Results 1 to 8 of 8
    www.derbyrims.com
    Reputation: derby's Avatar
    New question here. Hub brands having convertible axle compatibility?
    What are some quality brands of hubs which have both front and rear hub which can convert to all the "standards" of axles.
    Front: QR skewer, 15mm, and 20mm, convertible hub with compatible forks.
    Rear: QR skewer, 10mm though axle, 12mm x135, 12mm x142, convertible hub with compatible rear dropouts.
    I think 12 x 150mm rear hubs are never convertible.
    Church of the Wheel
    Reputation: mtb143's Avatar
    Hadley, Hope, King?
    "I thought you'd never love me without my Mojo." -Austin Powers
    DT Swiss, I9, Stans.
    usually cranky
    Reputation: b-kul's Avatar
    sun ringle, halo, azonic, superstar, transition, novatech
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Stan's front hub needs to be HD variant to use 20mm insert...
    Reputation: TwoHeadsBrewing's Avatar
    Hope Pro 2 Evo hubs can do all axle standards. The DT Swiss 240s front can, but the rear I believe does not convert.
    "Got everything you need?"
    www.derbyrims.com
    Thanks everyone... this helps narrow my search a lot
    And with maximum axle conversion hubs, I'm also interested in fast engaging, about 60 clicks of engagement per revolution or more. For safer rock climbing, pedal timing and back pedal ratcheting.
    Church of the Wheel
    Many good choices, but I'd give highest personal recommendation to Hadley. DT Swiss second only because of personal Hadley preference. Everything else third and I will only use if I get a killer deal on them.
    Are these for an Ibis, perchance?
  1. Replies: 9
    Last Post: 11-18-2013, 06:46 PM
  2. Replies: 15
    Last Post: 11-24-2012, 09:30 AM
  3. Rear Axle Compatibility?????
    By bowler1 in forum Wheels and Tires
    Last Post: 05-12-2012, 07:00 PM
  4. QR15 skewer compatibility across brands
    By aussie_yeti in forum Shocks and Suspension
    Last Post: 05-23-2011, 04:55 PM
  5. ST BB axle width compatibility
    By PissedOffCil in forum Tooltime
    Last Post: 01-11-2011, 11:39 AM
