Results 1 to 5 of 5
    Reputation: tyrebyter's Avatar
    Hope Pro 2 Rear 10mm Through ?
    I'm sure this question has already been answered, but my search skills are lacking, so I apologize in advance for the clutter. Looking to spec a Hope Pro 2 Evo rear hub for a wheel build and would like to do a 10x135 through axle. I only find the a 12mm through or a 10mm bolt on, but no 10mm through. Am I reading that wrong or is there a 10mm through option?
    Dec 2005
    Depending on where you are purchasing the hub, it might be listed as a Saint 10mm.
    CRC listing for example: Hope Pro 2 Evo Rear Hub - 10mm Saint | Buy Online | ChainReactionCycles.com
    The 10MM TA is less common then some of the other options, which is strange as you take a regular 9/10mm x 135 bike add the 10mm through axle with a good 10mm QR like the DT Swiss RWS and it really helps to stiffen up the back of a bike.
    lamer
    Reputation: llamma's Avatar
    The advantage of the Hope Pro 2 Evo hubs is that they can be converted to anything using just endcaps. Just buy the cheapest version hub you can find and then buy the endcap kit. Here's the one I have Amazon.com: Hope Pro 2 Evo 10x135 Conversion Kit: Sports & Outdoors I've converted mine from QR to 142x12mm (X-12) and back to 10mm with a RWS TA.
    Feel Good About Hood
    Reputation: Pedal/Paddle's Avatar
    Quote Originally Posted by llamma View Post
    True for the regular hub but NOT the SS/Trials hub. QR or bolt on only. Just FYI.
    Thanks for the info. I saw the Saint option but couldn't make out what it was from the description or parts breakdown. Sounds like the way to go.
  1. hope adapters for 10mm
    By melonas22 in forum Wheels and Tires
    Last Post: 03-15-2013, 05:43 PM
  2. Hope 2 Evo Hub 135 x 10mm Bolt On
    By Oro D in forum Weight Weenies
    Last Post: 01-28-2013, 12:18 PM
  3. Hope Pro II Rear Upgrade to 10mm RWS
    By trailjunkee in forum Wheels and Tires
    Last Post: 12-01-2011, 12:09 PM
  4. Hope Pro 2 9mm/10mm RWS Confirmation Request
    By cru_jones in forum Wheels and Tires
    Last Post: 05-18-2011, 06:40 AM
  5. Hope Pro2 10mm Conversion, which on?
    By thrasher_s in forum Wheels and Tires
    Last Post: 02-16-2011, 03:16 PM
