Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 201 to 300 of 850
  1. #201
    Aug 2014
    now this is the bearing that I'm trying to remove
  2. #202
    Reputation: Poopshute's Avatar
    Quote Originally Posted by Forcemajeure View Post
    So, if I'm correct, the axle has a flange in the middle. You would use a rubber mallet to gently tap on the axle and one side bearing should pop out. Repeat for the other side. The video links below were sent to me by "Matt" that works for Reborn (company that makes these hubs).
    https://www.youtube.com/watch?v=oct-egH6CKs
    https://www.youtube.com/watch?v=1cqPeEcYHoY
  3. #203
    Aug 2014
    thanks poopshute.. will check out the links, do i really need to remove the spokes and rims before i can remove the inner bearings?
  4. #204
    Lol... nope! You can do this w/out completely blowing up your wheel. The basic idea is to make sure the Axle is free and has room to "slide out" with the bearing. A vice that's not compressed all the way is a good tool for the job. Use different size sockets from a socket wrench set and the same rubber mallet to press new bearings into place.
    Again, I'm not completely sure this is how the bearings come out but from first glance of my hub, it appears to be the only way. There's nothing threaded on the axle so it has to simply be held in by the pressed bearings.
  5. #205
    Aug 2014
    will try removing the inner bearings if ever rain started pouring down, while it is not raining, i'll go out and use the other bike... thanks for the quick reply.. i really appreciate it..
  6. #206
    Aug 2014
    now this link that you gave me seems to be the best match for the koozer hubs 6 pawls
  7. #207
    Aug 2014
    this link also looks like a good guide
    https://www.youtube.com/watch?v=kpjSclC0STQ
  8. #208
    The second one you posted is a slightly different design where the entire axle comes out with the freehub. The first link is more inline with the design of our hubs.
  9. #209
    Would you mind providing a quick how-to on how you removed the bearings from the freehub body? Also, when you get the bearings out of the hub, can you let us all know how it went?
    Planning on upgrading my bearings next season.
  10. #210
    Jul 2015
    hi all
    just found out about this hubs, and I will like to know if anyone has use them for Freeride or Downhill?
    also, how are holding up the ones around? any problems with them?
    thanks a lot
  11. #211
    Quote Originally Posted by leon78 View Post
    hi all
    thanks a lot
    There's quite a few of using these hubs and no one has posted any issues so far. I ride aggressive XC that leans very much in the AM category. Lots of climbing and I tend to hit/jump over obstacles instead of ride around them on my 26er. Had a bee minor crashes as well. Both the hub and the new wheel build (I'm only rocking the rear) are holding up great.
    I don't know what makes a hub downhill compliant but I can tell you these hubs come in QR and 15mm (front)/142x12 (rear) through axles designs. The axle is also aluminum.
  12. #212
    Aug 2014
    Koozer hubs, 72 POE @ under -asdf.jpgayt here are some pics, took me several hours to complete the task as i wanna take my time and be careful with the bearings and hubs.. will test ride the bike next time
    i forgot to take a picture of the retainer ring, like a washer on the axle ratchet side, you have you use thin metal to pry it out
    1. remove the end caps by using 2 pcs 5mm allen key ( i think it was 5mm )
    2. pull out the free hub body by doing counter clockwise motion
    3, remove the bearings on the freehub body, just, toggle the spacer and gently tap the bearing and it will fall off
    4. remove the retainer or washer like metal ring on the axle you can check both sides to be sure, but i removed the one on the ratchet side
    5. use rubber mallet gently tap the axle, i chose to hit the rotor side first, once out use the axle to remove the 4th bearing
    now i used different kinds of sockets from my socket wrench set, and a threaded rod to act as a press tool, cost me $1 USD
    havn't tried riding my bike, since i also removed BB, cranks, pulley, rotors, rollers, general check up and clean up after a grueling ride on the mountain, trails, mud, heavy rain..
