Results 1 to 19 of 19
    how do you keep from scratching black nipples
    when building a wheel with black brass nipples how do you keep from scratching them with the spoke wrench when you have a lot of tension?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by goodmojo View Post
    Never had a problem with that.
    Use the proper size wrench.
    mtbtires.com
    Same. Ive reused colored nipples 3 or 4 times before they start looking rough, tensioned up to 125kgf.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Don't bite them so hard.
    2012 Niner Air9
    2011 MB Le Champion CF
    2009 SE Racing SoCal Flyer
    2003 TiSport Gman
    hit them with a can of black krylon when your done =]
    West Chester, PA
    Pretend it's a mountain bike and not a show car ?
    Use a sharpie.
    A good spoke wrench, like Shiggy said, is still the easiest way, in the long run.
    Quote Originally Posted by 92gli View Post
    Im trying to build the wheels for sale so the nipples pretty much need to be perfect.
    Quote Originally Posted by shiggy View Post
    Im using the park wrenches, are there any that are better? As for sizing, how do you match the sizing with the nipple? If it is just by feel, then I think the fit is fine.
    for a 14 gauge nipple, what size spoke wrench would you use?
    Linoleum Knife
    Reputation: forkboy's Avatar
    What's the harm in wanting something you invest time and energy in, to look good?
    If the holes are drilled through the rim (not UST) - I usually build using a modified screwdriver on the back of the nipple.
    And Park wrenches are OK, but not the best... I like my Spokey.
    DT Swiss Spokey Nipple Wrench > Accessories > Tools > Spoke Wrenches | Jenson USA Online Bike Shop
    West Chester, PA
    Quote Originally Posted by forkboy View Post
    Because its a tool that works in dirt and rocks and mud.
    But he said they're for resale, so fine. Me, I wouldn't care if a little of the black coating was rubbed off on my new nipples. As long as the wheels are straight and tensioned properly.
    Linoleum Knife
    Even if I was doing it for personal use, I'd still try and do it right.
    Reputation: GhisalloWheels's Avatar
    Oct 2007
    Cycle tracks will abound in Utopia. ~H.G. Wells
    Dec 1998
    Generally, most DT, Wheelsmith, and Sapim nipples use a Park black wrench. There is NO slop when the wrench is on the nipple.
    I use only Park standard or 4-sided.
    mtbtires.com
    obsessive
    Reputation: eurotrash666's Avatar
    The Spokey or Park wrenches that are broached at 45 degrees instead of square mark the nips a lot less. It's also a matter of touch. Easy on with the wrench, turn, and easy off. Slow down.
    And if it's just the black nipples are causing trouble, have you considered dating Asian?
    Go out and ride your bike
    Try the 4 sided wrenches that park makes (again, like Shiggy said) if you are concerned about marking. They cost a bit more, but do provide a more secure connection.
    Anti seize and a 2 sided wrench scuffs much much less than oil and a 4 sided wrench. I only build with a park 2 sided wrench now, the 4 sided one drives me nuts.
    Nothing wrong with wanting a decent looking build, regardless if its for you or for sale... a normal spoke wrench should build a clean unscuffed set of alloy nipple wheels without issue. Using anti seize on the threads will make it even more surefire and smooth.
    Moisturize your calloused hands?
    Stay aware of those who hide in plain sight.
Hot Deals
Contests
Latest Mountain Bike Articles
