Results 1 to 2 of 2
    New question here. Hope Pro2 EVO rear hub bolt on?
    Hey fellas, anyone using the 135mm Pro2 EVO bolt in (not thru bolt) 10mm rear hub?
    If so, can the 10mm bolt in be used on a frame that was originally designed to use a standard 135mm QR?
    Or does the frame have to be designed for 10mm rear axle?
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    It'll work on any QR-style 135mm frame. Best ordered direct through Hope USA.
  1. Hope pro2 EVO vs pro2 SS / trials Hub?
    By HPIguy in forum Singlespeed
    Last Post: 01-16-2015, 04:06 PM
  2. Hope Pro2 Evo rear hub conversion: need help
    By guppie in forum Wheels and Tires
    Last Post: 11-29-2014, 11:53 AM
  3. Hope pro2 hub rear
    By vince7870 in forum Wheels and Tires
    Last Post: 10-07-2012, 11:10 PM
  4. Hope pro2 evo rear hub axle conversion
    By mint355 in forum Wheels and Tires
    Last Post: 06-23-2012, 08:15 AM
  5. Hope Pro2 bolt-on with track ends
    By max_29 in forum Singlespeed
    Last Post: 05-07-2011, 06:36 PM