    Koozer hubs, 72 POE @ under -11732042_10153459001844431_1908019021040225626_o.jpgKoozer hubs, 72 POE @ under -11741040_10153459007424431_3676314459789042173_o.jpgKoozer hubs, 72 POE @ under -11754936_10153459012284431_6875684105960859037_o.jpgKoozer hubs, 72 POE @ under -11792136_10153459010884431_4547933318077910118_o.jpgKoozer hubs, 72 POE @ under -11794302_10153459014054431_400056152450664767_o.jpgKoozer hubs, 72 POE @ under -11794382_10153459017189431_3905463602681630234_o.jpgKoozer hubs, 72 POE @ under -11794488_10153459003954431_3935853902128435372_o.jpgKoozer hubs, 72 POE @ under -11807147_10153459015789431_5805527995102833205_o.jpg
  13. #213
    Aug 2014
    the first picture with the red circle like line, that was the retainer that you need to remove, really hard to notice the ring
  14. #214
    Short-Change-Hero
    Reputation: gregnash's Avatar
    So you will have to give us a ride report after you have ridden with the new bearings. Wondering if it would be worth it to just replace the bearings right off with something like SKF or NAICHI bearings (they really don't cost all the much on eBay).
  15. #215
    Thanks for the pics and write-up. I have a few questions that hopefully you can clarify:
    1.). When you say "toggle spacer" and gently tap the freehub body, are you saying to just remove the loose spacer ring and then tap the freehub body itself on a hard surface to let the bearings fall out? Are they not pressed in?
    2.). You mention a retainer ring on the axle. Will the ring dislodge itself when you use a mallet against the axle to force the bearings out? Meaning, is there really a need to remove this ring prior to tapping the axle with a mallet?
    Thanks again for posting your tear down. This is going to help a lot of people here!
  16. #216
    Aug 2014
    Quote Originally Posted by gregnash View Post
    yup will definitely give a report or update after my test ride, but all i can say is that the axle moves smoothly when i tried spinning it by hand, unlike before i can really feel that the bearings were like rough and somewhat like grinding..
  17. #217
    Aug 2014
    Quote Originally Posted by Poopshute View Post
    step # 3 is to toggle the spacer or move the spacer so you can see the inner ring of the bearing, then gently tap the bearing, i used long allen key to pry it out, i don't intend to use the old bearings to for me it is okay to tap on the inner ring of the bearing
    retainer / ring - i think you will have a hard time if you use axle to force the bearings out without removing the retainer or ring
    i just wish that i can record or video shoot the process, but i don't have a digital cam only a xiaomi phone, and got no one to help me out with the video shoot
    the next time i hit the trails, will definitely open up the hubs and shoot a video
    now my problem is the front hub, this one i think is much harder, as i can't remove both end caps
    the axle doen't have hex key slot or can't use allen keys to act as a counter for you to remove the next end cap
    OR DO I JUST remove one end cap and use mallet??
  18. #218
    Reputation: bosbik's Avatar
    Quote Originally Posted by gotdurt View Post
    Success! Koozer 9mm QR fr hub converted to 15mm thru-axle via Stan's end caps...
    Attachment 995473
    All that was needed was a few seconds each on the flat side of the grinder (maybe .5mm each), and they slipped right into the fork. The OD of the o-ring is *slightly* small so they will come out of the bore under their own weight dry, but a touch of grease holds them well. A slightly thicker o-ring could also do the trick, if it isn't too much. Either way, they'll do the job until Koozer comes out with the kit.
    @gotdurt
    did you do just a direct install with the stans endcaps onto the hub? Did you change out the axle?
  19. #219
    Are you sure the end camp is threaded on? My 142x12 rear has end caps that are simply held on by small washers. The QR holds everything together.
  20. #220
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    Anyone have info regarding XD drivers for this hub? Any other brands (Novatec) have one that might be compatible?
