking time-bomb.
    It's totally cool if you own Koozers and love them. You are entitled to you opinion, and if you guys have had good experience with them I'm HAPPY to hear it - I wouldn't wish busted equipment on anyone. But, as you are entitled to you opinion, so am I - and as a fairly experienced wheel builder who's seen them fail in person, it's hard to me to see them positively. I'd never lace them for someone, but I'd have no issue lacing up a set of m8000 xt's - the only caveat being that I would tear them down and make sure things were up to spec before sending them out the door. Not really a luxary you are afforded with Koozers.
    • 2016 Banshee Rune
  39. #839
    mjw
    mjw is offline
    Feb 2007
    Have you used the current gen m8000 hubs? Or current gen m9000 xtr?
    They are actually quite good, if you can take five minutes to learn to properly maintain them.
    You'll also find pretty good reviews of the current xt and xtr wheelsets, with positive commentary on the hubs if you look.
    I've seen lots of failure in deore/lx/slx/xt in the past too, but not much in the current generation xt however. Much of this was from people not maintaining the hubs properly. Often they come out of the factory poorly adjusted and with very little grease.
    That said, you look like a burly man as I scroll through your posts, and I gather you're going to be hard on just about any hub. If money were a non-issue, I'd say Onxy hubs would be a great fit.
    • 2016 Banshee Rune
  40. #840
    Im one of the rare few that reliability use shimano hubs. Im also one of the not-rare many that busted a koozer
    I personally like shimano hubs. Ive seen so many failures for other people that its pretty hard to recommend them anymore, I dont know what the deal with the discrepancy is, but it is what it is.
  41. #841
    Apr 2017
    Still no reports of failure of the (ratchet) 470's?
    ps My 490 rear hub is still flawless after 2 years of hard use at 170 lbs. Almost makes me nervous.
  42. #842
    Not as many people bought them. We learned our lesson!
    At 72poe, it was worth taking a risk. At 28poe, it's just another low quality Asian hub.
  43. #843
    Is dang happy!
    DT 350 has a similar ratchet ring mechanisim and only 18poe unless you upgrade the freehub. The 470 is a completly different hub than the 490. My criteria was cheap and loud for this set of wheels. I will still feel dumb if mine blows up... it will not be the first time I took a chance on kooky asian parts, probably not the last. I will get another Hope if it poops the bed.
  44. #844
    mjw
    mjw is offline
    Feb 2007
    Quote Originally Posted by Mr. Doom View Post
    If the ratchet is made from some good Material I suspect they will be reliable. If soft...
    Why the need for loud. I'll never understand that.
    • 2016 Banshee Rune
  45. #845
    Is dang happy!
    I normally prefer quiet hubs but due to the increase of bear activity on the local trails I am looking for the loudest possible. I am more concerned about making noise at speed than enguagment and this hub is twice as loud as my Hope... there is a method to the madness. The BHS mtb270's, XT, Hope pro4 and DT 350 have good track records but are not as loud as the Koozer 470's.
  46. #846
    mjw
    mjw is offline
    Feb 2007
    That has to be the most legitimate reason to have a loud hub yes lol. Bear bells also a great idea.
    I have a 350 with 54T ratched which I find pretty loud also. .Hopes are pretty good also, especially if you just use a light lube instead of heavy grease. 470's to appear loud on YouTube though!
    • 2016 Banshee Rune
  47. #847
    Apr 2017
    If the ratchet material was soft, they would maybe not be so loud?
  48. #848
    Nov 2014
    it doesn't have to be butter soft to suffer in the durability department
    just soft enough to wear quicker and eventually fail
  49. #849
    Srgyoel
    Feb 2018
    I just got the xm470 thru hubs shimano driver in the mail, does someone have the measurements for them so I can put in a spoke calculator, I could find the QR measurements but they don't seem to align with mine
  50. #850
  1. Replies: 2
    Last Post: 04-03-2014, 08:27 PM
  2. Hope hubs vs Stan's ZTR hubs...when the Hopes are cheaper
    By Watarski in forum Wheels and Tires
    Last Post: 09-12-2013, 08:49 AM
  3. Centerlock Hubs - Better than regular 6bolt hubs?
    By mattsmc43 in forum Wheels and Tires
    Last Post: 05-28-2013, 11:46 AM
  4. Anyone prefer freewheel hubs to cassette hubs??
    By vindiggitydog in forum Singlespeed
    Last Post: 03-20-2012, 12:54 PM
  5. Velocity hubs vs Stan's stock hubs
    By 7Wayne7 in forum Wheels and Tires
    Last Post: 02-22-2012, 04:11 PM
Members who have read this thread: 241
