.0808" is 12AWG (American Wire Gauge)
Lifted from Sheldon Brown's Web site at
http://www.sheldonbrown.com/wheelbuild.html#spokes
Spoke Gauges
The diameter of spokes is sometimes expressed in terms of wire gauges. There are several different national systems of gauge sizes, and this has been a great cause of confusion. A particular problem is that French gauge numbers are smaller for thinner wires, while the U.S./British gauge numbers get larger for thinner wires. The crossover point is right in the popular range of sizes used for bicycle spokes:
U.S./British 14 gauge is the same as French 13 gauge
U.S./British 13 gauge is the same as French 15 gauge
Newer I.S.O. practice is to ignore gauge numbers, and refer to spokes by their diameter in millimeters:
U.S./British 13 gauge is 2.3 mm
U.S./British 14 gauge is 2.0 mm
U.S./British 15 gauge is 1.8 mm
U.S./British 16 gauge is 1.6 mm
Spokes come in straight-gauge or swaged (butted) styles. Straight gauge spokes have the same thickness all along their length from the threads to the heads.
Swaged spokes come in 5 varieties:
Single-butted spokes are thicker than normal at the hub end, then taper to a thinner section all the way to the threads. Single-butted spokes are not common, but are occasionally seen in heavy-duty applications where a thicker than normal spoke is intended to be used with a rim that has normal-sized holes.
Double-buttedspokes are thicker at the ends than in the middle. The most popular diameters are 2.0/1.8/2.0mm (also known as 14/15 gauge) and 1.8/1.6/1.8 (15/16 gauge).
Double-butted spokes do more than save weight. The thick ends make them as strong in the highly-stressed areas as straight-gauge spokes of the same thickness, but the thinner middle sections make the spokes effectively more elastic. This allows them to stretch (temporarily) more than thicker spokes.
As a result, when the wheel is subjected to sharp localized stresses, the most heavily stressed spokes can elongate enough to shift some of the stress to adjoining spokes. This is particularly desirable when the limiting factor is how much stress the rim can withstand without cracking around the spoke hole.
Triple-butted spokes, such as the DT Alpine III, are the best choice when durability and reliability is the primary aim, as with tandems and bicycles for loaded touring. They share the advantages of single-butted and double-butted spokes. The DT Alpine III, for instance, is 2.34mm (13 gauge) at the head, 1.8mm (15 gauge) in the middle, and 2.0mm (14 gauge) at the threaded end.
Single- and triple-butted spokes solve one of the great problems of wheel design: Since spokes use rolled, not cut threads, the outside diameter of the threads is larger than the base diameter of the spoke wire. Since the holes in the hub flanges must be large enough to fit the threads through, the holes, in turn are larger than the wire requires. This is undesirable, because a tight match between the spoke diameter at the elbow and the diameter of the flange hole is crucial to resisting fatigue-related breakage.
Since single- and triple-butted spokes are thicker at the head end than at the thread end, they may be used with hubs that have holes just large enough to pass the thick wire at the head end.
Æro (elliptical) spokes are a variety of double-butted spoke in which the thin part is swaged into an elliptical cross section, which makes them a bit more ærodynamic than round-section spokes. The most widely available spoke of this type is the Wheelsmith Æro. These are 1.8mm (15 gauge) at the ends, and the middles are equivalent to 16 gauge, but in the form of a 2.0 x 1.6mm ellipse. The Wheelsmith &Aelig;ro is my favorite spoke for high-performance applications, not just because of whatever ærodynamic advantage it may offer, but because the flat center section provides an excellent visual indicator to help the wheelbuilder eliminate any residual twist in the spoke. This helps build a wheel that will stay true.
Æro (bladed) spokes have a more pronounced æro shape, flat, rather than elliptical. Although they are the most ærodynamic of spokes, they won't normally fit through the holes in a standard hub because they are too wide. To use "blades", the hub must be slotted with a file. This can weaken the flange, and will usually void the warranty of the hub. It is also a lot of trouble.
There was a fad in the early '90s for Hoshi "blades" which had a double bend instead of a conventional head. This allowed the spokes to be inserted "head first" into the hub flange, so that they could be used with normal hubs. Unfortunately, they turned out to be prone to breakage, and I can't recommend them.
