Results 1 to 9 of 9
    Mar 2013
    I know the spoke length but not the ERD
    The drive side is 3.0mm X 252mm
    The non-drive side is 3.0mm X 254mm
    My wheel is 3x 24 spokes
    I'm planning to replace my rear hub with Circus Monkey HDW3 or HDW2. Currently using crappy Shimano FH-RM-40 . I think I need new spokes too. But i'm not sure how long I need. Here an image of the HDW3 hub measurements If someone can help me calculate the length that would be nice.
    A wheelist
    Reputation: Mike T.'s Avatar
    That's a very original question. That would be quite a calculation for someone to do and you're willing to trust their answer? If so, you have more nerve than I have. The safe way is to measure your own ERD and even the hub dimensions.
    Mike The Bike's home wheelbuilding info - dedicated to providing Newby wheelbuilder information and motivation.
    Mar 2013
    Quote Originally Posted by Mike T. View Post
    Thanks for the quick reply. Sorry, the link didn't work for the hub measurement. Here's the new hub measurement http://www.circusbike.com/upload/news/71.jpg and PCD http://www.circusbike.com/upload/news/70.jpg can you tell me the Hub Center to Flange Center from that image? Because i'm not sure what i'm looking at.
    I will try to find out the ERD for my rim.
    A wheelist
    Quote Originally Posted by enyceckk101 View Post
    I don't ever trust any measurements unless I take them myself.
    And for me that would also be from the same source as above.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    are you planning to build this wheel yourself?
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Quote Originally Posted by meltingfeather View Post
    Yes. But after all the research, I think i'm getting a new rim that has erd label on it (ofc measure again just double check). Then calculate the spoke length. Might get an Alex rim with 32 spokes hole and doing 3x pattern. With a HDW2 hub.
    Thanks for the help btw
    Reputation: Shalom's Avatar
    Nov 2008
    Buy this, read it, take your own measurements and build your own wheel.
    Manufacturer ERDs are often not quite right.
    Reputation: gmats's Avatar
    Apr 2005
    Aloha eny,
    Interesting question though I can see your motivation of not wanting to get any more parts then you need to.
    I guess you can do an internet search for the rim you use. Which rim by the way, maybe someone already knows this. I guess you posting the question here technically constitutes "internet search" of some sort.
    So I am attaching a .pdf file with a "how to" on my method for calculating ERD. It requires some tools but not much cost. The idea to me is because I live so far away from most "shops", I want to be sure of the rim's ERD before I order spokes. Even if it's a big name manufacturer, verifying is useful.
    ERD How To.pdf
    Then, you can go on to this link and calculate the spoke lengths you'll need:
    Spocalc, by Damon Rinard. A free Excel spoke length calculator.
    Or, there are a number of "online" spoke calculators around.
    I hope this helps, good luck with that. Chime back in and let us know how it went, what your (learning) experiences are.
    Mar 2013
    Quote Originally Posted by gmats View Post
    Aloha eny,
    ERD How To.pdf
    Great info! Thanks.
  1. Please help with spoke length!
    By nicksstorm in forum Wheels and Tires
    Last Post: 10-18-2012, 12:43 AM
  2. Nipple length affecting spoke length?
    By wilonpill in forum Wheels and Tires
    Last Post: 09-09-2012, 06:28 PM
  3. Spoke Length
    By jbsmith in forum Wheels and Tires
    Last Post: 01-04-2012, 03:37 AM
  4. Spoke Length
    By Kiwimtbker in forum Wheels and Tires
    Last Post: 08-05-2011, 04:53 AM
  5. spoke length
    By GOONRock in forum Wheels and Tires
    Last Post: 01-18-2011, 04:13 PM
