    Reputation: Uncle Knobby's Avatar
    Jan 2013
    Higher pressure tubeless question
    I know one of the major reasons to go tubeless is to run at lower pressure without pinch flats, but how well does tubeless work at higher pressures?
    I ride a lot of pavement commuting to work and occasionally ride to the nearest trail (10 miles of pavement each way). When on the road I run around 35-37 psi, since I'm clyde-ish. My bike has American Classic tubeless ready (pre-taped and shipped with valves) wheels and I'm running Ardent EXOs. If I pull the tubes and use sealant, will I have a problem running at higher pressure?
    Thanks in advance for some insight; I just want to get the facts before I start coating things in goo.
    2013 El Mariachi Ti and a motor that needs an overhaul.
    Quote Originally Posted by Uncle Knobby View Post
    If the question is can i run tubeless at 35-37psi without exploding them across the garage then my answer would be yes.
    Ive recently had some Mavic Crossmax STs and ran them at about 30-35psi for a full week of riding without any problems and they werent even proper tubless tyres (Continental race kings 2.0wide).
    Yes i did rip a tyre but that was on rocks that just cut the sidewall (unfortunate) i found that at my weight anything less than that just felt a little flat when riding (currently 225lbs).
    Jan 2013
    Yes, that was the gist of the question, not enough coffee to be fully coherent yet. Thanks for the info!
    It will be no problem. I commonly air my tubessless tires up to 40 psi for long sections of road use, or gravel grinder type races.
    Visiting St george/Hurricane? Stay at my vacation rental. Discounts for MTB's
    http://www.vrbo.com/392904
    PM me
  1. Newbie question on tubeless tire pressure
    By ciocc in forum General Discussion
    Last Post: 04-29-2013, 02:52 PM
  2. Tubeless Air Pressure Changes?
    By SCR818 in forum Wheels and Tires
    Last Post: 04-04-2012, 10:29 AM
  3. Lower vs Higher 29'' tire pressure issue...
    By Zaratustra in forum 29er Bikes
    Last Post: 08-30-2011, 05:54 AM
  4. Clydesdale tubeless air pressure?
    By megalops in forum 29er Bikes
    Last Post: 08-22-2011, 01:26 PM
  5. Tubeless tire pressure question
    By RBowles in forum Beginner's Corner
    Last Post: 01-19-2011, 02:10 PM
