Inner Tube Quality
Printable View
  • 12-23-2012
    drjay9051
    Inner Tube Quality
    Being new to mountain biking I decided to learn how to change a flat and carry proper tools. Purchased Q tube thorn resistant inner tubes but they are VERY heavy so i'm returning them.
    In Dick's Sporting Goods today picked up a couple of Avenir tubes at $6.99 each.
    Got home and decided to pump them up to assure they were not defective.
    When i inflate they each have an area where the rubber bulges. Not a small bubble but the entire tube for an area about 5-6 long is bulged. No leaks after 10 minutes just not uniform in shape.
    Is this normal? Will the tube regain proper shape when inside a tire and inflated?
    If these are not good tubes what do you all recommend in a tube?
    Thanks.
  • 12-23-2012
    shiggy
    Thanks.
    Entirely normal. The tube just enlarges to fit the tire.
  • 12-23-2012
    drjay9051
    Thanks for the help, Shiggy. Not a whole lot of reviews on tubes !!
  • 12-23-2012
    skyak
    Before I went tubeless, I personally always had very good success with the Continental MTB Light Tubes. Usually around $9 each, reasonably light at 130 grams and made for tires up to 2.5".
