Results 1 to 5 of 5
    how to adjust play on DT Onyx disk front hub?
    noticed that there is a good bit of play on my DT Swiss Onyx disk front hub, how can I adjust it? Hopefully without buying any new specialized tools
    thanks
    May contain nuts
    Reputation: Haggis's Avatar
    Quote Originally Posted by edgar
    thanks
    Most likely worn bearings, or improperly seated bearings... No real adjustment as such, QR holds the assembly together. They're easy to replace.
    Reputation: RockyRider's Avatar
    Online Manual
    thanks
    http://www.dtswiss.com/data/files/MA...0215101788.pdf
    can you replace the bearings without any special tools?
    Feb 2006
    Many thanks, Rocky Rider....I needed that !