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
  21. #221
    Short-Change-Hero
    Looks like the bearings are the exact same used by DT Swiss, found that you can buy a set of bearings for a DT Swiss hub rebuild for about $15. Not sure if they are better than SKF/Nachi/etc. bearings but thought that was interesting.
    Pretty sure I am going to pick one of these up this fall and build it into a wider rim (possibly a 27.5+ rim for my 29er). If I do I will plan to replace the bearings first off.
  22. #222
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    @Forcemajeure
    I couldnt find why you changed the bearings in the first place. Had they given out or did you just change to better quality bearings preemptively?
    Cheers
  23. #223
    Aug 2014
    I'am also not sure, but i think you are right the end caps on the front hub is not locked on the hub, only on the axle, so if i remove the other end cap, i could just gently hammer out the axle and it should be ok.. will re-check if my front bearings need some replacement
    i think the only need to be regrease or check if there's any dirt or anything that gives a rough spin, i just tried spinning the axle after our trail ride and it is really hard to spin, but i appliead some grease and will check next time
  24. #224
    Aug 2014
    Quote Originally Posted by abelfonseca View Post
    @Forcemajeure
    Cheers
    i forgot my reason why i wanted to change the bearings..
    a short story.. bought the koozer september 2014 been using them on roads and light trails..
    now come july 26, i used them on heavy trails, dh, mud, rain and everything..
    I checked my bike and hubs the next day, and found out that the axle on rear and front hubs are quite hard to spin by hand..
    so went on and opened up rear hub, found some dirt, sand, water on the hub..
    tried spinning the axle and it was a lil bit rough not really smooth..
    i think the old bearings can still be used, but we ride on no bail out zones, can't afford to lose a bearing while riding
  25. #225
    Aug 2015
    Quote Originally Posted by Determinants View Post
    I need information about shops here in Philippines who sell koozer hubs.
    Nabili ko yung saakin s "wiley's bikeshop"(search mo nlng s FB) pwede meet-up s sta. Cruz church 4.5k lng
  26. #226
    Merendon Junkie
    Dec 2011
    Just laced a rear koozer 72 POE QR to a carbonbicycle rim. Used sapim laser and brass nipples. Total weight is 810 grams before taping.
    It sounds, sweeeeeezzzztttt!! Wheel feels great. Havent had a chance for a real test ride yet.
  27. #227
    Aug 2014
    had a small ride with the koozer new bearings on rear hubs, ride was only at 10kms on road only
    and i think it runs well, rear hub still smooth, but will try them out next time on trails
  28. #228
    This is just my opinion but if you're going to replace the bearings, why not go with something nicer like an Enduro ceramic bearing? They're double the cost but will perform better. Just my $.02.
  29. #229
    Also... normal store bought mineral oil doesn't stay put in these hubs. I had the fluid leak out after one ride. Sure, some of the oil staid on the pawls but over the counter mineral oil is too light. Trying Dumonde Tech freehub oil. Hope this stuff works as it's pricey!
  30. #230
    Aug 2014
    for me I'm using top 1 synthetic lithium hi-temp grease as BB, hub, headset lubricant
  31. #231
    Reputation: farmdog's Avatar
    Jul 2015
    I just purchased a set of WTB frquencu i23 29" rims and I need to get black spokes and red nipples. I'm going to use the Koozer hubs...what size nipples did you use and spokes?
    Finished building a set for a friend, red koozer hubs, sapim race, stans arch. Here are some pics and hub sound video.
    Attachment 983828
    Attachment 983829
    Attachment 983830
    Attachment 983831
    https://www.facebook.com/uberwheels/...type=3&theater
    Cheers
  32. #232
    Short-Change-Hero
    Spokes and nipples go through Dans Comp for single cut, single purchase ability. Comp style spokes are common but heavier but also easiest to build with.
  33. #233
    Quote Originally Posted by farmdog View Post
    In my research, I found that DT Swiss comp spokes are the go-to spokes for wheel builds. They make chrome and black. Maybe get DT Swiss comp spokes and red nipples from a different source (like Dans Comp)? Sorry I don't have size information. I had a local shop build my wheel for me.
