Results 1 to 12 of 12
    May 2012
    How much spoke head clearance is required?
    I can't seem to find anything, but that it should be a positive number.
    A set of 28h rims I am about to build up will have 1.2mm of clearance with a 3x lacing. Is that enough clearance?
    2x will give me 5.8mm
    Thank you
    Jan 2014
    No idea what you're talking about.
    Why don't you use spoke length calculator and determine the spoke size you need? Post the numbers here, we'll help you.
    May 2012
    I did use a calculator, hence how I know I have 1.2 mm of clearance. It is how much room there is between the spoke crossing over the first cross spoke head.
    May 2012
    How much spoke head clearance is required?-screen-shot-2018-04-15-5.56.59-pm.png
    Jan 2014
    No thread should be showing and no spokes should be sticking out on the other end.
    Use this link, its far less confusing and straight to the point:
    https://www.prowheelbuilder.com/spokelengthcalculator
    May 2012
    I don't think we are on the same page. I am referring to when a spoke crosses another spoke it can cover up the spoke head making removing a broken spoke a PITA. I am not talking about spoke thread length. There is nothing confusing about Roger's calculator that I posted
    Jan 2014
    I would never use "spoke head clearance" as the guide whether to do 2x or 3x.
    In all normal hubs you'll have no issues removing spoke, unless you're lacing 24h rims with 3x, but in all other cases don't overthink it.
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by yourrealdad View Post
    This is why 2x is commonly used with 28 or 24h hubs. My thought is you'll be ok, but I don't know how much clearance you need? I'm not very familiar with that calculator or the measurement in general.
    I just laced my first 28h rear wheel 3x and it worked out ok. I wasn't sure it was going to work once I had the wheel laced and no tension on it, just looking at it. Once I got some tension on the spokes I knew I was safe.
    If you haven't ordered spokes yet you can go 2x to be safe, otherwise it may be a bit of a roll of the dice, but like I said I think your OK.
    Rigid SS 29er
    Hardtail 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    bikes don't have motors
    Reputation: life behind bars's Avatar
    May 2014
    I'd go 2x just to reduce the spoke angle, but that's just my preference.
    Quote Originally Posted by me View Post
    Of all the paths you take in life, make sure that most of them are dirt.
    May 2012
    I am fine with going 2x. Actually find it interesting that both replies so far have been for 2x. Usually I feel like everyone is screaming 3x is the only bestes way
Name:	Screen Shot 2018-04-15 at 5.56.59 PM.png
    As long as the clearance is positive it will be fine. Take a look at the help page (in the spoke length data, click the heading "Spoke head clearance").
    The spoke entry angle is okay too, so no problem with 28h 3x,
    Also, you have selected a 2mm diameter spoke. Are you sure that's correct? For more info, click the heading"Spoke dia." to make sure.
    May 2012
    Roger,
    Wow, I feel like an idiot. I have been using your calculator for a while and never knew you could click on the different headings. And no, 2.0 was not correct. I will be using cx-rays so 1.5. I thought the spoke diameter was for the ends, but it is the middle section?
  1. How much weaker are 28 spoke rims vs 32 spoke likely to be?
    By trail-blazer in forum Wheels and Tires
    Last Post: 10-10-2017, 09:17 AM
  2. Required Spoke Length. HALP??
    By MPX309 in forum Wheels and Tires
    Last Post: 02-22-2015, 06:23 PM
  3. Replies: 16
    Last Post: 01-28-2014, 10:32 AM
  4. How much is too much standover clearance?
    By Belvedere in forum 29er Bikes
    Last Post: 03-01-2012, 12:38 AM
  5. XT M785's: required spoke lacing direction?
    By happyriding in forum Brake Time
    Last Post: 09-29-2011, 11:25 PM
Members who have read this thread: 43
