Results 1 to 34 of 34
    Reputation: kevingp's Avatar
    Mar 2012
    Kenda Slant Six, Have you tested them?
    I just bought a pair of slant six tires online. I was wondering if someone had used them in sandy, and hard soil? How's the grip, handeling?
    Lot's of reviews out there, use the search
    Reputation: akt42's Avatar
    Jan 2011
    Rode them all last season in CO. Wicked! My favorite rear tire so far.
    Mar 2012
    I've heard good things about them. Lots of positive reviews.
    I think I am going to put one on the rear to counter my slow rolling Nevegal. I love the cornering and front end grip of the Nevegal but hate the high rolling resistance.
    "Your opinion may vary, but it's stupid." -Rich Dillen
    Mar 2012
    Quote Originally Posted by Paul.C View Post
    I've read that a bunch of people use slant six on the back and nevegals on the front. Too bad my tires have shippe already.
    I use one on the back with a nevegal on the front on one bike. And at both ends on another. Tubeless 28psi rear 25psi front. Great tires
    Seeking MB-2 Fork (19.3), Ritchey FD post silver 26.8
    How did your kenda set up tubeless? Any tricks or is it pretty strait forward? I am planning on running a slant six and a SB8 and I want to set them up tubeless but kenda says no. I am using a brand new crank brothers wheel set so no need for a rim strip. Just wondering how many people are having luck running kenda tubeless.
    Mar 2012
    I bought a crankbrothers wheelset with kenda tires and shop says they will work.
    Reputation: Poopshute's Avatar
    Quote Originally Posted by mtb4146 View Post
    I have the same setup... Nev up front and a Slant Six on the back. Both tubeless. Are you asking about the UST versions or the SCT version of the Slant Six? The UST is a true tubeless tire that's heavier than the other versions. The SCT is Kenda's tubeless ready version AND is "permitted" by Kenda to allow sealant (Sealant Compatible Tire). I've been running UST versions of the Nevegal with Stans sealant for over a year now (even though Kenda says the warranty will be voided). No problems whatsoever. I just setup the Slant Six UST the same way. Only had the S6 for a little over a week riding primarily on gravel paved trails (conditioning rides). At ~45 psi, they're doing just fine and initial reports is that they role faster than the Nevegal I had on the back. Still, the tire is so new that I can't give an accurate review of how they compare to having a Nevegal in the rear. I can tell you that the UST S6 mounted to my Bonty TLR rims pretty smooth. Needed about 55 psi with a compressor to get the bead to pop but I was expecting that from mounting the Nev's. Pressure wise, they've been holding strong not leaking anything. Again, I'm using the UST version which better not have any leaks to begin with!
    I should also mention that Kenda now has an SCT version of the SB8. I'm assuming you're going for speed and weight may matter to you. If that's the case, go with the SCT versions of both and juice away.
    Jan 2011
    I ran the non UST slant six tubeless on the rear all last season. 28psi, n o problem at all, sealed up like a dream. I live and ride in the Colorado Rockies. 2 endurance races and countless training miles on them and not ever the slightest hickup. I am running them on DT 4.1 rims with Stan's yellow tape and Stan's sealant . Best setup I've ever run. The shape of the tread works like a mini paddle in sandy conditions and has really low rolling resistance. Will probably get another one when this one is done. Won't be long now.
    Dont own any UST Kendas but also run them tubeless. I figure Ill wear em out before I degradation probs.
    Reputation: fixgeardan's Avatar
    Hows the side walls? I seem to be hard on side walls. Alsp hows the volumn are they true to size?
    I dont run very much in the rocks, so I cant weigh in on that one.
    Meh. I tried them and had high hopes because I love the Nevegal but not the slowness. I was not that impressed. It is a great tire for hardpack and the like, but here in south Florida with the sugar sand forget it. They felt twitchy to me because of such a round profile and until it layed over and caught the side knobs it wouldn't grip. If I was not in Fl I could see it being a great tire, but I am back to Ignitors.
    Mar 2012
    These tires arent good in sandy soil?
    Quote Originally Posted by firebike7 View Post
    What pressures are you running? Im up on the cape in Mass and have lots of sand. Seem to track great,
    Mar 2012
    Quote Originally Posted by trodaq View Post
    Are you using them for both front and rear?
    I've been reading a lot about tires since I want to replace mine.
    Lots of comments, good and bad, but dont know if they are from people that ride in sandy conditions.