  34. #234
    Short-Change-Hero
    Right but I have not found anything in my limited research that suggests that they are markedly better than a quality steel ball version for justification in the price. Plus I am not a weight weenie so the slight increase in weight is nothing I am concerned about. Granted I haven't done a whole lot of research but in this type of application there really isn't a "need" for ceramic ball bearings at close to/or more than the cost of a quality steel.
  35. #235
    Word... Each to his own. I'm sure the bearings you buy will be sufficient.
  36. #236
    Short-Change-Hero
    So I am curious, why do you feel that the ceramic bearings would be better? Like I said, I have not done a whole lot of research on it but I am curious as to your opinion why they are worth double the cost?
  37. #237
    Aug 2014
    same here i want to switch to ceramic bearings on hubs and BB but i can't find any seller in philippines
  38. #238
    DFMBA.org
    Reputation: MTBeing's Avatar
    When you get those bad boys built up post the pics, specs and the weights if you could. I'm considering the exact same setup.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
  39. #239
    I come from a roller hockey background. Each wheel used a pair of cartridge bearings and we tried to get the highest ABEC rating possible with the least friction possible. Back then ceramic bearings were just being introduced and were not affordable. With inline skates, you could feel the difference in high quality low friction bearings vs. cheapos. I'm just using that experience and translating it to the biking world. I want my wheels to spin as smooth and fast as possible. Investing a few bucks more for bearings I'll keep around for a while (with proper maintenance) is worth it to me.
    I installed an enduro ceramic BB a year ago and my crank free-spin was night and day compared to the stock shimano BB.
    But, would you feel a difference let alone care? Totally up to you. I'm a techy-gadget guy. Like the latest and greatest as long as it's within my budget.
  40. #240
    Aug 2014
    less maintenance for ceramic bearings.. and rust proof, my vote goes to ceramic as well
  41. #241
    Short-Change-Hero
    Ok see what I was read was that the ABEC rating only really applies to super high rpm situations. This is something that what I was reading is more for high speed machinery or vehicles, not bikes.
    With the advancements in technology the ABEC 3/5 bearing that are steel are same surface consistency as ceramic bearings. But yes the ceramic do not rust, but for me I do not live in a super wet area for riding.
  42. #242
    Jul 2015
    Bike hub store has the MTB180 / MTB270 Disc Hubset 15mm thru and 12x142 on sale now for $135 & free shipping...any opinions on these?
  43. #243
    Reputation: Myers005's Avatar
    Jan 2011
    There's an active thread about the BHS hubs Initial Thoughts BikeHubStore MTB270 & MTB180 hubs
    I have 2 rides on my BHS mtb270. So far so good, nice hub.
  44. #244
    Reputation: cerebroside's Avatar
    $135 for the BHS hubs is a great price. I've got both, posted my opinion in this thread: Koozer vs BHS. I will add that the Koozer is a hell of a lot louder than the BHS MTB270.
  45. #245
    Aug 2014
    koozer 6 pawls much louder than my Circus Monkey HDW3
  46. #246
    Aug 2014
    i replaced my front hub bearing a week ago and, all i need to do is remove i end cap, use rubber mallet to hammer down the axle and was able to remove them without issues,
    same method on installing new bearings, i used d.i.y bearing press, same size of bearings
    bearings on freehub body does have a different size
  47. #247
    Reputation: savo's Avatar
    does anyone know the koozers weight?
    they looks very interesting
  48. #248
    I measured 201 g front, 304 g rear for the QR versions, without skewer.
