Results 1 to 3 of 3
    High Roller 2 EXO's super loose on the rim?
    Anyone else have High Roller 2's in the EXO sidewall? I have one that is so loose, its hard to keep it on the rim for inflation and I'm wondering if they are are just looser than the EXO DHF's I've had of if they had a bead issue? Have worn out about 6 DHF EXO's and was hoping the HR2's would be similar.
    I just bought a HR2 EXO 2 weeks ago, tried to set it up tubeless. It pumped okay, but just didnt look re-assuring.
    First ride it last about 2 hours and blew off the rim! and I agree, it is super loose. I need to pump it to almost 35 psi to make it feel solid.
    I also noticed that the HR2 EXO sidewell doesn't have the same 'reinforced' look as does the DHF EXO. are they the same?
    The DHF EXO mounted up tubeless no worries at all.
    Update: Been using Stan's Flow rims and finally having luck keeping the tire on mounting it ghetto-tubless using a BMX tube. 2 weeks of pretty technical riding and its still fine. But just got a brand new DHF, way tighter on the rim and works tubless with no issues.
