Results 1 to 12 of 12
    Kenda Small Block8 or Nevegal?
    I've read the reviews on both tires and am leaning towards the small block. I'm currently running Specialized Fast Trak LK 2.0(came stock). I'm looking for more grip. Mainly riding hardpack but some lose rock and semi wet conditions as well. Once a week or so I try to get in a 7-14(depending on if I ride the loop twice) mile road ride in a Natl. park. So, in all, 1 trail ride and 1 road ride/week.Which tire will have the best life span based on my riding?
    Reputation: thesuperone's Avatar
    Nov 2006
    For life span
    For life span on a road & dirt combination, I would say the small block 8s. Or maybe you should try; small block in the back and Nevegal in the front, thatís the combination I use. Get the best of both worlds!
    May 2005
    f you like road riding more than trails, use the 8s but your trail riding will suffer on descents. (You will have rear tire loss of traction)
    Stick-E Nevegals on trails are great, but on roads they stick like glue and wear fast
    Or compromise with Nevegal Dual Compound Tread (TDC) tires, which work well in both situations
    SB8 for the rear and then alternate Nevegal and SB8 for the front depending on conditions.
    I run a SB8 in the rear couldn't imagine one up front, seems like it would wash out easily.
    Thanks for the advice. SB8 rear and Nevegal up front seems to be the consensus.
    PB(or anyone that can answer)- What is the difference between the Stick-E and DTC Nevegal? Were you suggesting that the DTC would be suitable for trail/road as it relates to performance and wear?
    Thanks!!
    May 2005
    Stick-E Nevegals have the same rubber compound through out the width of the tire. It is a durometer 50. The lower the number the softer the rubber, BTW. The DTC tires have a rubber compound that is a durometer of 60 on the center of the tread. 60 is slightly harder and lasts much longer than 50. DTC shoulder tread are 50 durometer to stick to the trail during turns. Of course you have a compromise with the DTC tires as on wet roots, they slip easier than the Stick-E tires.
    Thanks for the response- great explanation! So, in your opinion, would I be better off with the DTC's front and back or a SB8 rear and DTC front?
    SB8's on my bike front and rear never washed out the front, grip is awsome in pretty much all conditions, only when its really muddy do they let me down, I'm really suprised how good they have been, even fine in snow , I have them on my 07 Heckler,
    I have DTC Nevegal, and sticke, don't consider them to be as good as SB8, Kenda blue groove is also an excellent tire great on the front. DTC not very grippy on wet rock.
    I run SB8s fall/winter/spring when I'm riding urban and hardpack - they corner like nothing else! SB8 is good up front, just not in loose/muddy conditions.
    What size? I currently have the Nevegal DTC 2.1 in front, and I just got the SB8 2.1 in back. Since I switched to the Nevegal, I swear I've become a better rider. the SB8 looks so skinny, but I got it tol make me faster on the climbs. I ride XC 50/50 singletrack and fire road in dry and dusty SoCal. I'm going to run them both at 35psi and I weigh 190lbs without gear.
    What are the pros and cons of using the 2.35 for both? I'm assuming better traction, but more rolling resistance and rotational weight?
    Quote Originally Posted by mtbdan
    Yes and yes but with the added volume it adds some cushion to your ride.
