Results 1 to 5 of 5
    Sep 2014
    How to figure out if I can swap hub with same spokes and rim
    So I am completely ignorant on how spokes are figured out. I have a very nice set of handbuilt wheels that I want to use on a new frame.
    I need to go to a boost rear hub.
    My current rear hub is a Sram X9 QR. How can I figure out if there is another hub that will allow me to have just that hub swapped out without incurring the cost of new spokes?
    Or is that a bad idea in and of itself? Is it okay to re-use spokes?
    Reputation: Mr Pig's Avatar
    I've reused spokes but I'd be very surprised if you bought another brand of hub that has the same dimensions as your old one. It's possible but you'd need to work out the spoke lengths in the same way you would for any other wheel build.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Here, they appear to have your hub dimensions #1 Wheel Building SPOKE CALCULATOR Now Online | PROWHEELBUILDER
    You can keep swapping hubs until you find one close.
    Reputation: J.B. Weld's Avatar
    Unless it's a radial laced wheel (0 cross) wheel hub flange diameter affects spoke length surprisingly little, they can be several mm's different and still use the same spoke length. Check the numbers with a spoke calculator.
    Of course new is better but I've re-used spokes before with good results.
    I brake for stinkbugs
    Jun 2013
    J.B. is right, because spokes connect to the hub at a tangent, hub size barely matters. You can't go from high flange to centerlock, but a 5mm difference is no problem.
  1. Replies: 40
    Last Post: 02-06-2018, 04:31 PM
  2. Replies: 6
    Last Post: 07-24-2015, 02:37 PM
  3. Replies: 1
    Last Post: 06-12-2014, 04:02 PM
  4. HUB SWAP - WI --> I9, Can I re-use my Sapim CX Spokes?
    By Ben_Im in forum Wheels and Tires
    Last Post: 03-14-2014, 10:23 PM
  5. I've been farting all day, and I can't figure out why...
    By iheartbicycles in forum California - Norcal
    Last Post: 11-12-2011, 08:57 AM