  49. #249
    thanks
  50. #250
    Aug 2014
    Koozer hubs, 72 POE @ under -koozer-hub-ha02n-ha04n-mtb-bicycle-hub-keanho-1508-15-keanho%402.jpg
    koozer's weight with skewers
  51. #251
    Ah,bummer, I see the 142x12 thru axle hub is NOT 6-pawls 72 POE but only 3-pawls
    Koozer 72HD HA02N HA04N Hubs CNC Aluminum 2 4 Bearing 32h Through Axle QC Hub | eBay
    Other sellers don't mention it... anyone has the thru axle version?
  52. #252
    Quote Originally Posted by savo View Post
    Try this one (seller Revmega).
  53. #253
    Aug 2014
    bearings on koozer hubs much easier to replace than the circus monkey hdw3
  54. #254
    Reputation: drakche's Avatar
    Nov 2012
    Just got a reply from revmega that the thru axle hubs are convertible to QR. If anybody is interested.
  55. #255
    Quote Originally Posted by drakche View Post
    good to know.
    does the conversion involve a different axle or just endcaps? and do they sell a conversion kit? can't see it listed.
  56. #256
    Nov 2012
    just endcaps. 10$, they are not listed. you need to contact him and pay the 10$ separately, and he will ship them
    Also spare freehubs are 20$.
  57. #257
    ah... too late, he already shipped my hub. may have asked before
  58. #258
    Nov 2012
    you can contac him and he will ship ou adaptors only
  59. #259
    thnx, will do if i'll need them
  60. #260
    Reputation: funnyjr's Avatar
    Ok so had my Koozer hub now for awhile built to Arch EX rims. It engagement is amazing very impressed. Bit heavier than my DT240, louder and bearings not as smooth. I think if you changed out bearings on the Koozer to some higher end bearings of think it is a great hub for the money and can't be beat. I will upgrade to SKF bearings when mine need replacement otherwise just ride it for now.
  61. #261
    Braaap
    May 2014
    I learned today that a batch of 12x142 hubs received axles with an incorrect ID tolerance (less than 12mm). I contacted Matt/Revmega and he had a replacement hub sent my way same day. I'm thoroughly impressed by both the hub and customer service! It's a real eye opener that Reborn is able to turn a profit on these hubs after both ebay fees and shipping from China!
  62. #262
    Jul 2013
    I sent a email to Revmega. I wanted to see if he sold 12x142mm end caps. He told me you can't go from QR to 12x142mm, But only 12x142mm to QR. But the newer hubs should be able too.
  63. #263
    Reputation: gotdurt's Avatar
    For those that have had the rear hubs for a while, how are they holding up for you? I had an obnoxious creak develop a couple of weeks ago, coming from the rear of the bike under load... checked all of the pivots, looked for cracks in the frame, etc and eliminated the frame as the problem... don't see any obvious external cracks in the hub body, but I swapped wheels with my other bike and the creak followed the wheel, with no creaks on the original bike now. The 2nd bike is a single speed, so it wasn't in the cassette, and I didn't see any visible external issues on the freehub when switching. I guess the next thing will be to tear the hub down when I have time and see if I can find anything, meanwhile I'll continue to ride it in hopes that it becomes a little worse and thus more visible. Maybe I'll get lucky and find that it's a bearing issue...
    Anyway, hoping maybe if any others are experiencing the same/similar problem, we might be able to nail it down.
    'T'is only a flesh wound...
    Some videos
  64. #264
    Jul 2013
    You might have loose spokes on the rear wheel.
  65. #265
    Quote Originally Posted by caRpetbomBer View Post
    That was actually the first thing I checked when I moved on to the rear wheel, but all was good; it doesn't sound like a typical spoke pop/creak though.
    Some videos
  66. #266
    Aug 2015
    https://m.facebook.com/wileybike/pho...pe=3&source=56
    Guys Koozer now have 15mm front tru axle
  67. #267
    Jul 2013
    Quote Originally Posted by niel.evangelista@gma View Post
    I think they had the 15mm front thru axle for awhile now.
  68. #268
    Correct. In all colors too. They've had 15mm versions for quite some time now. Just ordered and received a red one myself. My rear 142x12 6-pawl version is still going strong after a full Summer of riding 3-times a week. Impressive for the cost. Love them so far!
