Results 1 to 2 of 2
    Hope Pro 2 Rear Click Noise
    been running the pro II's for a couple months now on my sultan.
    rescently started getting a click/clank noise.
    happens every so often after coasting , then as i procede to pedal with pressure the rear will click like something is skipping, sorta like a catch then a click noise?
    all drivetrain parts were new when built up, sram 980 cassette on back , X9 rear der , X0 shifters.
    any ideas what's causing it or similar case problems from others.
    thanx
    Feb 2007
    You might want to just open them up and see what is going on. They can be rebuilt pretty easily without tools. Maybe the pawl springs are gunked up.
