Results 1 to 3 of 3
    Kenda Nevegal vs Tioga DH Size Comparison
    Does anyone know if the Kenda Nevegal 2.35 will fit swing-arm of a Titus LocoMoto? I can currently fit a Tioga DH 2.1 but not the Tioga DH 2.3. The Tiogas seem to run large compared to other tires. Does any have an opinion about these two models for dry/loose/hardpack?
    Ft. Collins, CO
    Chillin the Most
    Based off the specs on Shiggy's tire site, the Tioga 2.3 DH rear tread measures 2.29, while the Nev 2.35 measures out at 2.39.
    You might just go to a 2.1, which should fit and still be a decent volume (as big as most other 2.3 tires).
    Either BlueGroove or Nev will work, but for those conditions, the BG might be a bit better choice (faster rolling and likes hardpack). Nev favors loose conditions.