  69. #269
    Aug 2015
    Sorry .my bad... is it good for AM or aggressive ride?? Coz the 9qr one say its for XC ...i'm planning to put it on our giant trance
  70. #270
    I ride my trail bike pretty damn hard. I would consider my riding style aggressive XC and a little AM. I tend to go through/over things instead of ride around them. Tend to bottom out my suspension and all that jazz. Anyways, after a few crashes, the rear hub is still holding up great. I have to muscle up some semi-technical stuff too and the hub has never slipped or given way. I'm very impressed for now. The hubs are very easy to service as well. Everything comes apart very logically and replacement bearings are easy to obtain. For the price, it's kind of a no-brainer. You can buy multiple backup-ups of the Koozer hubs for the price you'd pay for one mid-high end hub... not that you'd need to.
  71. #271
    Reputation: iheartoregon's Avatar
    Apr 2013
    I was going to grab a set of these hubs to build up a wheelset for my cx bike but it doesn't look like they are shimano 11spd compatible yet?
  72. #272
    Shortcutting Hikabiker
    Reputation: Acme54321's Avatar
    Oct 2003
    Quote Originally Posted by iheartoregon View Post
    Shimano 11sp is the same freehub body as 9/10.
  73. #273
    Quote Originally Posted by Acme54321 View Post
    11s mtb (11-40 or 42 cassette) is the same, but 11s road cassettes (up to 11-32) will not mount on 9/10s freehub body.
  74. #274
    Oct 2003
    Yeah, I missed the whole CX part of it LOL.
  75. #275
    Merendon Junkie
    Dec 2011
    I have now logged about 500kms on my rear koozer hub. I have ridden it in the wet, sandy, muddy, dry etc. conditions and several creek crossings (with water level below the hub) and it has operated smoothly so far. I decided to take the hub apart today after a 70 km ride to see how everything was looking. I am very happy with what I saw.
    The negatives: Some scoring due to the cassette digging in. This can be prevented by using a higher quality cassette (xt). I had to pry (carefully) a couple of the cogs off with a screwdriver.
    The good: Grease on the pawls and over the bearings looks very clean. There was no sign of water or dirt under the seals. The pawls look in very good condition. Bearings still spinning very smoothly. Smoother than when new actually. Internal seals look very good. No play on the freehub body, or anywhere else. The hub appears to be very well sealed.
    Some scoring on the freehub body by cheap cassette (deore)
    Pawls in perfect condition as far as I can tell.
    Koozer hubs, 72 POE @ under -koozer2-500km.jpgKoozer hubs, 72 POE @ under -koozer3-500km.jpg
    Grease clean and clear. No water or dirt contamination.
    Koozer hubs, 72 POE @ under -koozer4-500km.jpgKoozer hubs, 72 POE @ under -koozer5-500km.jpg
    Except for the second picture of the zoomed pawl, all were taken before cleaning. Since I had taken it apart, I decided to go ahead and clean the grease an applied some phil wood oil. Now the angry bees have quieted down :-(
    Cheers
  76. #276
    Oct 2015
    Question regarding 10 speed cassetee
    I was wondering if I can use 10 speed cassette on this hub and more specifically for the 40-11 set(17T replacing cog). I will be buying it soon Thanks!
  77. #277
    Aug 2014
    it is possible for the 10spd for the 11spd not really sure
  78. #278
    Merendon Junkie
    Dec 2011
    yes you can use 10 speed and shimano mtb 11 speed.
  79. #279
    Oct 2015
    That's great! Thanks! I'm still debating on whether i should get Sram X9 or this hub. But I don't like the idea of 12 POE. Don't know if the Koozer is gonna stand my type of riding which is enduro/freeride
  80. #280
    Jun 2014
    I currently am riding wtbi23 on x9 hubs. The x9 hubs have held up well for me with all mountain riding, and I weight 235lbs. With my gear. I am building a new wheel set and am considering this hub set also. I love the high engagement but durability is the most important factor for my build. I really can't see any bad feedback online but I would love some feed back from people that are putting these hubs through jumps, steeps, mud and everything else that is truly fun about mountain biking.
