Results 1 to 10 of 10
    TR
    TR is offline
    Angry bunny
    Reputation: TR's Avatar
    Hope bolt in on Pro2 hub
    Converting my old Pro2 hubs to bolt in but it seems that they may have changed the bearing size on the drive side?
    Can anyone help me with what that bearing size should be?
    My new axle wont slide through the existing bearings.
    MTB B'dos
    Reputation: LyNx's Avatar
    Which Pro2 hub are you converting and how old? If it's the original Pro2 that used 2 small bearings in the freehub vs the newer one that moved to a roller bearing, that might be your problem, if it's a Pro2 and you're trying to use a Pro2 EVO axle, that could be your problem. Not 100% sure if they changed bearing/axle size when they moved to the EVO models, but very possible, best bet is to give Hope a call.
    Reputation: Nubster's Avatar
    There are different bearings in the two Pro2 hubs. The Pro2 uses a 15x28 and two 15x24 bearings driveside. The Pro2 EVO uses a 17x28 and two 17-26 and a 17x30 bearing driveside.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Norco Torrent HT 7.1
    Thread already spun
    Reputation: Zowie's Avatar
    Aug 2013
    Hope Pro 2 Rear Axle Conversion Kit | Jenson USA
    This looks proper for an old non-Evo to me. Does yours look like this?
    TR
    TR is offline
    Angry bunny
    Yep, an older one.
    Nothing in the listing about any changes unfortunately.
    It just said that it was a bolt in axle and I assumed it would work based on previous conversions I had done to bolt through and to 142.
    TR
    TR is offline
    Angry bunny
    Quote Originally Posted by Nubster View Post
    So do you know if you can just upgrade the bearings or do I need a whole new freehub (or even better a whole new hub)?
    I have messaged Hope, but no response so far.
    TR
    TR is offline
    Angry bunny
    Yep, looks like that.
    MTB B'dos
    If you want to upgrade to the new bearings, it's an entire new freehub and axle (which it seems you already have), know as I asked about converting my SS/Trials hub, but ended up not worth it at the time, wasn't necessary or important.
    Quote Originally Posted by TR View Post
    Thread already spun
    Aug 2013
    Are you sure?
    If you have an original pro two, the axle is stepped down from 17mm to 15mm like that, and it doesn't fit your freehub body, something's wrong.
    I guess you knew that already though.
    TR
    TR is offline
    Angry bunny
    Quote Originally Posted by Zowie View Post
    Are you sure?
    yep, looking, they have sent me the EVO axle when I need the plain Pro2.
  1. Hope Pro2 EVO rear hub bolt on?
    By verrocchio100 in forum Wheels and Tires
    Last Post: 09-18-2015, 08:16 AM
  2. Hope pro2 EVO vs pro2 SS / trials Hub?
    By HPIguy in forum Singlespeed
    Last Post: 01-16-2015, 04:06 PM
  3. Replies: 3
    Last Post: 05-18-2013, 10:08 AM
  4. Replies: 2
    Last Post: 11-08-2011, 12:12 AM
  5. Hope Pro2 bolt-on with track ends
    By max_29 in forum Singlespeed
    Last Post: 05-07-2011, 06:36 PM
