Results 1 to 8 of 8
    Mar 2005
    New question here. How does this dang Ultraflate work???
    I got this a year or two ago and never used it and lost the documentation of course. Yesterday we really needed it because hubby's pump valve was leaking, but we took one look at the Ultraflate head and couldn't figure out how it could possibly work on Schrader. There is nothing to depress the valve pin. I tried to pump a tube today, but nothing happens. Went to the web site and I noticed the newer models have some sort of brass air chuck attached but I don't think I ever had that.
    What am I doing wrong here"
    Do you have a picture of that....that we could see?
    Old man on a bike
    Sounds like you have a Presta head instead of Schrader on your inflator to me.
    suum quique
    Mar 2005
    Quote Originally Posted by Bikinfoolferlife
    I wonder why they would call it an "Intelligent Head" then. What is "intelligent" about Presta-only?
    sadly, like the element
    Sep 2004
    Can you unscrew the pump head? If you can, most likely you can switch around a spring, seal, and a plastic piece (pointy on one end) inside and reassemble the pump and it will then pump Shraeder and vice versa.
    Don't touch me!
    Reputation: beeristasty's Avatar
    They have videos on their website, not sure if you can see what you need though.
    http://www.innovationsaz.com/INmain....Category=power
    No offense to KB, but if I see another "Strong, light, cheap. Pick two" line on this site...
    MCM# eleventy billion
    No offense to thieves, but if I see another "Ride it like you stole it" line on this site...
    Mar 2005
    Good job!
    Well I figured it out...I knew I should have played around with it when I first got it, blown some tubes up. As it was, I had a bulb in it all this time, with the handle not screwed all the way in thinking that would keep unpunctured, and when I tightened it it did not work. So I messed that one up, blew it off,then put in a fresh one & screwed the handle all the way in.
    Guess that's the way you do it, go ahead and puncture the bulb ahead of time?
    Then it worked, but only for so long. Is that because of the resistance put up by the valve pin in Schrader? Do you need a second bulb to get some real pressure with a Schrader?
    What I don't get is, why the Schrader valves anyway? I had Presta on my old GF and I think they're more convenient, easier to empty for one thing. Can't figure out why Specialized still uses these things. I mean it's not like I have to go to a gas station to fill my tires..
    Anyway, I was doing it right to begin with. Pretty slick toy!
    Mar 2005
  1. How can I make Ultraflate work on Schrader??
    By MTDirtGirl in forum General Discussion
    Last Post: 06-26-2005, 12:57 PM
  2. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  3. Hot dang! Now THIS is the firm I need to work at...
    By Dijridoo in forum Singlespeed
    Last Post: 11-19-2004, 02:05 PM
  4. Disciples of trail work
    By General Coonskins in forum Oregon
    Last Post: 04-26-2004, 06:20 PM
  5. Disciples of Dirt-Oregon trail work
    By General Coonskins in forum Trail Building and Advocacy
    Last Post: 03-23-2004, 09:43 AM