  81. #281
    Quote Originally Posted by hobdog31 View Post
    Probably put over 1000 km's on mine this season, all trail riding, no maintenance, often riding in the pouring rain. Jumps, yes, steeps, yes. I try not to ride muddy trails, but they have seen a lot of dirty standing water.
    I'm 180 lb without gear, but they probably get more of a beating since it's a hardtail. Trail in the photo is Comfortably Numb descent in Whistler.
  82. #282
    How are these hubs holding up for everyone? I saw they new have complete wheelsets but I don't know how good the rims are.
    Koozer XM 650B 27 5" MTB Wheelset Wheel 32h 72HD Click Noise 4 Bearings Hub Set | eBay
    Also has anyone built up a 27.5 (650B) wheel yet? I am thinking about getting these hubs with the nuke proof DH rims but I have no clue on spokes
    Nukeproof Generator 275 DH Rim 2015 | Chain Reaction Cycles
  83. #283
    Aug 2014
    no regrets on my Koozer hubs, yeah they are made in china, but so far still rolling
  84. #284
    Mine spin great so far aswell. Seems drag has diminished more with use.
  85. #285
    Quote Originally Posted by DirtMerchantBicycles View Post
    What issues did this produce? Was the through-axle not able to go through? How did you find out about this issue?
  86. #286
    Reputation: zemper's Avatar
    Aug 2013
    @forcemajeure hey nice to see you here too i see you often in pinoymtbiker.org, do you have any idea if the shops at manila already sell 12x142 rear hub versions?
  87. #287
    Aug 2014
    Quote Originally Posted by zemper View Post
    zemper,
    sorry i dont have any idea about the 12x142, koozer in phils now cost a lot more,
    more demand i guess...
  88. #288
    has anyone tried the koozer hubs with the star ratchet/CK copy
    KOOZER MCS 24H Straight Pull Hub XR1600
    Koozer MCS 24H Straight Pull Hub XR1600 Hub Disc 7 EZO Bearing Front Rear MTB QR | eBay
    Seems to one of the few 24 hole 142x12 hubs I can find.
  89. #289
    Aug 2013
    Cool find KevinNZ! Looks new though, I doubt many would have had experience with this one. Lighter than the existing Koozers it seems.
    edit: darn, a 15TA + 12x142 set is about US $160. Kinda expensive for a relatively new product.
  90. #290
    Quote Originally Posted by KevinNZ View Post
    Yeah, great find! I'm going to contact the seller to see if they ever plan on making a 32h version. If you (or anyone) picks one up, please do post feedback. A star ratchet/clutch version for that price is pretty killer! Looks like similar tech as a Chris King at a fraction of the cost.
  91. #291
    Just contacted a Reborn rep. 32 hole clutch/ratchet version will be coming out soon. It will utilize the conventional j-spoke holes which will be easier for a wheel builder to measure out spokes. Too bad I have a fairly new pawl version! Although, I couldn't be happier with the pawl version. It's still running strong.
  92. #292
    Aug 2013
    Oh man, that's both good and bad news... currently trying to upgrade my stock 27.5 wheelset and torn between Koozer and Bitex hubs... J-spokes are good news as these are the most common spokes available here. hope that they make it soon, can't wait to build a proper 27.5 wheelset!!!
  93. #293
    You'll definitely be a guinea pig with these new hubs. I'm sure they'll work great as this Chinese company is really trying to take a bite into the hub market. However, this new hub hasn't been tested much and their current 72 poe pawl version has been ridden by many people, myself included, with great results. I don't think you can go wrong with either version but you'll sure to be happy with their current version. If you do end up going with their ratchet/clutch version, please post up here!