    I'm looking at different tires right now.
    Slant Six
    Nevegals
    Velociraptors
    Ignitors
    Cant decide.
    I have them front and rear on my Superfly.Was running just on the rear with a Nevegal up front in the snow. The Slant 6 packed up real fast and became a rolling snowball. I have tone on the front of my SS 29er. I ride a lot of sandy single track incl soft sand toward the beach and they do just fine. Once the front pressure is around 30 they start to act less stable. I run Nevegals front and rear on 2 other bikes. Definately a slower tire but grippy as hell
    PS All the 29ers are the 29x2.2
    Mar 2012
    I currently have Schwalbe nobby nic, they came with the bike. I've read some good things about these. Should I keep these or mix the slant six on the rear with nobby on the front?
    Keep playing with the pressures and see if you can get the feel you're looking for. If you cant get the NN to do what you want or its worn. I have no problem recommending the Slant6
    Mar 2012
    I'll use the slant six when I get them to see how they compare to the nobbys. I like my current tire the slant came with the wheels i bought.
    Mar 2012
    Wow, tires are great even in front and rear setup. I rode yesterday a trail near the beach, the terrain varies from hard packed to loose over hard to super loose sand (usually when dry) with rocks here and there. I used to ride with nobby nics which is a great all around tire, but these kendas grip really nice to anything in their way. Im running them tubeless and I love the feeling of this tire, still need to work on my confidence over sand but thats another story. They corner great, roll fast, they are not the lightest tires but I dont really mind that. If you are planning to get these I sure recommend them.
    Reputation: TheMutt's Avatar
    Quote Originally Posted by kevingp View Post
    I run them front and rear also. They corner real well even in sand, but they amaze me how fast they roll. I switched to them from Small Block 8's and haven't looked back.
    They don't work so well when the trail is wet, but they're still not horrible.
    Setting them up tubeless was a breeze too.
    Mar 2012
    Im having trouble setting them up tubeless. The front tire keeps loosing air. I was told that i need to keep applying sealant until the tire fully stretches.
    My wife has them and loves them. I ran them but the sidewalls were way too thin for me, other than that i thought they were great. I may give them a try again with the SCT.
    With that said are the SCT a thicker sidewall than normal?
    Providing you're sure you installed the strip correctly. You can try using a soapy rag to wipe down the tire and see if air is coming out of the sidewall. If so you can try adding more sealant. Also, with the wheel off spin the tire slowly so the sealant flows along the inside of the sidewall.It will eventually seal. Sometimes a good rough ride will do the trick
    I have been running Slant Six 26 x 2.35" for roughly 250 miles of rocky single track and overall I am impressed. They are the DTC so only have the sticky on the side knobs and I am just now seeing where the sides are being either worn off or torn off. I have noticed a big difference in performance as a result. The center knobs are in good shape as with the far outside, the ones on the side aren't doing so well. I have run Nevagals front and back and switched to these as I had the same problems with the Nevegals of tearing off the side knobs as well. I thought I might get longer usage out of these, not really the case. AND once the first knob goes the others quickly follow. I am not running tubeless and run at 36lbs. I could post pictures if someone was interested.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have the Slant Six on the back and like it a lot. I'm running a Psycho Genius up front. Good combo for me.
    I like turtles
    Jan 2009
    For XC racing I didn't care for them. They are to heavy to be that much of a slick. There are many other manufactures with better traction, equal rolling and lighter weight. I am running the Crossmark instead. They did however setup well tubeless
    Mar 2012
    Quote Originally Posted by Drider85 View Post
    That will be my next tire. Talked to a guy that had them on the trail and said the same thing.
    Mar 2013
    Great rear tire!! I used it for 3 endurance races (Cohutta 100, ORAMM 65, Fools Gold 100)
    Possitive: Great grip, great climbing traction hard walls.
    Negative: Wear out really fast
    Great tiree
    Nov 2013
    I got them on my bike and had issues with setting up the tubeless they weeped out the sidewall. Put a bunch of sealant (Stans and I know but I have never had an issue with any warranty at my LBS as I rarely ask for it and they know me well)in and they ran fine. After 350 miles I started noticing the center knobs on the rear were wearing way down less than half the original compared to up front. I run in the street about two miles between the trail and my house or one mile each way. They did not grip as good as I would have like in the steep loose stuff on technical climbs. I thought they were ok but with the rear losing knobs and an already dubious grip on some of my climbs I have retired them.
