Results 1 to 11 of 11
    Ride Instigator
    Reputation: Ricko's Avatar
    I'm TUBELESS! ... so do I really NEED sealant?
    I laced up a pair of Mavic XM819 UST rims to my King hubs and and mounted up some Maxxis Ignitor UST tires. I went for a little street spin last night after I got the bike back together and just to expiriment, I aired up the tires and didn't use any of the Stans sealant that I have here. The tires held air and I just checked this morning and they're still holding air. I'm just wondering if sealant is really necessary with a UST setup like this and if anyone else out there runs without. I'm all about keeping things simple and not using sealant is one less step.
    Any thoughts?
    Unfit Norwegian
    Reputation: Dazed's Avatar
    Ust doesn't require sealant, but it can be useful for puncture resistance.
    Dec 2011
    Reason i went tubeless was for small puncture sealing.I rode over goatheads last year and i flattened both tires very fast.There werent enough patches in a kit to repair it either.
    Tubelss with no sealant wouldnt have been any bette.Tubeless with sealant would have sealed the thorn holes as i rode away
    LMN
    LMN is offline
    You don't need but it does improve a UST setup. Obviously sealant is going to help with small punctures. The other side benefit, is your tire will not lose air as quickly. Your standard UST, without sealant, can lose air fairly quickly (like over night). Adding sealant slows this process down.
    One down side to sealant is it adds weight, if that matters to you. Two scoops of Stans comes in at 120grams, or 240 grams for two wheels. You got spend a lot of money save 240 grams.
    "The best pace is suicide pace, and today is a good day to die." Steve Prefontaine
    Unfit Norwegian
    Ust tires and tubes add weight too, btw.
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    Im not a fan of UST myself because the additional weight doesn't seem worth it to me. Especially if you are using sealant.
    I wouldn't run any type of tubules without sealant since puncture proof is nice to have
    I do all my own stunts, but never intentionally...
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    I ran tubeless with Stans for about 3 yrs. The ONE time I punctured and NEEDED the sealant, it failed me. And it was a small puncture in the tread area, not a sidewall gash. Luckily was only a 2 mile walk back to the parking lot (I didn't have a tube with me).
    I've recently switched to full UST (my wheels were always UST as I dislike the whole strips deal) with some Maxxis High Roller 26x2.35 UST. Not using sealant and not looking back either. I switch tires often and the sealant is just plain messy. The HR's are a tad heavier (~890g) but not bad - especially for trail/AM. Insanely easy to mount and inflate with a floor pump (I used a Joe Blow Mountain pump). Literally a couple minutes to mount and inflate. No compressor needed. The JB Mountain pump is a big bore high volume pump - so that helps.
    My UST setup has held air for MONTHS so I'm not worried about leak down. I've had worse leak down with tubeless ready tires (Contis) and Stans than with Maxxis' UST. Different tire/rim combinations might lead to different results but that's my experience so far.
    Santa Cruz Hightower LT
    EVIL Following
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    Many people ride UST without sealant. They're usually much more puncture resistant than TLR or standard tyres. And if you make a hole you can just patch it up from the inside same as you do with Tubes and ride on.
    So you can run UST tires without tubeless, doesn't mean it's a good idea. It takes 2 minutes to dump some Stans/Etc. You only have to remove 1 bead.
    I see no reason NOT to do it.
    Unfit Norwegian
    UST is older than TR/Stan's etc, and was designed for use without sealant, so it's OK, but as I said, a little sealant for puncture resistance is a good thing.
    ZEN RIDER!
    Reputation: Mt.Biker E's Avatar
    Mar 2006
    weight weenies crack me up lol.
    sealant is a good thing for punctures.
    I also carry rubber roof repair tape for rv's in my pack.
    It seals up larger sidewall issues and its easy to use & sticks to rubber easily.
    Life in every breath
  1. Tubeless sealant failure
    By likeaboss in forum Wheels and Tires
    Last Post: 10-01-2012, 07:37 PM
  2. when to replace sealant for tubeless set-up
    By sponger in forum Beginner's Corner
    Last Post: 07-23-2012, 05:02 AM
  3. OKO sealant for tubeless conversions
    By TigWorld in forum Wheels and Tires
    Last Post: 05-15-2012, 08:53 PM
  4. Tubeless: When to refill sealant
    By pointerDixie214 in forum Wheels and Tires
    Last Post: 07-24-2011, 09:30 PM
  5. Non UST Tubeless without sealant?
    By bushido5 in forum Wheels and Tires
    Last Post: 01-25-2011, 10:17 AM