  94. #294
    Aug 2014
    No 32 holes for this new hub?
  95. #295
    Lol. Dude. Read... Three to four posts up.
  96. #296
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Is the mechanical clutch that big an upgrade compared to the pawls? I guess I don't ride hard enough to destroy my freehubs. Still, is it worth holding out for?
    I love the look of the straight pull hubs, but 24 spokes just isn't cutting it.
  97. #297
    Quote Originally Posted by GuitsBoy View Post
    The whole idea behind the clutch/ratchet hubs is based around strength. Pawl versions usually have about half the pawls engaged at any given time (so 3 speaking of the Koozer hubs). With a clutch system, all "teeth" are engaged whenever you pedal. There's a VERY low chance of ever "spinning" a clutch/ratch hub. Ok, with that said, I ride my bike pretty hard. I weigh about 210 fully geared and haven't had a skip or a failure in my pawl version hub. Yeah, the clutch/ratchet system looks awesome and I may have held out for it if I hadn't already bought/installed/ridden the entire season the pawl version. Reborn (the people who make these hubs) state that the 32H version of the clutch hub will be a j-spoke design. I actually prefer that as the straight pull spokes are not readily available and the lengths are very specific to the hub dimensions. J-spokes are very readily available and sizes are fairly standard with a few measurements of the hub. I guess the straight-pull design is supposed to be stronger since there's no bend but with some high quality spokes like the DT-Swiss comp j-bend spokes, you should rarely (if ever) break a spoke unless you hit it super hard on something.
    I do agree that the straight pull design is pretty sweet looking.
  98. #298
    Land of the 230+
    Sep 2013
    Yeah, I googles and found http://www.rbn.hk/?lang=en and I knew what you meant by reborn rep. Did they give you any inkling as to the time frame or the price? I assume it going to be priced similarly to the straight pull version that's out now. The 93 dollar price point is what makes these things so appealing, but once you get close to doubling that, theres many other options, though none that include a mechanical clutch as far as I know.
    I hear the straight pull are a ***** to get started as well, since they just spin and spin and spin. Maybe in a few more years theyll become more prevalent...
  99. #299
    If you look for the seller "revmega" on eBay, he's a legit Reborn rep. He goes by Matt. Contact him for any information. He didn't give me a timeframe but I also didn't push for one since I'm not really in the market to buy one. I do agree that I think the price will be close to what the 24h version is. There's no way they would sell as many of these hubs as they do if they were anywhere near the price of comparable hubs that can be bough in the US. I really don't see it being anywhere near $200. I'm assuming it'll be in the $120 ball park which for a clutch system hub is a pretty great deal. Even their 6 pawl 72poe hubs they currently sell for $60 is a really damn great bargain for what you get. A comparable hub with anything near 72 POE is going to cost you at least $150.
  100. #300
    Braaap
    May 2014
    Wow, already a new hub and clutch design! And Japanese bearings. Never heard of them (EZO) but the Chinese NBK bearings are meh.
    Still waiting on a XD driver though. A couple weeks has turned into a couple months, oh well.
  1. Replies: 2
    Last Post: 04-03-2014, 08:27 PM
  2. Hope hubs vs Stan's ZTR hubs...when the Hopes are cheaper
    By Watarski in forum Wheels and Tires
    Last Post: 09-12-2013, 08:49 AM
  3. Centerlock Hubs - Better than regular 6bolt hubs?
    By mattsmc43 in forum Wheels and Tires
    Last Post: 05-28-2013, 11:46 AM
  4. Anyone prefer freewheel hubs to cassette hubs??
    By vindiggitydog in forum Singlespeed
    Last Post: 03-20-2012, 12:54 PM
  5. Velocity hubs vs Stan's stock hubs
    By 7Wayne7 in forum Wheels and Tires
    Last Post: 02-22-2012, 04:11 PM
Members who have read this thread: 254
