IRC Mythos xc II- tubeless setup
Has anybody tried these with stans? Do they bleed out the sidewalls? I would like to try a set of these, I havent run them before.
I've used wire beaded XC II's...they worked fine. They did weep a little but nothing major. Stans doesn't recommend their folding bead versions. I ran a set of the original Mythos XC folding bead tires on UST wheels back in 2003 and they burped several times before I cut a sidewall on them.
- You may not post replies
- You may not edit your posts
Forum Rules
